Author Topic: Headgasket still weeps, front of engine.  (Read 8112 times)
Reply #30May 23, 2011, 07:28:29 pm
Re: Headgasket still weeps, front of engine.
« Reply #30 on: May 23, 2011, 07:28:29 pm »
Yes, I am working on a hydro motor.
I agree ARP is the way to go, but am not entirely sure this motor will be in the car much longer. I am thinking TDI to this car.. OR taking the T bits from the TDI and putting them on my 1.6 for now??
Its up in the air..
BUT yes to the warm half-turn??
Reply #31May 23, 2011, 07:47:41 pm
Luckypabst
  • 502
« Reply #31 on: May 23, 2011, 07:47:41 pm »
My book gives that as the sequence for the triple square head bolts (somewhat different for the older socket-head bolts). I understand it to be specific to head bolt type and not whether it's a mechanical or hydro head.
Chris
'82 TD Westy
'81 NA Caddy
Reply #32May 23, 2011, 07:57:45 pm
« Reply #32 on: May 23, 2011, 07:57:45 pm »
Ok, head bolt specific. I have the 12mm triple square.
Warm 1/2 turn is good then?
Reply #33May 23, 2011, 08:03:50 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #33 on: May 23, 2011, 08:03:50 pm »
Chris
this is also my understanding. IIRC (no book here right now) the triple square bolts do not require a retorque after 1k miles. Only the 6pt bolt do. FWIW, I have ARPs on my car and it leaks. FML.
Reply #34May 23, 2011, 08:11:18 pm
Luckypabst
  • 502
« Reply #34 on: May 23, 2011, 08:11:18 pm »
Triple square do require 1k mile retorque. Let's not let this get into a confusing mess. What I posted earlier was direct from the Bentley.
To 8VOF: I would give it that extra half turn. I think that as long as you aren't seeing any combustion pressure into the coolant, you should be OK on the gasket seal. Half turn in one continuous motion is a bit much. If you have to break it up into smaller turns, I'd probably do (2) quarter turns, each in a smooth, continuous motion as the Bentley requires, while following the standard torque procedure between each quarter turn.
Chris
'82 TD Westy
'81 NA Caddy
Reply #35May 23, 2011, 08:16:47 pm
Powered by Spearco
  • 1203
« Reply #35 on: May 23, 2011, 08:16:47 pm »
The book right here says, MF and ME require an additional 1/2 turn at 1k miles.
Also, I thought that all hydro heads have triple square bolts anyways.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #36May 23, 2011, 08:34:04 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #36 on: May 23, 2011, 08:34:04 pm »
Not trying to at all. Thanks for the clarification :thumbup:
Reply #37May 23, 2011, 10:38:11 pm
Luckypabst
  • 502
« Reply #37 on: May 23, 2011, 10:38:11 pm »
Apologies if that came across even remotely rude  8)
'82 TD Westy
'81 NA Caddy
Reply #38May 24, 2011, 10:11:05 am
« Reply #38 on: May 24, 2011, 10:11:05 am »
Chris
6pt bolts require a re-torque because they are re-useable non-stretch bolts.. 1.5, and early 1.6Ds were the engines to come with these bolts..
