Author Topic: main diferences between 1y and azz ?  (Read 17992 times)
Reply #15March 06, 2011, 02:33:21 pm
MJF
  • 581
Re: main diferences between 1y and azz ?
« Reply #15 on: March 06, 2011, 02:33:21 pm »
Use AAZ or Tdi con rod bearings and you'll be fine. I'm now running about 180hp/350nm, no worries. It's AEF, same internals as 1Y.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #16March 07, 2011, 02:34:53 am
ibizz
  • 57
« Reply #16 on: March 07, 2011, 02:34:53 am »
its possible to use con rods from aaz or tdi in 1y rods?
you ive it in your setup ?
witch pump is beter aaz one ore gtd one ?
Reply #17March 07, 2011, 05:24:52 am
carrizog60
  • 978
« Reply #17 on: March 07, 2011, 05:24:52 am »
i have done that,in a passat 35i.
gt2052v turbo boosting at 1 bar for now,1Y intake manifold,60mm stainless exhaust,gtd pump.
still need more fuel as the big turbo and better manifold clears all the fuel smoke only at one bar...
Portugal
Reply #18March 07, 2011, 05:33:21 am
« Reply #18 on: March 07, 2011, 05:33:21 am »
Exactly what I wanted to hear...I am buying a 2256vk as soon as I get the cash from the engine sale :D Giles will get you all the fuel you want...trust me.
Reply #19March 07, 2011, 06:35:15 am
ibizz
  • 57
« Reply #19 on: March 07, 2011, 06:35:15 am »
hey macka
manny 1y engines around here
they came out in seat ibiza, caddy , cordoba , wv golfs , ventos , passat and others ..
so manny engines around here
Reply #20March 07, 2011, 06:37:16 am
ibizz
  • 57
« Reply #20 on: March 07, 2011, 06:37:16 am »
hey carrizog60
the turbo dont strungle with 1y admission colectors?
witch exaust colectors did you use ?
thanks for ani outputs and help
Reply #21March 07, 2011, 06:56:16 am
MJF
  • 581
« Reply #21 on: March 07, 2011, 06:56:16 am »
You want to use 1Y intake manifold and AFN (110hp TDI) exhaust manifold? That's exactly what I am using now. EGR mount from exhaust manifold will hit intake, you need to grind it some.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #22March 07, 2011, 07:33:31 am
« Reply #22 on: March 07, 2011, 07:33:31 am »
hey carrizog60
how come your english was soo much better over on the vortex?
Reply #23March 07, 2011, 12:52:36 pm
ibizz
  • 57
« Reply #23 on: March 07, 2011, 12:52:36 pm »
eheh believe it or not
its becouse the demand of power LOL
i mean , its becouse writing it manny times this days
im kind of taking rust out of my ingles
im in portugal and im portuguese , not manny people to talk with and special write ingles .. if you understend me ..
Reply #24March 07, 2011, 12:59:52 pm
ibizz
  • 57
« Reply #24 on: March 07, 2011, 12:59:52 pm »
hey mjf
if its with egr , no problem for my 1y admission , becouse my car its from 94 its the last ones that came out without egr and cataliser
sound goods
Reply #25March 07, 2011, 01:57:14 pm
« Reply #25 on: March 07, 2011, 01:57:14 pm »
you are still doing pretty good.. dont get me wrong.
i would not be able to read or write portuguese at all.. hahaha.
Reply #26March 07, 2011, 02:02:15 pm
carrizog60
  • 978
« Reply #26 on: March 07, 2011, 02:02:15 pm »
hello
i used 1Y intake, but had it resurfaced with a bit of alge to help clear the exhaust.
did the same on the exhaust manifold.
the exhaust manifold is a 1.6gtd,but was cut and the exhaust side of turbo welded,because of lack of space.
on normal(bolt on) assembly the turbo will hit the firewall...
portuguese is not an easy language...
but i am smart and can speak,read and understand pretty good lolllll
um abraço da zona de aveiro ;)
Portugal
Reply #27March 07, 2011, 02:37:21 pm
ibizz
  • 57
« Reply #27 on: March 07, 2011, 02:37:21 pm »
my 1y dont ive egr so it must have more space
il use gttdi turbo and colectors , since is a litle turbo and dont ive egr may be its bolt in right without mood ?
Reply #28March 07, 2011, 10:44:52 pm
MJF
  • 581
« Reply #28 on: March 07, 2011, 10:44:52 pm »
Gttdi? What engine code? EGR is in exhaust manifold, I had to grind it to fit with 1Y intake.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #29March 08, 2011, 02:31:02 am
ibizz
  • 57
« Reply #29 on: March 08, 2011, 02:31:02 am »
mjf
seat ibiza gttdi 110 hp afn engine i think
since my model car dont ive egr and cataliser , the admission manifold must not ive that egr port on it , but i didnt see so far
becouse engine are running
did you already use the con rods from another engines in 1y rods ?
