Author Topic: ive got a small fountain for a dipstick (video)  (Read 20106 times)
April 16, 2011, 03:25:00 pm
wdkingery
  • 494
« on: April 16, 2011, 03:25:00 pm »
if i pull my dipstick @ idle, its got a small geyser effect! not flying out, but rolling out. drips  per second. are my rings that bad considerin im averagin 43 a gallon? or is it possible theres another issue?
http://youtu.be/cbu9kwAztmA?hd=1
<iframe width="1280" height="750" src="http://www.youtube.com/embed/cbu9kwAztmA?hd=1" frameborder="0" allowfullscreen></iframe>
« Last Edit: June 12, 2011, 09:33:21 pm by wdkingery »
Reply #1April 16, 2011, 05:13:49 pm
Re: ive got a small fountain for a dipstick
« Reply #1 on: April 16, 2011, 05:13:49 pm »
i think i would look at a plugged breather hose or something like that..
Reply #2April 16, 2011, 05:41:16 pm
maxfax
  • 2126
« Reply #2 on: April 16, 2011, 05:41:16 pm »
X2, and also check your vacuum system for leaks..   The vac pump exhausts into the crankcase..  IF it's sucking extra air in, it's pumping extra air into the crankcase...
Reply #3April 16, 2011, 05:43:19 pm
« Reply #3 on: April 16, 2011, 05:43:19 pm »
yup, check the vac pump too. shouldnt have much of an exhaust..
Reply #4April 16, 2011, 06:07:07 pm
wdkingery
  • 494
« Reply #4 on: April 16, 2011, 06:07:07 pm »
guys thanks for the insight! im fairly certain i have a vaccum leak, as i can head the brake booster "bleed" down  after i turn the engine off, and i defnitely have a hard pedal unless the car us runnin.. hmm ill have to check around! thanks im glad its not "the other thing" haha.  and its really a problem because you cant even get near the dipstick without gettin terribly nasty, and i cannot park in the driveway not even for a second. i think its the brake booster. is the gasser from an 88 the same? any gasser?
Reply #5April 16, 2011, 07:39:20 pm
wdkingery
  • 494
« Reply #5 on: April 16, 2011, 07:39:20 pm »
the mesh in the valve cover? what is the mesh? when i take the 8 nuts off and lift  the cover, i just see a cam with caps and rockers..  where's the mesh?
Reply #6April 16, 2011, 07:46:08 pm
« Reply #6 on: April 16, 2011, 07:46:08 pm »
In the cover. Flip her over and check the hole covered with the mesh lol
Reply #7April 16, 2011, 07:54:08 pm
wdkingery
  • 494
« Reply #7 on: April 16, 2011, 07:54:08 pm »
i can stick my finger straight thru that hole?
Reply #8April 16, 2011, 07:57:49 pm
« Reply #8 on: April 16, 2011, 07:57:49 pm »
well it shouldn't be plugged then.
Reply #9April 17, 2011, 08:04:53 am
« Reply #9 on: April 17, 2011, 08:04:53 am »
what kinda car do you have? a mk2? if you have a mk2 car, then the booster off the gasser should work..
Reply #10April 17, 2011, 08:11:26 am
wdkingery
  • 494
« Reply #10 on: April 17, 2011, 08:11:26 am »
thanks flossy! it's an mkII (as evidenced by my sweet aaz fuelly in my sig!) yeah i'ma shoot out and get that booster from the 88 gasser today.. but i really need to figure out where the vac leak is before i spend any more money i don't have..
Reply #11April 17, 2011, 08:14:14 am
« Reply #11 on: April 17, 2011, 08:14:14 am »
the brake booster is about the only thing that uses vacuum.. the heater switch might too, but i doubt it. usually the diesels got cable operated heaters..
Reply #12April 17, 2011, 08:23:10 am
wdkingery
  • 494
« Reply #12 on: April 17, 2011, 08:23:10 am »
yeah but i might have a boogered up line runnin the the booster.
and when i flip my vent lever i hear vacuum so i think it's a candidate but .. i don't think it's got a big enough leak to geyser my dipstick
Reply #13April 17, 2011, 08:50:39 am
« Reply #13 on: April 17, 2011, 08:50:39 am »
wow, you got a vacuum operated heater then.. thats kinda weird..
and usually if you have a bad hose to the booster, it usually doesnt feel like its working very much..
Reply #14April 17, 2011, 03:07:36 pm
« Reply #14 on: April 17, 2011, 03:07:36 pm »
A/C cars use vacuum HVAC controls. Block the nipple off at the vacuum pump and see if that solves your problems
