Author Topic: track times  (Read 24327 times)
Reply #15September 11, 2011, 05:18:14 pm
Powered by Spearco
  • 1203
Re: track times
« Reply #15 on: September 11, 2011, 05:18:14 pm »
Todays best and best with this setup,
R/T .048
60' 2.488
330 6.807
1/8 10.214
MPH 71.41
1000 13.185
1/4 15.645
MPH 91.96
I really gave her hell at the launch this go.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #16September 12, 2011, 07:37:27 am
Re: track times
« Reply #16 on: September 12, 2011, 07:37:27 am »
like we were talking, you need more air to burn all that fuel you got from master Giles..
and that turbo you have on there sounds pretty big.. it was barely whistling, even after those few throttle blips..
how much boost do you make in first gear? and how late does the turbo come on? around what RPM?
didnt you say it comes on pretty good around 4 grand?
Reply #17September 12, 2011, 08:25:15 am
Powered by Spearco
  • 1203
Re: track times
« Reply #17 on: September 12, 2011, 08:25:15 am »
In first gear, I rev it to 5K and by the time I look at the gauge, it reads maybe 7 psi.
By the time I'm in second gear, its at 0 psi and its got to start building boost all over again. But once I see 3k rpm its starting to build and by 3700 its at 10 psi and climbing fast to 20-25 psi but once again, in the higher rpms, its to small and over spooling. From second to third gear, theres maybe a 10 psi drop and is really pulling hard till it chocks out.
Oh well, it is what it is. Even with NOS, its still has all the fuel I would ever need.
I'm looking for a VNT1756VB or a GTB VNT turbo.
'13 Golf R:. Tuned
'98 Puch G320
Reply #18September 12, 2011, 08:29:29 am
Powered by Spearco
  • 1203
Re: track times
« Reply #18 on: September 12, 2011, 08:29:29 am »
Its that lightened FW that I put in there. Stupid, stupid, stupid.
Great for street with a K14 or the like but for drag racing, nah.
'13 Golf R:. Tuned
'98 Puch G320
Reply #19September 12, 2011, 08:34:27 am
Re: track times
« Reply #19 on: September 12, 2011, 08:34:27 am »
 :o :o :o :o
HOLY CRAP!!! you got some lag.. i make full boost in all gears, and boost drops about 2-3 psi between shifts.. then power down again and the boost is right back.. you really need a VNT buddy..
would have you pulling alot lower in the RPM range.. along with the regular weight flywheel.. i used a light flywheel once, and hated it. car was doggy off the bottom.
5 grand, im making 7 psi in neutral..
kinda hard to compare a regular turbo to a VNT turbo tho..
i still think the truck is awesome tho!  8)
(TOTAL SLEEPER STATUS)
Reply #20September 13, 2011, 05:07:11 pm
Re: track times
« Reply #20 on: September 13, 2011, 05:07:11 pm »
awesome i knew there was some more quickness hiding in that car, i bet there is more yet.  its a shame the turbo is spooling too late for you, the compressor map is beautiful for a 1.6, but perhaps that turbine is just too big, or maybe your wastegate is leaking some?  the next size down for a turbine housing is .36 a/r which is stock vw t3 size, dunno how to tell if that would help or not, they make turbine maps too but i'm not really sure how to interpret them, have u considered talking numbers with a professional turbo shop?  vnt 17 would be an awesome turbo for a 1.6, but with what seems to be your power goals i don't think it is big enough.
Reply #21September 19, 2011, 07:18:00 pm
bgbmxer
  • 107
Re: track times
« Reply #21 on: September 19, 2011, 07:18:00 pm »
what mods are done to the head? what intake and exhaust mani also?
 and how are you shifting? in my other cars i never lift when i shift at the track. period.  kick the clutch and slam the next gear. yes its not much of a difference but a tenth at the start is about a second on the big end.
« Last Edit: September 19, 2011, 07:31:19 pm by bgbmxer »
Reply #22September 20, 2011, 11:07:19 am
Re: track times
« Reply #22 on: September 20, 2011, 11:07:19 am »
if you race shifted 2nd, or 3rd in my car, you would go up in smoke. it would take time away..
Reply #23September 20, 2011, 04:53:15 pm
Re: track times
« Reply #23 on: September 20, 2011, 04:53:15 pm »
up in tire smoke?
Reply #24September 20, 2011, 04:57:56 pm
Re: track times
« Reply #24 on: September 20, 2011, 04:57:56 pm »
up in tire smoke?
yup, it would just blow the tires off. 2nd gear, you gotta let off to shift in my car.
Reply #25September 20, 2011, 06:52:32 pm
bgbmxer
  • 107
Re: track times
« Reply #25 on: September 20, 2011, 06:52:32 pm »
up in tire smoke?
they make race slicks for problems like this
Reply #26September 20, 2011, 06:59:31 pm
Re: track times
« Reply #26 on: September 20, 2011, 06:59:31 pm »
up in tire smoke?
i like the way you think!
my transmission, however, does not. lmao..
i want to find some small slicks for my car and put it on the strip before winter gets here.
Reply #27September 20, 2011, 07:11:01 pm
RadoTD
  • 513
    Stage WTF
Re: track times
« Reply #27 on: September 20, 2011, 07:11:01 pm »
Even aside from the tire/transmission problem, you're already at 5000rpm and full boost in 2nd and 3rd gear. Not sure what PBS's governor spring is doing exactly, but in that 1/10s, you could hit some pretty high rev's, and that's not even taking into account what would happen in a missed shift...
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #28September 20, 2011, 07:19:54 pm
Re: track times
« Reply #28 on: September 20, 2011, 07:19:54 pm »
i still have a governor. its called pump rollers skipping. lol.
my motor still only pulls to a certain RPM, even in neutral. doesnt turn scary revs.. prolly ~6000...
Reply #29September 21, 2011, 03:10:30 pm
bgbmxer
  • 107
Re: track times
« Reply #29 on: September 21, 2011, 03:10:30 pm »
up in tire smoke?
they make them. what are these transmissions good for power wise
