Author Topic: Alternator tensioner idea.  (Read 4681 times)
January 26, 2013, 06:06:20 pm
jaed_43725
« on: January 26, 2013, 06:06:20 pm »
Has anyone come up with a turnbuckle setup for these. I have a 85 TD w/AC and had to put on a new alternator belt. What a PITA and stupid design. I remember on a 87 Mustang I had this: http://www.summitracing.com/parts/mch-30351/media/images/year/1987/make/ford/model/mustang. I am wanting to eliminate that stupid tensioner pulley thing and use the alternator as the tensioner. Any info on this is much appreciated. Thanks.
Reply #1January 26, 2013, 06:19:04 pm
bbob203
  • 1789
Re: Alternator tensioner idea.
« Reply #1 on: January 26, 2013, 06:19:04 pm »
i made a bracket out of 1/4 in steel from lowes ill post a pic tomorrow
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2January 26, 2013, 06:19:29 pm
« Reply #2 on: January 26, 2013, 06:19:29 pm »
ja, search the board for "turnbuckle"... a few setups around, most delete the AC compressor.
Reply #3January 26, 2013, 06:22:05 pm
bbob203
  • 1789
« Reply #3 on: January 26, 2013, 06:22:05 pm »
Ive thought about using a turnbuckle up top with a modfied ac setup to "help it out" buy running a smooth idler on the back of the belt the turnbuckle tension from the top requiring less or back on the belt and potentially removing need for idle at all.
03 Jetta wagon TDi
Reply #4January 26, 2013, 06:27:15 pm
« Reply #4 on: January 26, 2013, 06:27:15 pm »
I'm still scouring the web for a good overrunning v-belt pulley. The whole tensioner/belt-slack/crank-nose crap could be relieved a great deal.
Serpentine conversion is the full-meal-deal, but a durable clutched v-pulley could really help the value crowd.
Reply #5January 26, 2013, 06:31:04 pm
« Reply #5 on: January 26, 2013, 06:31:04 pm »
it is a BAD IDEA to tension a V-belt from the back side.. they are not designed to work like that.
Reply #6January 27, 2013, 02:56:53 am
bbob203
  • 1789
« Reply #6 on: January 27, 2013, 02:56:53 am »
trust me I know. But its also a dumbass idea to tension how its done on mk2s with ac.
03 Jetta wagon TDi
Reply #7January 27, 2013, 02:58:20 am
bbob203
  • 1789
« Reply #7 on: January 27, 2013, 02:58:20 am »
is there any pics floating around of what a 1.6 crank nose looks like with it modified for a tdi pulley?
03 Jetta wagon TDi
Reply #8January 27, 2013, 03:59:11 am
« Reply #8 on: January 27, 2013, 03:59:11 am »
Crazy andy:
Andrew's jig:
Fatmobile's jig:
Reply #9January 27, 2013, 05:16:49 am
bbob203
  • 1789
« Reply #9 on: January 27, 2013, 05:16:49 am »
so people are putting the flat spot on the opposite side of the oe key way?
03 Jetta wagon TDi
Reply #10January 27, 2013, 06:21:14 am
CrazyAndy
  • 739
« Reply #10 on: January 27, 2013, 06:21:14 am »
Only if the keyway on the crank hasn't worn out so bad as to have raised edges.  Then you need to cut over the keyway, or at least turn down the raised edges.  But yep, cutting opposite the keyway is the usual way if the damage is only mild or nonexistent.
And I didn't know folks had made jigs, that's very nice.  I especially like fatmobiles jig since it's easier to clamp to a support.
Reply #11January 27, 2013, 06:22:55 am
bbob203
  • 1789
« Reply #11 on: January 27, 2013, 06:22:55 am »
looks like his could be done on the vehicle no? Thats what i want to do.
03 Jetta wagon TDi
Reply #12January 27, 2013, 06:31:10 am
« Reply #12 on: January 27, 2013, 06:31:10 am »
AIUI, both can be used in-place.
Reply #13January 27, 2013, 06:50:43 pm
92EcoDiesel Jetta
« Reply #13 on: January 27, 2013, 06:50:43 pm »
With ideas from themans and fatmobile, I made this setup and it's  been solid, no belt adjustment needed since the first adjustment and it's been a few week around 1500 miles driven.
http://www.vwdiesel.net/forum/index.php?topic=32520.15
Reply #14January 27, 2013, 08:17:25 pm
« Reply #14 on: January 27, 2013, 08:17:25 pm »
So those flat saw teeth are cutters to cut a flat on the crank nose?
What is the basic problems with the design?
I lost two pivot bolts on the alternator shortly after I got it,  but it isn't a stock alternator. Someone had cobbled a non W terminal design alternator on it. I have not have had any problem since I last used a hardened bolt for the fulcrum. I blamed the homemade tensioning arm. My Alternator bracket tends to flex.
