Author Topic: Dead starter? Video inside.  (Read 5887 times)
February 01, 2013, 11:40:45 am
Farlos
  • 17
« on: February 01, 2013, 11:40:45 am »
http://www.youtube.com/watch?v=U2diZ6pFSYc
Good battery, (is my TDi's battery) less than 1 year old.
Might need new brushes in my starter?
Reply #1February 01, 2013, 01:37:16 pm
Re: Dead starter? Video inside.
« Reply #1 on: February 01, 2013, 01:37:16 pm »
are the ground and power wires known to be good?
added any extra grounds? they are not a bad idea, supplemental grounds..
checked your starter bushing?
if your ground and power wires are good, and your starter bushing is also good, and the car still runs as it should,
then it would lead me to believe that you have something dragging, or just that your starter is shot..
can you coast start the car, and have it run as normal? just wont re-start?
didnt seem like it was pulling very many amps.. usually a dead starter will dim the lights when cranking, even with a NEW battery..
Reply #2February 02, 2013, 03:18:26 am
Farlos
  • 17
« Reply #2 on: February 02, 2013, 03:18:26 am »
How can i test them?
How can i add any extra grounds? maybe to the head?
No, how can i?
So, you think my starter is fine, but my wiring is bad?
Reply #3February 02, 2013, 06:17:35 am
« Reply #3 on: February 02, 2013, 06:17:35 am »
First:
- What year is the car, engine?
- will it start with a jump from another car?
- will it start after charging the battery?
- has it taken a long time cranking before starting?
- are the battery terminals and cable-ends clean from corrosion where they join?
Reply #4February 02, 2013, 06:18:39 pm
wdkingery
  • 494
« Reply #4 on: February 02, 2013, 06:18:39 pm »
if you don't mind a bit of defiling:
go to the junkyard and..
1.) pull a gasser starter (or diesel if they have one)
     - install it
2.) grab the battery cables off an f150 (or f250 if they got one)
     - remove 1 or 2 valve cover nuts and thread a bare end of the battery cable under that little metal bar that connects them all, and connect the other end to the negative battery terminal
3.) use the remaining section of battery cable from the f250 to connect the positive battery terminal with the starter, and if you have enough, you can double the one that runs to the alternator as well.
that is all
Reply #5February 03, 2013, 08:47:56 am
Farlos
  • 17
« Reply #5 on: February 03, 2013, 08:47:56 am »
First:
-1992, RB engine, 1.6 td with intercooler
-Yes
- In summer yes, in winter no
- The last time i jump started it was in september, have not touched it ever since.
- the battery terminals are deff in good nick, but the cables are old, from a 1986 GTi.
     - install it
that is all
i already have 2 gasser starters, but i didnt think they can start a diesel engine, i will give it a try.
Here in Spain there is not even one f150 in a junkyard, but i get the point, good stiff cables for an extra ground in the head and for a positive directly to the starter.
Reply #6February 03, 2013, 12:12:49 pm
« Reply #6 on: February 03, 2013, 12:12:49 pm »
-ok
-Yes
- then maybe the starter is OK, but battery is perhaps bad.
- batteries get poor in the winter, not usually starters
- I should ask better... Does the starter need to crank more than 30 sec to start the engine? That will make the brushes/starter/bushing wear faster.
- They might be small for a diesel... if they get warm from cranking, bigger is better.
It sounds as likely (or more) to be battery/charging as starter.
What is the resting voltage of the battery?
What is the voltage at the battery when the engine is running (after the glow is over and dash indicator LED is off)
Testing the charging system basics here: http://www.vwdiesel.net/forum/index.php?topic=32799.msg304607#msg304607
"...def in good nick..." A traditional Spanish expression?  ;D
Reply #7February 03, 2013, 12:44:00 pm
Farlos
  • 17
« Reply #7 on: February 03, 2013, 12:44:00 pm »
-ok
-Yes
Thank you so much for your attention, im spanish but i learnt my poor english in a little village in UK.
I will try to jumpstart the car as soon as i can, and i will change the main wires to and from the battery, re tighten the nuts from all the wire connectors and then, if everything fails, remove the starter and have it inspected at home.
If everything is working properly, would a gasser starter be able to start a diesel engine? because there are far more gassers here than diesels, and diesel replacements are more expensive.
thanks again!
Reply #8February 03, 2013, 06:24:43 pm
« Reply #8 on: February 03, 2013, 06:24:43 pm »
Gasser will do it but the diesel is better. I would say that it is a starter bushing problem.
Reply #9February 04, 2013, 01:01:15 am
« Reply #9 on: February 04, 2013, 01:01:15 am »
they will start a WARM engine..
they struggle to fire it when cold tho..
Reply #10February 04, 2013, 10:56:09 am
wdkingery
  • 494
« Reply #10 on: February 04, 2013, 10:56:09 am »
I got a tied gasser starter that starts a cold motor running on pure wmo ;-)
Reply #11February 04, 2013, 11:57:55 am
Farlos
  • 17
« Reply #11 on: February 04, 2013, 11:57:55 am »
So, any 020 starter will work?
Reply #12February 04, 2013, 12:32:39 pm
srgtlord
  • 797
« Reply #12 on: February 04, 2013, 12:32:39 pm »
No get a real diesel starter and call it a day....
Reply #13February 04, 2013, 12:59:53 pm
« Reply #13 on: February 04, 2013, 12:59:53 pm »
I do recommend using a diesel starter, but any standard mk1,2 or 3 gas starter will get you by.
Reply #14February 04, 2013, 01:51:45 pm
wdkingery
  • 494
« Reply #14 on: February 04, 2013, 01:51:45 pm »
i mean if you are going to go drop $100 on a new starter, obviously get a diesel one..
but if you have "any 020 starter" laying around, install it.
