Author Topic: Where can I find Replacement nozzles for an automatic alh?  (Read 9627 times)
October 18, 2013, 07:26:52 pm
bbob203
  • 1789
« on: October 18, 2013, 07:26:52 pm »
Cant seem to find them on any of the top sites
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1October 18, 2013, 08:06:25 pm
Re: Where can I find Replacement nozzles for an automatic alh?
« Reply #1 on: October 18, 2013, 08:06:25 pm »
why not put good ones in?? a standard shift set i think is bigger...
auto got bigger 11mm pumps but i think smaller nozzles... vs the 5 speed
Reply #2October 19, 2013, 07:36:33 am
bbob203
  • 1789
« Reply #2 on: October 19, 2013, 07:36:33 am »
I want whatever the stock size is and no one seems to list the auto replacements. You even said do not put anything different in.
03 Jetta wagon TDi
Reply #3October 19, 2013, 02:46:15 pm
« Reply #3 on: October 19, 2013, 02:46:15 pm »
The nozzles do not determine flow guy..
The pump is still going to send either bigger or stock nozzles the same fuel without a tune.
Reply #4October 19, 2013, 03:56:31 pm
bbob203
  • 1789
« Reply #4 on: October 19, 2013, 03:56:31 pm »
How don't they? Bigger holes more fuel less return flow.
03 Jetta wagon TDi
Reply #5October 19, 2013, 04:24:45 pm
« Reply #5 on: October 19, 2013, 04:24:45 pm »
How don't they? Bigger holes more fuel capacity, creating a potential for  less return flow.
^fixed that
It's a positive displacement pump.
Reply #6October 19, 2013, 04:40:12 pm
cyrus #1
  • 360
« Reply #6 on: October 19, 2013, 04:40:12 pm »
I wouldn't recommend putting in bigger nozzles unless you plan on getting tuned or enjoy rolling lots of coal.  I have DLC 1019's in my auto ALH jetta.  The power is excellent but there is far more smoke than I want.  The IQ could not be set high enough to dial it in either.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
1990 Jetta 8v-Eventually to be 1.6TD
Reply #7October 19, 2013, 04:46:59 pm
bbob203
  • 1789
« Reply #7 on: October 19, 2013, 04:46:59 pm »
I want no extra power. I want this gearbox to last as long as possible. This is a daily driver for her to get to work and to drive when we go on trips for her job. Like I said Stock nozzles where they at? I also am not a big fan of rolling coal except when someone cuts me off i like to blip the throttle and give a little cloud to show my disapproval of their poor driving.
« Last Edit: October 19, 2013, 05:21:26 pm by bbob203 »
03 Jetta wagon TDi
Reply #8October 19, 2013, 07:59:03 pm
« Reply #8 on: October 19, 2013, 07:59:03 pm »
I got a set of 442 (manual trans) injectors from Franks TDIs the car ran better in every respect, and only  makes the slightest  puff of haze for an instant if you romp on it.
The auto has been fine for 4 years since.
Reply #9October 20, 2013, 04:37:57 am
bbob203
  • 1789
« Reply #9 on: October 20, 2013, 04:37:57 am »
Maybe ill give them a shot they are cheaper on kerma to.
03 Jetta wagon TDi
Reply #10October 20, 2013, 06:04:22 pm
thegimpster
  • 243
    • VDubShirts.com Awesome VW themed shirts with attitude
« Reply #10 on: October 20, 2013, 06:04:22 pm »
try tdiclub maybe. surely someone over there has a set they have left out of their car or something.
Check out www.vdubshirts.com for cool VW themed shirts with attitude.
Reply #11October 21, 2013, 01:08:54 pm
Zeitgeist
  • 90
    Rule Cascadia
« Reply #11 on: October 21, 2013, 01:08:54 pm »
So my ALH is originally from an auto Jetta, and I'm planning on mating a 12mm head from my spare 4BT to a Land Rover pump body.  Which size nozzles should I run?  I'm worried that the auto nozzles are too small.
'87 300TD (OM606)
'90 300D (OM602)
'89 Vanagon Bluestar (ALH)
'01 EV Weekender (AXK)
'04 Passat Variant (BHW)
Reply #12October 21, 2013, 01:34:02 pm
« Reply #12 on: October 21, 2013, 01:34:02 pm »
More important question would be "what are your power goals and what other mods do you have?".  Nozzle size is directly related to how much air you have to use the fuel you're injecting.
Reply #13October 21, 2013, 03:28:38 pm
Zeitgeist
  • 90
    Rule Cascadia
« Reply #13 on: October 21, 2013, 03:28:38 pm »
Agreed.  The turbo is a rather smallish KKK unit (not a T3) originally installed on a Mercedes 3.0L diesel.
'87 300TD (OM606)
'90 300D (OM602)
Reply #14October 21, 2013, 04:15:41 pm
« Reply #14 on: October 21, 2013, 04:15:41 pm »
K26 then?
