Author Topic: K24/T3 turbo on AAZ  (Read 8590 times)
November 24, 2011, 05:44:52 am
ilikevwdiesel
  • 1202
K24/T3 turbo on AAZ
« on: November 24, 2011, 05:44:52 am »
this is probably for the Canadian posters here: what is the best way to get a K24 or a T3 from a 1.6 TD onto an AAZ engine? That is, is there a combination of factory parts that make it all a bolt on or do certain parts have to be fabricated? Is the early AAZ/K14 exhaust manifold better than the 1.6 TD unit? Replies from people who have actually done this modification please. Thanks.
My Bio
Reply #1November 24, 2011, 06:22:48 am
chrisg
  • 72
Re: K24/T3 turbo on AAZ
« Reply #1 on: November 24, 2011, 06:22:48 am »
i'm planning on it next spring and have done lots of reseach.
i plan to use the 1.6 manifold with the T3 attached. its pretty well bolt on besides the oil drain. your best bet from what i've seen and read is to use a pipe tap to tap the flange on the turbo and use a braided line from the turbo down to the block.
you will also need to get or fab up a new down pipe due to the exhaust having a square flange/bolt pattern vs the rectangle one of the AAZ
Reply #2November 24, 2011, 10:11:43 am
stewardc
« Reply #2 on: November 24, 2011, 10:11:43 am »
The 1.6 exhaust manifold and T3 is a direct bolt-on and makes a great engine spectacular. I used a custom braided oil feedline which I got made at a hydraulic shop for $20. The drain fittings are below. Top one is the turbo oil outlet fitting and the bottom one (also available from the hydraulic shop) goes into the block to replace the old banjo bolt. Then just craft up a stainless flex line to connect the 2.
Add a manual boost controller and ARP head studs, set the boost at 20psi and watch the tires melt  ;D
Downpipes are available from Giles and another exhaust company (I forget which one right now).
My custom downpipe
« Last Edit: November 24, 2011, 10:17:30 am by stewardc »
Reply #3November 24, 2011, 12:35:50 pm
ilikevwdiesel
  • 1202
« Reply #3 on: November 24, 2011, 12:35:50 pm »
how come you guys don't use the AAZ exhaust manifold that used a K14 turbo? Aren't the ports d shaped to match the AAZ cylinder head? And where did you get that Mk1 downpipe that's nice...the ones I've got came from Techtonics.
My Bio
Reply #4November 24, 2011, 12:41:28 pm
ilikevwdiesel
  • 1202
« Reply #4 on: November 24, 2011, 12:41:28 pm »
has anyone put a T3 on an AAZ and tried to use the 1.6 oil pan and turbo oil return line? maybe it would reach down there?  :D
My Bio
Reply #5November 24, 2011, 12:59:11 pm
« Reply #5 on: November 24, 2011, 12:59:11 pm »
AAZ is over a half inch taller than a 1.6, i dont see how the return line is going to magically lengthen its self..
Reply #6November 24, 2011, 01:03:26 pm
ilikevwdiesel
  • 1202
« Reply #6 on: November 24, 2011, 01:03:26 pm »
did somebody say something?
My Bio
Reply #7November 24, 2011, 01:06:40 pm
« Reply #7 on: November 24, 2011, 01:06:40 pm »
are you still all butt hurt about that last arguement?
(i believe the 1.9 also has a different bolt pattern on a the oil pan rail)
Reply #8November 24, 2011, 01:09:36 pm
ilikevwdiesel
  • 1202
« Reply #8 on: November 24, 2011, 01:09:36 pm »
butt hert....  lol
My Bio
Reply #9November 24, 2011, 01:21:29 pm
410
  • 581
« Reply #9 on: November 24, 2011, 01:21:29 pm »
Oil pan bolt pattern is the same between the two engines.
Reply #10November 24, 2011, 01:22:27 pm
« Reply #10 on: November 24, 2011, 01:22:27 pm »
should be mature about it, and call it water under the bridge...  :)
or you could pack it around with you and hold a grudge like an immature kid..  :'(
your choice.  ;)
i already let the issues go, its in the past, who cares? it was just an arguement about trannies, i never called you any bad names, nothing like that..  8)
Reply #11November 24, 2011, 01:22:55 pm
« Reply #11 on: November 24, 2011, 01:22:55 pm »
its the 1.6 and ABA im thinking of then, thanks for the correction.
Reply #12November 24, 2011, 01:27:36 pm
ilikevwdiesel
  • 1202
« Reply #12 on: November 24, 2011, 01:27:36 pm »
your choice.  ;)
alright we cool
My Bio
Reply #13November 24, 2011, 01:30:17 pm
stewardc
« Reply #13 on: November 24, 2011, 01:30:17 pm »
The D shaped ports are only on the intake. Like this
Reply #14November 24, 2011, 01:33:59 pm
stewardc
« Reply #14 on: November 24, 2011, 01:33:59 pm »
Yes, I did till I got my new AAZ pan powdercoated. I had to fudge up a return and seal the bolthole for the AAZ drain.
