Author Topic: Rebuilt Pump, RUNS AWAY!  (Read 9016 times)
Reply #15August 01, 2010, 08:31:25 am
dankcorey22
  • 379
    Cummins!
    • Anything that runs
Re: Rebuilt Pump, RUNS AWAY!
« Reply #15 on: August 01, 2010, 08:31:25 am »
Well that's the first I've heard of flooding a diesel... how did you manage to get so much fuel into your TDI?
11 mm IP and big PP764 nozzles and a RC5 tune u guess, That what a guru told me i was doing when that happened
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #16August 01, 2010, 11:28:56 am
« Reply #16 on: August 01, 2010, 11:28:56 am »
Did you removed the pump head and plunger for the reseal ?
I removed the head in one piece if that makes sense. I didn't remove the plunger.
just to re-iterate, the head is on the back, with the 4 fuel lines exiting it. were you talking about the pump top? or the pump head?
its kinda hard to take the head out of the pump without taking the plunger with it..
Reply #17August 01, 2010, 11:41:30 am
« Reply #17 on: August 01, 2010, 11:41:30 am »
Can you explain this in more detail? Which sleeve? The sleeve from the centrifugal governor? Or the control collar "sleeve"? Fulcrum lever? I thought the max fuel screw acted as the fulcrum for the lever.
I am leaning towards the theory that I may have something incorrectly installed something related to the control collar which is why fuel delivery is taking place just fine but its just "wide open".
Sorry, the control collar sleeve is what I was talking about.
Fulcrum lever I was referring to the black piece that engages in the control collar and at the other end is pulled on by the governor assembly. It's held in by the 2 3 sided bolts.
If you take the top of the pump off you should be able to see if the collar is engaged properly, just wiggle the fulcrum lever back and forth
Reply #18August 01, 2010, 09:13:33 pm
kingler5
  • 43
« Reply #18 on: August 01, 2010, 09:13:33 pm »
Yes, I know the head is on the back. I meant I didn't purposely remove the plunger out of the head.
Slightly off topic, you know it's funny when I was putting back on the springs for the outside accelerator lever it only took me 2 minutes as opposed to 2 hours as it did the first time. You live and you learn. Now maybe if I could be as quick with drum brake springs.
I am going to pull the pump again to look at this. I know some have the guts to remove the top of the pump on the car, but I don't. Besides, I prefer working on the pump in a "laboratory" setting, i.e. indoors so if I need to actually pull the pump head again, I can do so at that moment.
Reply #19August 02, 2010, 10:17:38 am
« Reply #19 on: August 02, 2010, 10:17:38 am »
im still thinking that the fuel control collar is just spinning free on the plunger, stuck in one position. the little hitch ball on the end of the governor plate (fulcrum lever) sits in a hole on the control collar to control fuel. it has to move back and forth on the plunger shaft.
and please dont take things the wrong way. only reason i was saying about the pump top and head is because if you and vince are talking about a certain part, you might as well be talking about the same part. internet diagnosis is already sketchy at best, so why complicate things by potentially not being on the same page..
either way, pulling the pump top while the pump is on the engine is completely possible. ive done it many times. ive gotten pretty decent at it too. governor mods take ~30 mins now..
« Last Edit: August 02, 2010, 11:35:10 am by Rabbit on Roids »
Reply #20August 02, 2010, 10:43:52 am
Grey_Smoke
  • 83
    fling wing for the win.
« Reply #20 on: August 02, 2010, 10:43:52 am »
im still thinking that the fuel control collar is just spinning free on the plunger, stuck in one position. the little hitch ball on the end of the governor plate sits in a hole on the control collar to control fuel. it has to move back and forth on the plunger shaft.
There are people on here with much more experience than me, I think I might have had this problem, so here is what i did.
When I first did my pump, I got the hitch ball on the end of the governor plate down in front of the control collar, so it was stuck all the way open, I found the the easiest way to get it in the right place was to take a a putty knife, and hold the two springs back with it, then I could slide the governor plate in easily.  Hope that is helpful.
« Last Edit: August 02, 2010, 10:48:11 am by Grey_Smoke »
2001 TDI
86 Jetta Coupe TD - Still going together
sold - the Gutless wonder - 97 AAZ
An Oldvolks Home
Reply #21August 08, 2010, 04:38:26 am
kingler5
  • 43
« Reply #21 on: August 08, 2010, 04:38:26 am »
I fixed the control collar back to the control lever. Now, I have a new problem.
For some reason, after A TON of cranking, I am getting no fuel getting to my injectors, it wont even leak out when I loosen the lines at the delivery valves on the pump and crank it.
Already checked fuel cut solenoid, pulled it completely out to test it and it worked fine, do hear it clicking. No fuel is leaking out of the pump anywhere, it is sucking in fuel nicely, there are still a few air bubbles in the lines, but this thing used to start and run great even with the same amount of few residual bubbles.
What sort of error could I have made when putting the pump back together for the 2nd time that would cause there to be no fuel delivery?
I did take off the pump head last time, but it is secured down tight again as I said and there are no leaks.
FRUSTRATED!!!!
Reply #22August 08, 2010, 06:15:43 am
arnold
« Reply #22 on: August 08, 2010, 06:15:43 am »
Did you used the go pedal while cranking ? My bet : the max feul screw is out to far or maybe the throttle control lever is placed wrong.Or both...
Reply #23August 08, 2010, 06:25:07 am
kingler5
  • 43
« Reply #23 on: August 08, 2010, 06:25:07 am »
Yes I tried that. The max fuel screw is close to its original position, if not further in. The accelerator lever is placed correctly.
I don't see why any of that would cause no fuel coming out at the delivery valve.
Reply #24August 08, 2010, 08:04:59 am
arnold
« Reply #24 on: August 08, 2010, 08:04:59 am »
If the max feul is out to far it makes the control collar cover the hole in the plunjer completly,stopping feul from going in the pump head,try turning it in some more,every time i pulled the top of a pump i have to do adjustments on the max feul to get it running like before
Reply #25August 08, 2010, 02:19:21 pm
« Reply #25 on: August 08, 2010, 02:19:21 pm »
When you timed it did the dial indicator move normally?
Reply #26August 08, 2010, 03:32:43 pm
kingler5
  • 43
« Reply #26 on: August 08, 2010, 03:32:43 pm »
Yes. It is timed correctly at 1.0 mm.
The max fuel screw is screwed in as far as it will go with the factory collar on.
« Last Edit: August 08, 2010, 03:43:46 pm by kingler5 »
Reply #27August 14, 2010, 04:24:38 am
kingler5
  • 43
« Reply #27 on: August 14, 2010, 04:24:38 am »
I fixed the cause of my runaway, my control lever was indeed not seated in the control collar, and it could only bounce around at the hi-rev end, problem fixed, now I have a new problem.
Fuel will NOT come out of the delivery valves. My question is this: if there is a seal not quite tight enough, a couple of screws not tight enough, is it possible for the pump's internal pressure to to not be high enough to facilitate fuel coming out of the delivery valves? I thought the bulk of the fuel pressurization took place in the pump head with the action of the plunger? What is the normal internal pump pressure, and what is the breaking pressure of the delivery valves? Also what is the compression ratio, if you will, within the pump head?
Reply #28August 14, 2010, 02:15:20 pm
« Reply #28 on: August 14, 2010, 02:15:20 pm »
Did you take the delivery valves out at any time? (if yes, when)
How do you know you fixed the problem if the car does not run?
Is the collar on the right way?
Reply #29August 14, 2010, 08:55:30 pm
kingler5
  • 43
« Reply #29 on: August 14, 2010, 08:55:30 pm »
Never took out the delivery valves.
You are right, I don't know yet, will find out in a couple of hours.
You tell me if the collar is on the right way, the side with the little tiny hole is facing the sprocket end of the pump.
