TDI Engine -General Info
Where can I find Replacement nozzles for an automatic alh?
Topic: Where can I find Replacement nozzles for an automatic alh? (Read 9646 times)
October 18, 2013, 07:26:52 pm
bbob203
October 18, 2013, 07:26:52 pm »
Cant seem to find them on any of the top sites
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
October 18, 2013, 08:06:25 pm
Re: Where can I find Replacement nozzles for an automatic alh?
October 18, 2013, 08:06:25 pm »
why not put good ones in?? a standard shift set i think is bigger...
auto got bigger 11mm pumps but i think smaller nozzles... vs the 5 speed
October 19, 2013, 07:36:33 am
bbob203
October 19, 2013, 07:36:33 am »
I want whatever the stock size is and no one seems to list the auto replacements. You even said do not put anything different in.
03 Jetta wagon TDi
October 19, 2013, 02:46:15 pm
October 19, 2013, 02:46:15 pm »
The nozzles do not determine flow guy..
The pump is still going to send either bigger or stock nozzles the same fuel without a tune.
October 19, 2013, 03:56:31 pm
bbob203
October 19, 2013, 03:56:31 pm »
How don't they? Bigger holes more fuel less return flow.
03 Jetta wagon TDi
October 19, 2013, 04:24:45 pm
October 19, 2013, 04:24:45 pm »
Quote from: bbob203 on October 19, 2013, 03:56:31 pm
How don't they? Bigger holes more fuel capacity, creating a potential for less return flow.
^fixed that
It's a positive displacement pump.
October 19, 2013, 04:40:12 pm
cyrus #1
October 19, 2013, 04:40:12 pm »
I wouldn't recommend putting in bigger nozzles unless you plan on getting tuned or enjoy rolling lots of coal. I have DLC 1019's in my auto ALH jetta. The power is excellent but there is far more smoke than I want. The IQ could not be set high enough to dial it in either.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
October 19, 2013, 04:46:59 pm
bbob203
October 19, 2013, 04:46:59 pm »
I want no extra power. I want this gearbox to last as long as possible. This is a daily driver for her to get to work and to drive when we go on trips for her job. Like I said Stock nozzles where they at? I also am not a big fan of rolling coal except when someone cuts me off i like to blip the throttle and give a little cloud to show my disapproval of their poor driving.
Last Edit: October 19, 2013, 05:21:26 pm by bbob203
03 Jetta wagon TDi
October 19, 2013, 07:59:03 pm
October 19, 2013, 07:59:03 pm »
I got a set of 442 (manual trans) injectors from Franks TDIs the car ran better in every respect, and only makes the slightest puff of haze for an instant if you romp on it.
The auto has been fine for 4 years since.
October 20, 2013, 04:37:57 am
bbob203
October 20, 2013, 04:37:57 am »
Maybe ill give them a shot they are cheaper on kerma to.
03 Jetta wagon TDi
October 20, 2013, 06:04:22 pm
thegimpster
October 20, 2013, 06:04:22 pm »
try tdiclub maybe. surely someone over there has a set they have left out of their car or something.
Check out
www.vdubshirts.com
for cool VW themed shirts with attitude.
Reply #11
October 21, 2013, 01:08:54 pm
Zeitgeist
Rule Cascadia
Reply #11 on:
October 21, 2013, 01:08:54 pm »
So my ALH is originally from an auto Jetta, and I'm planning on mating a 12mm head from my spare 4BT to a Land Rover pump body. Which size nozzles should I run? I'm worried that the auto nozzles are too small.
'87 300TD (OM606)
'90 300D (OM602)
'89 Vanagon Bluestar (ALH)
'01 EV Weekender (AXK)
'04 Passat Variant (BHW)
Reply #12
October 21, 2013, 01:34:02 pm
Reply #12 on:
October 21, 2013, 01:34:02 pm »
More important question would be "what are your power goals and what other mods do you have?". Nozzle size is directly related to how much air you have to use the fuel you're injecting.
Reply #13
October 21, 2013, 03:28:38 pm
Zeitgeist
Rule Cascadia
Reply #13 on:
October 21, 2013, 03:28:38 pm »
Agreed. The turbo is a rather smallish KKK unit (not a T3) originally installed on a Mercedes 3.0L diesel.
'87 300TD (OM606)
'90 300D (OM602)
Reply #14
October 21, 2013, 04:15:41 pm
Reply #14 on:
October 21, 2013, 04:15:41 pm »
K26 then?
