Author Topic: main diferences between 1y and azz ?  (Read 17888 times)
Reply #30March 08, 2011, 03:00:54 am
ibizz
  • 57
Re: main diferences between 1y and azz ?
« Reply #30 on: March 08, 2011, 03:00:54 am »
i almost finish the body work this week
next its power build
i buy this car in very bad shape , rusty , with electric problems and manny others ..
i almost rebuild him complety , and make body tunning
preview
http://img194.imageshack.us/i/p1010319k.jpg/
« Last Edit: March 08, 2011, 05:21:41 am by ibizz »
Reply #31March 08, 2011, 03:08:26 am
MJF
  • 581
« Reply #31 on: March 08, 2011, 03:08:26 am »
AFN exhaust manifold has EGR port. You will have to make a plate to block it. And grind some material above the port. Otherwise it will hit 1Y intake manifold.
I have stock AEF (1Y) con rods and bearings. 1Y bearings are same as 1,6TD, these will be good at power levels you mentioned. But AAZ bearings are 1mm wider. AFN upper bearing is better material, these are the best. AAZ and AFN bearings will fit directly to 1Y con rod.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #32March 08, 2011, 03:26:08 am
ibizz
  • 57
« Reply #32 on: March 08, 2011, 03:26:08 am »
thanks friend
yes exaust colectors ive egr port , that must be close
but my admission manifolds dont ive that egr stuff that you guys cut , becouse car dont ive egr from factory
lets see if its plug and play ..
ive to start looking for a pump
witch best aaz or gtd ?
Reply #33March 09, 2011, 07:01:14 am
ibizz
  • 57
« Reply #33 on: March 09, 2011, 07:01:14 am »
its possible to know what stuff ive in engine , with engine number ?
and engine number is that sequence of numbers ending with j near injectors?
Reply #34March 09, 2011, 10:15:45 am
« Reply #34 on: March 09, 2011, 10:15:45 am »
the engine code is on the BLOCK.. not the head.. its right under the top water neck of the head, but still on the top edge of the block..
its a code that should start with a *
Reply #35March 10, 2011, 09:42:52 am
ibizz
  • 57
« Reply #35 on: March 10, 2011, 09:42:52 am »
i cant find it any here ..
and may engine bay its clean
but its possible to know what ive in engine by engine number ?
or just with code engine?
Reply #36March 10, 2011, 09:50:16 am
« Reply #36 on: March 10, 2011, 09:50:16 am »
what do you want to know? didnt we determine that you have a 1Y?
and whats an admissions collector? an exhaust manifold?
Reply #37March 10, 2011, 04:26:20 pm
ibizz
  • 57
« Reply #37 on: March 10, 2011, 04:26:20 pm »
exaust colectors = exaust manifold
admission colectors = admission manifold
yes i know its a 1y
Reply #38March 10, 2011, 04:31:01 pm
« Reply #38 on: March 10, 2011, 04:31:01 pm »
exhaust manifold, and intake manifold, how ever admissions manifold makes sense
Reply #39March 11, 2011, 08:50:19 am
« Reply #39 on: March 11, 2011, 08:50:19 am »
admission manifold? ive never even heard of such a thing.
Reply #40March 11, 2011, 08:58:53 am
galaboff
  • 60
« Reply #40 on: March 11, 2011, 08:58:53 am »
please someone post photo of that manifold  ???
Reply #41March 11, 2011, 09:18:03 am
« Reply #41 on: March 11, 2011, 09:18:03 am »
the one where the engine sucks in air?
or the one where exhaust comes out?
the turbo is driven by the exhaust manifold, and the boost is fed to the intake manifold..
no admissions manifold that i know of.. or atleast i dunno what manifold you are referring to..
im trying to find pictures of the manifolds tho..
Reply #42March 11, 2011, 09:39:21 am
« Reply #42 on: March 11, 2011, 09:39:21 am »
Exhaust Manifold:
picture just fore reference, yours may not be exactly the same..
Intake Manifold:
again,may not be exactly like yours, but close enough to get an idea..
Reply #43March 11, 2011, 02:07:22 pm
ibizz
  • 57
« Reply #43 on: March 11, 2011, 02:07:22 pm »
here call it admission colectors
and exaust colectors
but it exaust manifold
and intake manifold
that intake manifold is not like mine
mine its large like that one carrizog60 passat
same as 1y ive here
Reply #44March 11, 2011, 02:18:18 pm
« Reply #44 on: March 11, 2011, 02:18:18 pm »
oh crap, i forgot you have a n/a 1Y engine..
those are AAZ/TDI manifolds.. they are for turbo engines.
yes, your intake manifold would be much longer, and shaped just like a gasser intake manifold..
