Author Topic: track times  (Read 23603 times)
Reply #30September 21, 2011, 03:14:14 pm
Re: track times
« Reply #30 on: September 21, 2011, 03:14:14 pm »
power wise? idk, not much if you can hook the power to the ground..
200-250 ft lbs maybe?
Reply #31September 21, 2011, 05:51:03 pm
Re: track times
« Reply #31 on: September 21, 2011, 05:51:03 pm »
i think that is about the range, the lower rpm they make power, the more they fail.  they are stronger than most people act like they are tho.
Reply #32September 21, 2011, 10:55:00 pm
RadoTD
  • 513
    Stage WTF
Re: track times
« Reply #32 on: September 21, 2011, 10:55:00 pm »
i still have a governor. its called pump rollers skipping. lol.
my motor still only pulls to a certain RPM, even in neutral. doesnt turn scary revs.. prolly ~6000...
You've got more balls than I do! :P
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #33September 22, 2011, 08:49:21 am
Re: track times
« Reply #33 on: September 22, 2011, 08:49:21 am »
dude, andy2 used a cummins P pump. they are capable of fueling a motor enough that it can spin to bits..
a 1.6 gasser will happily spin 8k rpms.. these bottom ends are VERY SIMILAR to the gasser 1.6, aside from the much tougher pistons..
these motors are pump limited, not bottom end limited..
Reply #34September 22, 2011, 09:14:10 am
nathan_b
  • 361
Re: track times
« Reply #34 on: September 22, 2011, 09:14:10 am »
up in tire smoke?
yup, it would just blow the tires off. 2nd gear, you gotta let off to shift in my car.
they make race slicks for problems like this
i like the way you think!
my transmission, however, does not. lmao..
i want to find some small slicks for my car and put it on the strip before winter gets here.
a great friend of mine has a turbo del sol, for 1/8 mile drag racing we used to do, we had 12" slicks ;D
Reply #35September 22, 2011, 09:36:45 am
Re: track times
« Reply #35 on: September 22, 2011, 09:36:45 am »
up in tire smoke?
surely there 12" wide, not 12" tall?
Reply #36September 23, 2011, 01:27:29 pm
bgbmxer
  • 107
Re: track times
« Reply #36 on: September 23, 2011, 01:27:29 pm »
up in tire smoke?
they make plenty of 13 and 14 inch slicks out there
Reply #37September 23, 2011, 05:20:16 pm
Re: track times
« Reply #37 on: September 23, 2011, 05:20:16 pm »
thats how i always see it, the valve train can handle it no problem, rods are a little heavier but that is all on the bottom end.  the only thing i think that makes it hard to rev them high(aside from being diesel) is the high compression.
Reply #38September 23, 2011, 05:36:56 pm
bgbmxer
  • 107
Re: track times
« Reply #38 on: September 23, 2011, 05:36:56 pm »
once i get this clutch in were going to have to make a trip to south mountian or cecil and run this thing
Reply #39September 25, 2011, 10:39:29 am
Re: track times
« Reply #39 on: September 25, 2011, 10:39:29 am »
hey thats a good idea, i bet adam will want to take his gti and my brother will probably want to run his corrado, i'll  run my rabbit for s&g's
Reply #40September 27, 2011, 09:01:59 pm
MJF
  • 581
Re: track times
« Reply #40 on: September 27, 2011, 09:01:59 pm »
1/4 mile 14,40@91,5mph and 1,93 60 feet. Audi 80 1,9 idi, K14-2@24psi boost
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #41September 28, 2011, 06:45:29 pm
bgbmxer
  • 107
Re: track times
« Reply #41 on: September 28, 2011, 06:45:29 pm »
nice what mods?
Reply #42September 29, 2011, 04:06:00 am
MJF
  • 581
Re: track times
« Reply #42 on: September 29, 2011, 04:06:00 am »
A little ported head, 1Y intake, 10mm pump and 3" exhaust. Nothing that special.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #43September 29, 2011, 11:09:27 am
nathan_b
  • 361
Re: track times
« Reply #43 on: September 29, 2011, 11:09:27 am »
up in tire smoke?
12" tall
Reply #44September 29, 2011, 04:37:39 pm
Re: track times
« Reply #44 on: September 29, 2011, 04:37:39 pm »
what did you use, like an 8" wheel?
i seriously have a hard time picturing a 12" slick. lol.. that would make a car look soo goofy!
