Author Topic: getting horrible screach during start up !!video!!  (Read 5642 times)
July 20, 2010, 04:35:13 pm
awpgti
« on: July 20, 2010, 04:35:13 pm »
Whne i attempt to start up this 1985 jetta diesel im getting ths horrible sound and the car wont start, has anyone evr heard this sound???
Ok boys and girls here is the infamous cat rape sound, its not for the faint of heart....what's happening here is I wait for glow plugs, then try to start the car, at the end my fiance attempts to film the white cloud of smoke......turn the sound way up to get the full flavor, and the metalic nature of this!!!
click on the picture to watch video
here is the thread of what has been going on with this rebuild
http://forums.tdiclub.com/showthread.php?t=260581&page=108
Reply #1July 20, 2010, 05:31:15 pm
UnderPSI
  • 109
Re: getting horrible screach during start up !!video!!
« Reply #1 on: July 20, 2010, 05:31:15 pm »
Sounds like the starter isn't shimmed proper.
Suzuki Samurai 1.6
Reply #2July 20, 2010, 05:39:31 pm
awpgti
« Reply #2 on: July 20, 2010, 05:39:31 pm »
How do you go about shiming it??
Reply #3July 20, 2010, 06:01:49 pm
UnderPSI
  • 109
« Reply #3 on: July 20, 2010, 06:01:49 pm »
Isn't there a tin between the engine and trans?
Suzuki Samurai 1.6
Reply #4July 20, 2010, 06:49:56 pm
« Reply #4 on: July 20, 2010, 06:49:56 pm »
Do you have any loose belts? Did you play with the timing belt? What changed between when it was last starting properly and now?
Reply #5July 20, 2010, 07:26:04 pm
awpgti
« Reply #5 on: July 20, 2010, 07:26:04 pm »
Originally Posted by oilhammer
Just so we are clear, and to recap:
You got the engine started, it ran OK but you had the check valve on wrong so the vent cap was popping off #1 injector.
You fixed the check valve, engine started and ran fine, but then you noticed a horrific leak from the bellhousing.
Determined it was trans oil, pulled the trans, found you had someone sell you a large-shaft 020 seal, you corrected that, then put the trans back in, and now this problem? then....
...put trans in and everything ran ok...I adjusted the idle and ip had it run ok.
Then while it was running I was playing with the idle all of a sudden it stalled chucked it up to the idle screw.
Then I removed valve cover and turned each head bolt 1/4 turn because it went through several fam cycles.
Hasn't been the same since.....!?!?!?
Reply #6July 20, 2010, 09:12:12 pm
« Reply #6 on: July 20, 2010, 09:12:12 pm »
Check the cam and IP timing.
Reply #7July 22, 2010, 12:16:36 am
Thezorn
  • 381
« Reply #7 on: July 22, 2010, 12:16:36 am »
Check your crank nose sprocket too. The 1.6L's aren't known for it but the sprocket stripper on my 93 AAZ and I would get the same effect when trying to start.
Compounded 93 AAZ
Reply #8July 22, 2010, 06:30:48 pm
veedubcanuck
  • 151
« Reply #8 on: July 22, 2010, 06:30:48 pm »
Wow that sounds just like an engine that was run out of oil and spun the bearings..... What happened?
« Last Edit: July 22, 2010, 09:21:25 pm by veedubcanuck »
Reply #9July 23, 2010, 08:45:55 am
« Reply #9 on: July 23, 2010, 08:45:55 am »
there is either a broken piston, or bearings in very sad shape, in that engine.
not like internet diagnosis is the best, but my diagnosis is that it had a heart attack, and when the heart cant pump oil no more, the bearings have a heart attack.. lol.
sorry your engine is more than likely toast..
Reply #10July 25, 2010, 08:43:29 am
awpgti
« Reply #10 on: July 25, 2010, 08:43:29 am »
Well you guys guesed seems that the oil pump didn't prime/ lost it's prime/ or failed, but regardless the engine was oil deprived!!! And with out a doubt there is a degree of damdge!! The plan is to remove the head and the pan and inspect everything see what's damadged car was ran for no longer then 30 mom at idle had maybe three fan cycles!! What kind of damadged can I expect besides all bearings being shot and most likley broken and toasted rings??
Also I saw somthing about people upgrading to the " hydro oil pumps" they seem to flow a much greater amount of oil any insight into that would be great!!
Thank you!!
Reply #11July 25, 2010, 11:40:42 am
92EcoDiesel Jetta
« Reply #11 on: July 25, 2010, 11:40:42 am »
When did you first realize that oil was not flowing? Did you open the oil fill cap at the maiden start to look for oil flow? I assume not.
Reply #12July 25, 2010, 11:47:26 am
OM617
« Reply #12 on: July 25, 2010, 11:47:26 am »
Almost sounds like air being pushed out through a blown headgasket.
Reply #13July 25, 2010, 12:33:24 pm
westcoaster
« Reply #13 on: July 25, 2010, 12:33:24 pm »
Might be a bit late to ask these questions but...
Color of smoke out the tailpipe?
What happens if you disconnect the wire to the electrical pump (preventing the engine from wanting to fire)
Sound still there?
Post up a video of that. The engine wanting to fire is causing too much "clutter"
'87 suzuki samurai with a 1.9 AAZ TD transplant
Reply #14July 25, 2010, 02:23:55 pm
awpgti
« Reply #14 on: July 25, 2010, 02:23:55 pm »
Color was white now is black , the engine was def run with out oil. What damadge can I expect??
