Author Topic: MK1 Jetta Dash Install To MK1 Caddy  (Read 14479 times)
January 28, 2011, 05:37:17 pm
GEE-BEE
  • 1604
« on: January 28, 2011, 05:37:17 pm »
After cleaning out the a/c assy and duct's , I also added all new silicone foam on the vent door's
installing new blower fan assy and heater core assy ( 200.00 parts )
red silicone hose from heater to firewall
The shop did not have to use the jetta dash bracket's
Trevor ( member  )did a fine job on the cluster and installed the blue LED's and white meister gauge faces
All functions work !!!
The fan blower is much stronger and there is no rattles in this dash assy now that there dymat insulation and silicone foam on all attaching surfaces
Next will be a new Blaupunkt Stereo with DVD /CD function with  pop up dvd screen to finish
Gee-Bee
« Last Edit: January 29, 2011, 12:27:41 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1January 29, 2011, 05:04:06 am
BlastIt
  • 66
    • bigrblasting.com
Re: MK1 Jetta Dash Install To MK1 Caddy
« Reply #1 on: January 29, 2011, 05:04:06 am »
Gee Bee I would love to see some pics. I'm gonna do this to my caddy this summer so any tips or tricks you may have would be nice too.  You can send them to john at bigrblasting dot com   Thanks
Reply #2January 29, 2011, 05:47:11 am
« Reply #2 on: January 29, 2011, 05:47:11 am »
same foam you sent me? Do you have pics of how it went on. I think I put too much on mine, but can't pull the dash until summer time to find out. I still have little flow.
Reply #3January 29, 2011, 08:03:26 am
GEE-BEE
  • 1604
« Reply #3 on: January 29, 2011, 08:03:26 am »
I will send some pic's, I had a shop do the install while I went to japan and two islands in the Philipines
Boracay and Palawan
Water was  warm 78 and air temp was around 87
Great food and diving
For questions please contct Brad at Mesa West ( Costa Mesa Calif.)
His email is :[email protected]
( Ref: Dash Install )
The wiring was a problem as my truck was a gas and I had two get a MK1 diesel jetta cluster and add a tach, all functions work perfect now in the cluster.
If i did it again , I would do a diesel harness swap
Giles Pump OHC
MK1 JETTA DASH
Reply #4January 29, 2011, 12:09:56 pm
rallydiesel
  • 1880
« Reply #4 on: January 29, 2011, 12:09:56 pm »
You mean if you had someone else do it again.   ;)
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #5January 29, 2011, 02:43:01 pm
GEE-BEE
  • 1604
« Reply #5 on: January 29, 2011, 02:43:01 pm »
I was just saying that a diesel harness would have been much easier to deal with, I had to install a Bosch universal glow plug kit also and delete alot of wiring for this install.
gas to diesel
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #6January 30, 2011, 10:13:08 am
« Reply #6 on: January 30, 2011, 10:13:08 am »
Reply #7January 30, 2011, 10:20:29 am
GEE-BEE
  • 1604
« Reply #7 on: January 30, 2011, 10:20:29 am »
I spent some time cleaning, Nice work on the cluster Trev !
Installing new newton carpet kit in a few weeks...
Will be installing new CD/DVD stereo in the next few days
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #8January 30, 2011, 01:38:21 pm
« Reply #8 on: January 30, 2011, 01:38:21 pm »
thanks, no timing advance?
Reply #9January 30, 2011, 02:33:03 pm
GEE-BEE
  • 1604
« Reply #9 on: January 30, 2011, 02:33:03 pm »
What ?
Timing advance lever
not installed
Start's first turn with Bosch fast glow plug's and fast relay
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #10January 30, 2011, 03:45:00 pm
Powered by Spearco
  • 1203
« Reply #10 on: January 30, 2011, 03:45:00 pm »
GEE-BEE, if you don't mind, what did you pay in shipping for the carpet kit and who did you use for shipping?
There carpet kits and peices of kits are by far the best fitting and the colors match OEM carpets.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #11January 30, 2011, 03:47:47 pm
GEE-BEE
  • 1604
« Reply #11 on: January 30, 2011, 03:47:47 pm »
I havent heard, why do you one ?
they havent advised yet
we could ship two cheaper than one ?
Giles Pump OHC
MK1 JETTA DASH
Reply #12January 30, 2011, 06:30:29 pm
Powered by Spearco
  • 1203
« Reply #12 on: January 30, 2011, 06:30:29 pm »
I'm interested in the Scirocco rear parcel shelf carpet set, Biscuit color. I think they want $80 just for that. The last I time I contacted them via email, they make every order to order, so it would be a while. They also would'nt tell me who they use for shipping. Don't know why.
Aaron at Bleached Bora can get great shipping rates, but they won't use anyone but who they choose.
Let me know.
Thanks, Josh
'13 Golf R:. Tuned
'98 Puch G320
Reply #13February 05, 2011, 07:40:23 am
chopper03
  • 42
« Reply #13 on: February 05, 2011, 07:40:23 am »
GEE-BEE, What are your door panels from ?
Reply #14February 05, 2011, 08:45:41 am
GEE-BEE
  • 1604
« Reply #14 on: February 05, 2011, 08:45:41 am »
They were special order TMI for a Cabby, 3 hole door handle type with mirror hole
I added the early bug chrome door surround
cabby door pull's
cabby speaker grill's with Fogul speakers ( 300.00 )
Window crank's from rabbitparts.com
Nice fit & finish..
I found a new Blapunkt Chicago stereo with FM/CD/DVD with pop up screen , retails for 1100.00 new in the box for 200.00
« Last Edit: February 05, 2011, 08:47:56 am by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
