S-PAutomotive.com
Author Topic: Control arm mounting bolts, where to find?  (Read 2888 times)
September 09, 2011, 10:49:48 pm
  • 2787
« on: September 09, 2011, 10:49:48 pm »
For some reason my two rear ones (front suspension) are pitted pretty bad so I thought I'd throw new ones at it.
The part # is N 100 874 03 but I can't find anything online about it other than more people looking for the same thing ::).
Thanks
Reply #1September 10, 2011, 09:16:13 am
  • 1739
Re: Control arm mounting bolts, where to find?
« Reply #1 on: September 10, 2011, 09:16:13 am »
Isn't the rear part of the table on a Rabbit held by a clamp?
or are you asking about a different model?
Reply #2September 10, 2011, 03:01:22 pm
« Reply #2 on: September 10, 2011, 03:01:22 pm »
yes.. the rear is held by a clamp, and it connects to studs on the unibody..
the FRONT of the control arm takes a special bolt tho..
Reply #3September 10, 2011, 03:45:21 pm
  • 2787
« Reply #3 on: September 10, 2011, 03:45:21 pm »
oops, sorry guys, I'm talking about my '92 golf :-\.
These are the bolts that hold the rear of the control arm and the subframe to the body.
Reply #4September 10, 2011, 08:06:34 pm
  • 1739
« Reply #4 on: September 10, 2011, 08:06:34 pm »
It's 12mm x 1.5 pitch and 74 mm long [however that may include the 2mm  pointy unthreaded end]. If you can find them at a metric fastener supply, just make sure it's 10.9 or 12.5 grade
Reply #5September 10, 2011, 11:50:47 pm
  • 2787
« Reply #5 on: September 10, 2011, 11:50:47 pm »
Yeah I figured that would be my option, thanks.
