Author Topic: Water/Meth injector mounting location  (Read 5967 times)
July 01, 2011, 09:58:21 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« on: July 01, 2011, 09:58:21 pm »
Whats up guys? Ive been thinking about water injection lately cause when i finally get my engine built (which i hope will be in the next month) the engine will be over fueled by alot and thats just how i like it...  8)
Here is the kit im going to buy.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=120687968243&viewitem=&sspagename=STRK%3AMEWAX%3AIT#ht_2463wt_840
But anyways here is where im going to mount the injector, where the flat spot is in the picture on the manifold.
what do you think? To much water in both middle cylinders and not enough in the 2 outer?
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #1July 01, 2011, 10:07:52 pm
Re: Water/Meth injector mounting location
« Reply #1 on: July 01, 2011, 10:07:52 pm »
i know it seems like it will bias the two center cylinders.. but those two outer cylinders still draw in air, and if there is a mist of water in that air its gonna draw it in with it as well, so I can't see any problems.
I suppose it depends on how fine a mist you use.
Reply #2July 02, 2011, 06:50:06 am
camboscams
  • 324
« Reply #2 on: July 02, 2011, 06:50:06 am »
Thats a really sweet kit for the price i'd be curious to how it holds up and how it runs too! If it works good thats really affordable!
I'm down on the nozzle location, like eight valve said its gonna draw the mist/vapor in regardless, the onle way around it would be to do two nozzles one above each pair of cylinders, or if you were to move it closer to the turbo but then you risk the moisture falling out of suspension but there's only one way to find out!
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #3July 02, 2011, 09:28:55 am
« Reply #3 on: July 02, 2011, 09:28:55 am »
haha how about this setup
Reply #4July 02, 2011, 11:23:41 am
« Reply #4 on: July 02, 2011, 11:23:41 am »
the stock manifold biases the 2 center cylinders bad.. i wouldnt shoot it right there.. its aiming straight to the intake ports for cyls 2 & 3.. sure 1 & 4 are still gonna get some meth, but probably less than half of what the inner cylinders get..
Reply #5July 02, 2011, 11:30:07 am
dankcorey22
  • 379
    Cummins!
« Reply #5 on: July 02, 2011, 11:30:07 am »
Well I think shooting it right there will be fine. People says one thing and others say different...  i just know I wouldn't shoot it into the compressor because ive seen where that wears on the compressor blades.
Reply #6July 02, 2011, 11:38:51 am
« Reply #6 on: July 02, 2011, 11:38:51 am »
if your gonna put it there anyways, why would you even ask our opinions?
ive blown up an engine because of the stock turbo manifold.. i know what it does..
when the head bolt holes around cylinders 2 & 3 have more cracks than the rest, you tell me what its from?
peak cylinder pressures too high? YUP..
biasing of the center cylinders? YUP..
blistered pistons in the outter cyls? YUP..
idk man, do what you want.. but ive seen the destruction these intake manifolds cause when you ask them to do too much..
its your engine, not mine. do with it what you want.
i just know that i DO NOT run the stock TD manifolds anymore.
(the people who say that it doesnt bias the cylinders bad, have never had engine problems caused from cylinder biasing)
i, on the other hand, had an engine go boom, and the outter cylinders definitely do get alot hotter..
so, like i say, its your call, im just providing the factual evidence that the stock intake does bias the center cyls REALLY BAD..
Reply #7July 02, 2011, 11:46:21 am
dankcorey22
  • 379
    Cummins!
« Reply #7 on: July 02, 2011, 11:46:21 am »
Wheres a good place to mount the nozzle Using td manifold without doing it  pre turbo? I believe you now since you have proof not to place it there.
Reply #8July 02, 2011, 12:11:22 pm
« Reply #8 on: July 02, 2011, 12:11:22 pm »
can you weld?
a modification to your stock intake will make it feed the cylinders even..
1. cut the top of the plenum off
2. extend plenum a bit to clear everything
3. take 2" pipe, cut a slit in the bottom
4. weld it all together.
now you effectively have a passenger performance style intake manifold!
is your turbo still mounted up high on a stock exhaust manifold?
since my turbo hangs down low, i have enough room that i can run a stock mk2 gas intake manifold.. the nice thing about the gasser intake is the nice long ports, and it has an actual plenum that wont bias the cylinders.
and you are going to want your meth to be injected before the intake anyways, like 8-10 inches away, so it can get more of a chance to mix..
are you running intercooled, or just stock? because it would be kinda hard to go 8-10 inches away from the intake mani if its just got the single 90* fitting from the turbo to the engine..
Reply #9July 02, 2011, 12:21:45 pm
dankcorey22
  • 379
    Cummins!
« Reply #9 on: July 02, 2011, 12:21:45 pm »
can you weld?
Yes I can weld got a mig and stick. No tig:/
I'm not really sure what you mean about cutting and welding on the intake.
I am running stock without IC just one 90 degree rubber bend.
Still turbo is up high
Reply #10July 02, 2011, 12:48:19 pm
« Reply #10 on: July 02, 2011, 12:48:19 pm »
do you know what a passenger performance intake looks like? it uses the bottom half of a stock TD intake.. just the intake runner section, and bottom of the stock plenum..
i dont have, nor can i find, a picture.
where the cast elbow bolts on, the part you wanted to shoot meth into, that mounts to the top of the plenum.
you cut the top of the plenum off, so that the intake has an open top, basically a 2"x12" hole into the manifold..
cut/bend pieces of aluminum to extend plenum upwards towards hood a bit (3-4")
fit a chunk of pipe, with a capped end, and a slit in the bottom..
weld it all together..
Reply #11July 02, 2011, 08:24:04 pm
AudiVWguy
« Reply #11 on: July 02, 2011, 08:24:04 pm »
I agree on the MK2 intake manifold, great design. Consider using something other than Meth. It has a very high Octane rating. Opposite of what diesels like. Nothing beats water at removing heat. Look into adding isopropyl Alcohol (25-50%) mixture, it helps atomize the droplets finer. This way also allows for a small pre-turbo nozzle  in addition to the nozzle that should be a few inches to mix with the air better before entering the intake manifold. There's a ton of info out there spend a few weeks reading and make your own educated decision.
Just my 2 cents.
Cheers,
-JB
Reply #12July 02, 2011, 08:53:30 pm
dankcorey22
  • 379
    Cummins!
« Reply #12 on: July 02, 2011, 08:53:30 pm »
Ahh... I know what your talking about now! Thats quite a bit of work.
What do yall think about pre-turbo?
Ive heard and saw negitive thing come from that but its long term effects.
Reply #13July 03, 2011, 12:05:18 am
« Reply #13 on: July 03, 2011, 12:05:18 am »
i questions its effects.  atomization can not be beat.  surely its possible it errodes the inlet wheel, but i wanna see evidence of it and i will probabaly be proven wrong easily with a google search.  but thats fine as i am not conceited or anything
Reply #14July 03, 2011, 07:50:10 am
« Reply #14 on: July 03, 2011, 07:50:10 am »
i imagine its long LONG term effects.. i dont think you will see the tips of your wheel wearing away after a few weeks, or months for that matter.
