Author Topic: Dead starter? Video inside.  (Read 5834 times)
Reply #15February 04, 2013, 10:43:03 pm
Re: Dead starter? Video inside.
« Reply #15 on: February 04, 2013, 10:43:03 pm »
unless timing is perfect, and your engine is in PERFECT shape, a gasser starter WILL struggle to start a cold diesel..
the gasser starter is .7hp
the diesel starter is 2.5hp
theres a BIG difference..
ive never had good luck using a gasser starter on a diesel engine..
Reply #16February 05, 2013, 06:06:26 am
Farlos
  • 17
« Reply #16 on: February 05, 2013, 06:06:26 am »
This is some info i didnt have, so, i will refresh and upgrade my wiring, and then, i will try to rebuild my starter with new bushes.
Reply #17February 05, 2013, 12:42:03 pm
« Reply #17 on: February 05, 2013, 12:42:03 pm »
and when adding grounds, add one that bolts to the trans, near the starter, or bolt it directly to the starter body.. dont give the ground any longer path than absolutely necessary..
valve cover studs are a bad place to secure wires.. there is a cork gasket insulating the valve cover to a point..
if you need new battery cables, then go buy an amplifier install kit, get it with 4, or better yet, 2ga wire..
make your new cables out of that, and be done..
a bad cable can make a starter seem dead..
Reply #18February 05, 2013, 06:10:13 pm
« Reply #18 on: February 05, 2013, 06:10:13 pm »
I have 1/0 in my mk2. Size does matter.
Reply #19February 05, 2013, 08:54:02 pm
« Reply #19 on: February 05, 2013, 08:54:02 pm »
You have cables big enough to turn over two 7.3 IH's at the same time.. lmao
Overkill is a real phenomena. lol
Reply #20February 05, 2013, 08:56:21 pm
« Reply #20 on: February 05, 2013, 08:56:21 pm »
Overkill...because there is no such thing as underkill.
Reply #21February 05, 2013, 08:56:56 pm
« Reply #21 on: February 05, 2013, 08:56:56 pm »
Just curious, did you pay more for the car? or the cables? ;) Those are stupid expensive for me locally... :(
Reply #22February 05, 2013, 08:59:28 pm
« Reply #22 on: February 05, 2013, 08:59:28 pm »
I would have had 2/0 but they didn't have enough. I just bought the wire and made the cables myself, so I think I had around 30-40 USD in it. This was 2006, so it may have went up a bit since then.
Also, for a non moving car I have probably 7,500.00 in the MK2 and various parts right now. So what started off as a 600.00 car ended up bad.
Reply #23February 09, 2013, 04:22:49 am
Farlos
  • 17
« Reply #23 on: February 09, 2013, 04:22:49 am »
so today i took my main wires off my car, and cut replacements from 4 gauge wire (i think mine is thicker), i will pos pictures when i finish
