Author Topic: odo, speedo don't work on 2002 tdi auto  (Read 5037 times)
August 21, 2011, 08:13:23 am
motomike33y
  • 190
« on: August 21, 2011, 08:13:23 am »
replaced VSS on transmission but still won't work.  Is there any way to test the cluster other than replacement?  If I replace the cluster, then apparently I have to get vag-com to reset everything, correct?  Any less expensive suggestions?  thanks
82 vanagon 1.6 waiting rebuild
81 jetta w/dasher 1.5 engine
91 jetta w/ 85 golf 1.6 NA- work in progress           suzuki samurai hardtop that may someday be diesel
2012 golf tdi
Reply #1August 21, 2011, 10:02:59 am
  • 1739
Re: odo, speedo don't work on 2002 tdi auto
« Reply #1 on: August 21, 2011, 10:02:59 am »
If you have vag-com , you can do an output test to check the speedo operation.
I have experienced more than one mk4 with strange VSS wiring issues. Did you check to see if you have voltage coming to the sensor?
Reply #2August 21, 2011, 07:21:01 pm
motomike33y
  • 190
« Reply #2 on: August 21, 2011, 07:21:01 pm »
I don't have a vag-com.  didn't do any type of testing, figured easiest and first thing was to replace the vss since I had a new one for it.
2012 golf tdi
Reply #3August 27, 2011, 02:27:56 pm
catlin_cava
  • 1954
« Reply #3 on: August 27, 2011, 02:27:56 pm »
Do your reverse llights wlrk? This sounds stupid but i had thr same problem on my 2000 and it was the fuse check it, the reverse lights and speedo/odo are on the same fuse
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #4August 28, 2011, 10:51:58 am
Powered by Spearco
  • 1203
« Reply #4 on: August 28, 2011, 10:51:58 am »
The auto trannies also have a trans speed sensor thats located under the drivers trans mount that can cause simulare issues. The way to access it is to unbolt/remove the trans mount assembly and then you can get to it.
You should at least find someone with VagCom and check outputs and inputs before just throwing sensors at it as they can get spendy.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #5August 29, 2011, 05:25:47 am
motomike33y
  • 190
« Reply #5 on: August 29, 2011, 05:25:47 am »
I changed the sensor under the trans mount, and I think my back-up lights work, but I'll check the fuse.  thanks.
2012 golf tdi
Reply #6August 31, 2011, 10:19:48 am
motomike33y
  • 190
« Reply #6 on: August 31, 2011, 10:19:48 am »
nope, back-up lights work--guess I save up for vag-com and instrument cluster
2012 golf tdi
Reply #7September 03, 2011, 04:33:34 am
catlin_cava
  • 1954
« Reply #7 on: September 03, 2011, 04:33:34 am »
I've got a cluster, it's from a 2002 5spees but it will work, pM if your interested
Catlin
Reply #8September 03, 2011, 07:58:39 am
« Reply #8 on: September 03, 2011, 07:58:39 am »
sadly swapping clusters also issue due to alarm.. will have to be reset via stealership unless you send comp to get it defeated.. comp, key cluster are its 3 main parts..
Reply #9September 04, 2011, 03:32:14 pm
motomike33y
  • 190
« Reply #9 on: September 04, 2011, 03:32:14 pm »
thats what I was noticing on some of the threads about the immobilizer, but it seemed that I could reset the key using vag-com, unless I misunderstood(and if I had a vag-com).  That also was why I wondered if there is a way to test the current cluster, before trying to replace it.  Not making any radical changes until I learn more.
2012 golf tdi
