Author Topic: Ill never give up. 83' with 1.5D  (Read 7166 times)
Reply #15March 31, 2014, 08:15:00 pm
Re: Re: Ill never give up. 83' with 1.5D
« Reply #15 on: March 31, 2014, 08:15:00 pm »
Well that definitely ain't right.
If it's the HG then you almost certainly will have some pressure in the cooling system as that doesn't look like oil smoke. Easy to test - before starting the car with the engine stone cold check if there is any pressure under the cap, doesn't matter if there is a little, the important thing is to equalize with outside. Screw the cap back on and fire the engine. Let it idle for about 5 mins and check for pressure again. There should be virtually none. If you have a bubbling coolant tank or a lot of pressure you've found your problem for free!
If the cooling system passes the test then I'd advance the pump. That's free but not as easy.
Reply #16March 31, 2014, 08:15:48 pm
Re:
« Reply #16 on: March 31, 2014, 08:15:48 pm »
Oh yeah - does the cold start handle have any effect?
Reply #17April 01, 2014, 01:40:14 am
Mark(The Miser)UK
  • 1557
« Reply #17 on: April 01, 2014, 01:40:14 am »
That looks like retarded timing to me.
From the picture it is not pulsed so it can't be a broken ring.
I'd not worry about head gaskets leaking water into the cylinders, unless its leaking into all of them, which is unlikely.
Seals in the pump only serve to make starting hard, not much if at all when running.  Slacken fuel lines at the injectors and check that the pulse of fuel on #1 coincides with cam lobes skywards and just before TDC.
Partner turning on stareter whilst staring at slightly raised fuel line  @#1 will be observable...
Mark-The-Miser-UK
Reply #18April 01, 2014, 10:25:59 am
Jetmugg
  • 530
« Reply #18 on: April 01, 2014, 10:25:59 am »
Is the cam timing correct?
Steve.
Reply #19April 01, 2014, 11:57:52 am
Snowyroads
  • 26
« Reply #19 on: April 01, 2014, 11:57:52 am »
The cold start is doing something but the engine runs better without it. Ill check the coolant bottle tonight, thanks!
I'm thinking the timing might be low too.
And the engine is timed properly, per Vince waldons DIY.
I'm banking on the hg right now :/
Reply #20April 01, 2014, 02:58:58 pm
Mark(The Miser)UK
  • 1557
« Reply #20 on: April 01, 2014, 02:58:58 pm »
If the gasket is blown, then water will pressurize  before it actually gets warm.
For a duff gasket to be bad enough to affect compression enough to prevent/reduce combustion, then coolant pipes will split in seconds.
The diesel pulse is the best way to determine injection in the correct ball park.
Mark-The-Miser-UK
Reply #21April 01, 2014, 06:13:06 pm
  • 4549
« Reply #21 on: April 01, 2014, 06:13:06 pm »
If Cold start cable makes it worse of a runner I would say over timed.  Generally it helps with a retarded timing cause it bumps it up by a few degrees.  If as you say makes it run worse I would say too much into it and roll the IP to the front while running an see what it does smoke wise.
Reply #22April 01, 2014, 08:04:52 pm
Snowyroads
  • 26
« Reply #22 on: April 01, 2014, 08:04:52 pm »
Timing advance lever did work to smooth out idle.  The advance is working as it should.  I left it pulled for the video.
Let the car idle and the coolant bottle was hardly pressurized at all.  It gave me a tiny hiss.  Say 1-2 psi.  The engine did not get warm enough to cycle the thermostat so i dont know how much steam could have been produced. But it had been idling for about 5 minutes.    No cloudiness in the bottle.  The water still has a bit of black crap and oily residue floating on the surface.
And i still dont know how you all advance the timing while running!  I tried what one of our members suggested with a 1/4 socket and u-joint head with the 13mm but i can not ever get that bottom pulley mount bolt!  Every time i time this engine  (thinkin like 6-8 times now)  I have to remove alt, bracket, pulleys, cam cover. if i could just get to that bolt, i could play with the timing in 10 not 1h.
The video:
http://s72.photobucket.com/user/smoldt88/media/DSCF0026_zps90718db0.mp4.html
Thanks again for your help!
I will drive this thing to work in 3 months..  I will
Also, Tell me i'm not sitting on a pot of gold here.  I have the TD set up from the 83.  When i get this thing up and going,  i may just put the turbo back on.   Think its still okay or should i send it away to be rebuilt? 190k on the 83 rabbit td
« Last Edit: April 01, 2014, 08:23:51 pm by Snowyroads »
Reply #23April 01, 2014, 08:51:54 pm
« Reply #23 on: April 01, 2014, 08:51:54 pm »
May not mean a whole lot unless you know the system seal well enough to pressurize at all.
Just to confirm...You have new nozzles, heat shields, and  verified no compression leaks around any injector?
for oily coolant,  add half a box of Cascade dishwasher powder, run to full operating temperature, then drain.  This is what we do with the fullsize diesels when thee blow the oil cooler, and it seems to work well.  they hold about 7 gal of coolant, so you can probably reduce the dose quite a bit.  You do have to get it hot though, blocking the radiator with cardboard can help.
Reply #24April 02, 2014, 05:03:55 am
Mark(The Miser)UK
  • 1557
« Reply #24 on: April 02, 2014, 05:03:55 am »
The slight pressurizing sounds about right for an intact gasket.
If the low pressure  is due to pipework leaks, then you will have to be loosing significant water over the 5 minutes.
If you are not, then any cylinder to water leak is small, and will have no bearing on the way  engine is running.
Leaks around injectors, although not particularly welcome, again have no bearing on the way your engine is running.
I've looked at the sound track of the video. not easy to determine what is going on, as too many resonances. Another short recording with the hood down standing about 4 or 5ft  in front of the car.would be more helpful. There is some knocking, but it's quite variable.
Re moving pump whilst engine is running
 all my Quantum pumps are adjusted by pre-loosening the one lower nut accessed through one of the holes in the pulley with a 13mm deep ring spanner at about 5 'o' clock, and two 13mm nuts behind the timing belt guard, in the pump flange, one at about 10  o clock close to the #1 injector and one say 3 'o' clock.
The 4th nut is the pivot one down under the pump outlet head, with a 13mm bolt and a 14mm [or is it 15mm] nut. This can be awkward because the 13mm bolt head is hidden behind the oil stick and a water pipe.
Remember to detension fuel line after pump swinging.
Mark-The-Miser-UK
Reply #25April 02, 2014, 12:39:15 pm
damac
  • 531
« Reply #25 on: April 02, 2014, 12:39:15 pm »
I don't see where its mentioned whats up with the injectors?
Definately hear some odd rattling in there.
Sounds like you don't have the right ip mount mini bracket if you are talking things off in order to crack the nuts so you can time by ear.  the bottom ip bolt should be on the pulley side of the bracket so you can crack it before the rest.
I have lined the pump up to the mark before and just cracked each nut and smacked the pump head with a mallet to see what the car agrees with on a cold start, no cold start lever pulled.
Of course make sure you aren't ingesting air to start and that your filter and lines and out bolt are all clear so you can try and advance the smoke away.
But I do that with good parts and pumps I have resealed and cleaned.
I have had 2 runners that seemed to get the job done before but I could not ignore what I was seeing when timed by the book, and the pinging and smoke I was seeing.
Both are td's.  A jetta that had some nasty nailing when I tried to advance the smoke away and it wouldn't even at idle, although not as thick as yours.   Smoked some when driving to, even after warm and at a stop sign, etc.
Next is my pickup I just got on the road a few months ago.  Thought I had a set of running injectors from another project on the shelf, timed it up and it sounded ok and all of that.  But when I went to drive it, I was smoking out everybody behind me :)
Got new bosch injectors both times and no more of those issues.
1985 turbo diesel jetta
Reply #26April 04, 2014, 08:16:04 pm
Snowyroads
  • 26
« Reply #26 on: April 04, 2014, 08:16:04 pm »
TIMING IS AWESOME!
https://www.youtube.com/watch?v=SqoM6lg9tIo&feature=youtu.be
So i put the bottom IP bolt into the pulley side and pushed the IP towards the engine a whole bunch and shes purring like a kitten!!  it really sounds beautiful, save the horrible clacking from the exhaust piping.  Im so ready for another test drive.
So lets forget about the engine for a while.  I'm convinced that i've fixed the issues with the engine and now i need to focus on a few other issues.
First: What i've done with the 83.
rear brakes, 4speed swap with linkage from 4speed, manual steering swap, sent away the injectors for rebuild,  new glow plugs (pimping coming soon),  newer fuel filter.  probably forgetting a couple things.
so the immediate issues:
*BIGGEST. I need to fix the super spongy brakes.. I was about to do the brake bleeding again tonight with my gf when i discovered a front caliper was loosely flopping around on the mount.  I'll head to the junkyard tomorrow for the 2 allen bolts to mount it properly.  I'm really hoping that this fixes the spongy feeling.  I've bleed the air all around a couple times last year but nothing ever worked.    Im hoping that the 1/4 inch gap is allowing the brake piston to push the caliper away from the rotor has added to the poor brakes.
*BIG.  So i switched to the 1.5 triangle exhaust mani slash 3/4 exhaust pipe with the 1/4 1.6 muffler piping..   The stupid 1.5 pipe is about 2mm to large a diameter and i can not for the life of me tighten it on to the remaining pipe.. I tried to shim it with some exhaust repair tin foil from autozone.. no luck.  The rattle of the larger pipe around the smaller is awful at best.  clack a lacka smaka *** all day  Its annoying
*third.    Ill climb under the car tomorrow if the rain holds off.  I'm having to duck under the reverse gate to get into first..  I have played around with the linkage a bunch and it shouldnt be too hard without 5th to move the whole lot of the linkage over but ill just have to see how it goes..   I'm just going to set it in 1st and crawl under the car to adjust.. Is this an acceptable practice?  or do i go for reverse?   all the way over and pulled back(under the car) That also seems like a decent place to try and find the distant extreme to which all others will be closer to center.
EDIT: I did find bubbling around 3 of the injectors. Not real big bubbles or anything but you guys mentioned the injector seals.  Is there any big worry here?
Thanks all. We have accomplished another successful revival of a timeless beauty
« Last Edit: April 04, 2014, 08:19:36 pm by Snowyroads »
Reply #27April 04, 2014, 08:40:29 pm
« Reply #27 on: April 04, 2014, 08:40:29 pm »
If it's not fuel drippin out of the rubber lines, I'd worry.
dry the area with brake clean and fire it up to be sure.
If it's not the returns,  retorque your injector halves(don't overtorque or they crack and leak), and take a real hard look at the area where the seal washers seat to the head.
The harbor  freight tailpipe expanders work OK on small pipe, but don't bother with the 3" one.
If you had to massively advance the pump, something probably isn't right.
But starting and idling is a good  thing.
Reply #28April 05, 2014, 02:58:00 am
Mark(The Miser)UK
  • 1557
« Reply #28 on: April 05, 2014, 02:58:00 am »
RE that bubbling up the threads. I would not recommend over torquing.
Just leave them for  a week to see if they settle down.
If they don't, then remove injectors.
I assume these are brand new  heat shields.
Perfectly safe to reuse them indeed reused fit better than new.
Reform them using my technique listed here somewhere.
Reusing them once is perfectly safe, as my research found me reusing them 15 times [don't do this though].
The nozzle faces smears the soft shield and through reuse creates a better seal than new.
Note the best torquing techniques to avoid writing off the vulnerable injector boss on the head, and thus the head...
Mark-The-Miser-UK
Reply #29May 02, 2014, 07:27:14 pm
Snowyroads
  • 26
« Reply #29 on: May 02, 2014, 07:27:14 pm »
One last update before i make a new thread with a less stupid name!
So the car is driving much much better now.  I've probably put 30 miles on it since getting it running a month ago.
I did the hillbilly timing bump with a rubber mallet and it worked well but wouldn't hardly pull in 3rd or 4th (4speed trans).  So today i checked the timing with a dial indicator.  I was at about 1.28mm :) Oops so i backed it down to 1.15 and tried it again today.  Better driving but still slow.
Started up well again even after cracking the ip fuel lines.  It was super smokey with unburnt diesel smell. white smoke.  Until i warmed it up.  I want to drop the timing down to .88 like the book/vince waldon shows for the 1.5 pump but im worried that the retarded timing will make the white smoke worse, no?
Another note was even with the pump at 1.28 and today at 1.15, i am getting no black smoke..  im confused. I know the engine has less than 500 miles on it for sure and too much idling if you ask me. probably around 3 hours if i had to guess between me and PO.    So i think before i retard the timing, id finally figure out how to break that fuel screw collar off and crank that biz up.
no bubbles in intake line.  GP are working as far as im concerned and i drove for 20 minutes today without a problem.  the idle is pretty slow but it didn't ever die on me.  Id say top speed is about 45 in 3rd.  Maybe ill plumb up my speedo and get a real reading some time :)
On my next thread, we can tackle the other long list of problems.. The pictures will explain much!
Love you all! we did it!
