Downpipe choices AAZ in MK1
Pages:
Topic: Downpipe choices AAZ in MK1 (Read 10783 times)
Reply #15
March 08, 2011, 04:04:29 pm
Re: Downpipe choices AAZ in MK1
Reply #15 on:
March 08, 2011, 04:04:29 pm »
The exhaust outlet side of the K03 turbo is a different shape (rectangular) than the other turbos VW used.. K14, T2, T3, which have a square outlet.
Based on the pictures that I saw the AAZ TT downpipe is expecting the K14 turbo with its square outlet. Certainly worth confirming before you order.
This thread starts with a picture of the K03 rectangular outlet:
http://www.vwdiesel.net/forum/index.php?topic=25854.0
Whereas about 2/3 of the way down this thread you'll see a side view of the K14 square outlet:
http://forums.vwvortex.com/showthread.php?4726902
Last Edit: March 08, 2011, 04:10:10 pm by Vincent Waldon
Reply #16
March 08, 2011, 04:10:29 pm
erice1984
Reply #16 on:
March 08, 2011, 04:10:29 pm »
ah, okay. Damn.
That flange reminds me of the ones on Subaru turbos.
Is it as simple as grabbing up a different turbo? or are the intake manifold and exhaust manifold diff as well?
1980 Rabbit 1.9TD
Reply #17
March 08, 2011, 04:58:26 pm
Reply #17 on:
March 08, 2011, 04:58:26 pm »
Intake's the same, but the K14 uses a different exhaust manifold (same one as the T2/T3/K24) and probably different oil lines as well...perhaps someone else will chime in.
Unfortunately you really did get the odd ball turbo.
Reply #18
March 08, 2011, 05:02:15 pm
erice1984
Reply #18 on:
March 08, 2011, 05:02:15 pm »
Maybe I will work with it until it craps out on me or something. It does have the down pipe with it.
1980 Rabbit 1.9TD
Reply #19
March 08, 2011, 05:04:12 pm
Reply #19 on:
March 08, 2011, 05:04:12 pm »
Quote from: erice1984 on March 08, 2011, 05:02:15 pm
Sounds like a plan... lotta work to shift to a different turbo, and you should be able to find a muffler shop that can work with your existing downpipe?
Reply #20
March 08, 2011, 05:05:47 pm
erice1984
Reply #20 on:
March 08, 2011, 05:05:47 pm »
If the stock down pipe will fit in the rabbit (mk1) then the rest of the exhaust could be attached to it no problem.
1980 Rabbit 1.9TD
Reply #21
March 08, 2011, 05:22:49 pm
GEE-BEE
Reply #21 on:
March 08, 2011, 05:22:49 pm »
Correct, just a rear muffler is needed
To change to a different turbo:
intake manifold will change
intake snorkel is different 1.85 KO3 , K14 is 2.33 I.d.
( I make both snorkel's and Turbo Duct's )
turbo to intake manifold duct is different
Downpipe is different
Good Luck
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Pages:
