Big Valve 1.6 Head
Topic: Big Valve 1.6 Head (Read 4999 times)
July 16, 2010, 10:56:45 am
UnderPSI
Big Valve 1.6 Head
July 16, 2010, 10:56:45 am »
Putting 39mm intake and 34mm exhaust valves in a 1.6 head. Just got the seats and vavle guides in. Need to do some work on the exhaust and a ton of work on the intake to get the ports to blend with the seats.
Intake
Exhaust
Suzuki Samurai 1.6
July 16, 2010, 11:40:44 am
Re: Big Valve 1.6 Head
July 16, 2010, 11:40:44 am »
anyone know what comes in an AAZ head? valve size wise?
July 16, 2010, 08:33:15 pm
truckinwagen
July 16, 2010, 08:33:15 pm »
very cool, I was going to try this myself.
quick question though, how close does this put the valves to the side of the bore?
also, do you think there is enough meat in the head to port it to that extreme without getting too close to the water jacket?
is it a hydro, or a mech head, and where did you get your valves/seats?
-Owen
83 Opel Kadett Diesel
July 17, 2010, 08:31:23 am
UnderPSI
July 17, 2010, 08:31:23 am »
It's a mech head.
Suzuki Samurai 1.6
July 17, 2010, 02:25:11 pm
UnderPSI
July 17, 2010, 02:25:11 pm »
Started bowl work. Seems to be plenty there to cut.
Suzuki Samurai 1.6
July 17, 2010, 03:59:59 pm
truckinwagen
July 17, 2010, 03:59:59 pm »
very cool, would you mind taking a pic with a headgasket on it to show how close the valves get to the sides of the bore?
-Owen
July 17, 2010, 06:05:40 pm
UnderPSI
July 17, 2010, 06:05:40 pm »
Don't have the headgasket with me. Putting a 1.9 metal gasket on it. Should have room, block is done .5mm over that will give a little exta.
Suzuki Samurai 1.6
July 18, 2010, 08:14:35 am
arnold
July 18, 2010, 08:14:35 am »
Where did you get those valve's and seats ?
July 18, 2010, 10:17:51 am
UnderPSI
July 18, 2010, 10:17:51 am »
Machinest got the seats for me, the valves are of the shelf parts but I'm not sure if they will work quite yet.
Suzuki Samurai 1.6
July 18, 2010, 02:11:14 pm
truckinwagen
July 18, 2010, 02:11:14 pm »
when I was thinking of doing the same, I was thinking of using valves built for the aircooled VW.
they are cheap, available in a wide range of sizes(and in stainless) and have the right stem diameter to use the stock guides. the stems are too long, but any good machinist can cut them down to the proper length no problem.
you can get the stainless aircooled valves in just about whatever size you want for $10 per valve, and most of the retailers of the aircooled valves sell seats to match them too(but your machinist can probably get them for you cheaper)
are you willing to tell us how much you paid for the parts and machining?
I may just do this while I have my motor apart...
-Owen
July 18, 2010, 02:16:05 pm
UnderPSI
July 18, 2010, 02:16:05 pm »
Seats and guides were around $350. Trying to make it work with off the shelf parts to keep cost down use readily available parts. Also going to be using a hydro cam, hopefully everything will work without custom parts.
Suzuki Samurai 1.6
Reply #11
July 18, 2010, 05:07:31 pm
Reply #11 on:
July 18, 2010, 05:07:31 pm »
are 1.9 and 1.6 valves the same size?
Reply #12
July 18, 2010, 05:18:24 pm
MJF
Reply #12 on:
July 18, 2010, 05:18:24 pm »
1,6 34in 31ex
1,9 36in 31ex
mech valves ~105mm long, hydr ~95mm.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #13
July 18, 2010, 09:09:15 pm
Aki-76
Reply #13 on:
July 18, 2010, 09:09:15 pm »
http://s434.photobucket.com/albums/qq68/Aki-76/moottorin%20osia/?action=view¤t=03042010812.jpg
41mm in / 35mm ex
ceramic coated,off course
Reply #14
July 18, 2010, 09:20:30 pm
UnderPSI
Reply #14 on:
July 18, 2010, 09:20:30 pm »
Quote from: Aki-76 on July 18, 2010, 09:09:15 pm
41mm in / 35mm ex
Maybe just a hair big for a 77mm bore.
Suzuki Samurai 1.6
Big Valve 1.6 Head
