Author Topic: Headgasket still weeps, front of engine.  (Read 8077 times)
May 16, 2011, 02:08:57 pm
« on: May 16, 2011, 02:08:57 pm »
I just put a new head gasket in. 2 hole like was on the car before.. Had no time to pull, measure, then order. Its been about 1200kms but its weeping in between the head and block again... Stock HG, Stock head bolts. All OEM. Torqued to xx then half turn.. Could they use a bit more??
I mean does this usually happen?
Reply #1May 16, 2011, 02:22:53 pm
Re: Headgasket still weeps, front of engine.
« Reply #1 on: May 16, 2011, 02:22:53 pm »
at the oil drain? or is it weeping coolant?
i always put silicone around all the oil drain holes.
Reply #2May 16, 2011, 02:39:56 pm
« Reply #2 on: May 16, 2011, 02:39:56 pm »
I just installed the new one because it took out my clutch in its path...
It leaks oil, it appears to be leaking all along the front of the engine.. Pain in my rear!
Reply #3May 16, 2011, 04:20:48 pm
Luckypabst
  • 502
« Reply #3 on: May 16, 2011, 04:20:48 pm »
I had a leaker there at the high pressure oil passage. When I replaced the HG, I put a tiny bit of RTV on each side of the O-ring that's part of the head gasket. No problem since then...
Chris
'82 TD Westy
'81 NA Caddy
Reply #4May 16, 2011, 06:14:49 pm
« Reply #4 on: May 16, 2011, 06:14:49 pm »
Gonna need a new Headgasket, bolts, coolant, and oil then :(
sunuvabish. Thats a severe pain in my ass. #$#@!%!^
Reply #5May 16, 2011, 06:42:37 pm
Quantum TD
  • 1195
« Reply #5 on: May 16, 2011, 06:42:37 pm »
Every one I've ever owned has leaked there. I just let it accumulate, and then powerwash it off every 6-10 months. No harm, no foul.
Reply #6May 16, 2011, 06:56:41 pm
« Reply #6 on: May 16, 2011, 06:56:41 pm »
Ahh, honestly I could care less of the oil leak.. other than the fact it toasted my last clutch disk (200mm solid Beetle disk) because it got in there and fouled everything up.. I fear it will do the same again.. I have a rag stuffed down in there to stop it from gathering behind the vacuum pump and leaking down in my bell-housing.
Reply #7May 16, 2011, 07:30:30 pm
wdkingery
  • 494
« Reply #7 on: May 16, 2011, 07:30:30 pm »
ouch that hurts. i hope you get that ironed out
Reply #8May 16, 2011, 08:22:36 pm
« Reply #8 on: May 16, 2011, 08:22:36 pm »
If this clutch starts to slip, I'm gonna light the engine on fire.. outside of the car of course.. couldn't burn up my 84 lmao.
Reply #9May 17, 2011, 07:46:39 am
« Reply #9 on: May 17, 2011, 07:46:39 am »
are you POSITIVE that its not a valve cover gasket?
ive had those things make some funky leaks too.
Reply #10May 22, 2011, 11:32:34 am
« Reply #10 on: May 22, 2011, 11:32:34 am »
Leak still persists. And now I'm loosing coolant too.. $#@%.
Actually here is whats interesting, the past two days being parked in the garghe with a board under it have shown quite a big puddle of thick black oil dropped.. Yet the oil level is just where it is supposed to be (if not a tad higher than the crosshatch) from when I did an oil change with the HG early may. I did however put in 15w40 Rotella T6 Triple Protection.. which i believe is synthetic.. Causing some of my problems maybe?
I used a OEM Victor Reinz head gasket, and OEM 12mm headbolts. Torqued up to whatever, and the additional half turn. Do these require the aditional retorque after a bit? Can it be done? should it? Can it help me out?
I wouldnt be so worried if it were JUST loosing oil, and i could keep adding it.. but its dumping right behind my vacuum pump and I fear it will destroy my brand new clutch AGAIN.
I are needing your assitances. :D
Reply #11May 22, 2011, 11:36:59 am
« Reply #11 on: May 22, 2011, 11:36:59 am »
FWIW, i havent had such good luck with victor reinz gaskets.. i prefer the fel-pro print-o-seal gaskets.. they have silicone around all the important passages right from the factory..
Reply #12May 22, 2011, 11:47:52 am
« Reply #12 on: May 22, 2011, 11:47:52 am »
Do the Fel-Pro's have like an orange ring around vital passages?
I do believe the VR gasket I bought had this as well. I shoulda siliconed it... sumbish.
Reply #13May 22, 2011, 11:50:54 am
« Reply #13 on: May 22, 2011, 11:50:54 am »
yea, reddish orange ring of sealant around everything important..
and a ring all the way around the edge of the gasket.
Reply #14May 22, 2011, 12:02:15 pm
« Reply #14 on: May 22, 2011, 12:02:15 pm »
Pretty sure my VR had this... Dunno.
Can I retorque?
