Author Topic: Big Valve 1.6 Head  (Read 5172 times)
Reply #15July 18, 2010, 09:22:19 pm
truckinwagen
  • 1895
Re: Big Valve 1.6 Head
« Reply #15 on: July 18, 2010, 09:22:19 pm »
good lord!
anyone know at what point the valves start getting shrouded by the cylinder wall?
and also, do the runners on the 1.6 head have enough flow to support such big valves? I have always thought that the sharp turn at the valve bowl was the big flow restriction, not the factory valve size.
not to say that bigger valves would not help, but I wonder what the point of diminishing returns is...
-Owen
83 Opel Kadett Diesel
Reply #16July 18, 2010, 10:35:40 pm
  • 3468
    • McScrubbins Body Wash
« Reply #16 on: July 18, 2010, 10:35:40 pm »
Same with the AAZ's Owen. when i ported my head i noticed it choked up incredibly at the 90 degree turn. Very worth noting.
Reply #17July 19, 2010, 12:59:11 am
Aki-76
« Reply #17 on: July 19, 2010, 12:59:11 am »
http://s434.photobucket.com/albums/qq68/Aki-76/moottorin%20osia/?action=view&current=03042010812.jpg
41mm in / 35mm ex
ceramic coated,off course   ;)
My new engine is 80.5mm bore,next engine is 81.5 or more.(mayby more = )
Thats true,big valve isnt all ways better than orginal.Orginal bore (aaz/1Y) best size is somethink 38-39mm in and 33 ex.
This head i run dyno 0.6 bar boost 218hp in wheel.
« Last Edit: July 19, 2010, 01:02:36 am by Aki-76 »
Reply #18July 19, 2010, 09:35:25 am
UnderPSI
  • 109
« Reply #18 on: July 19, 2010, 09:35:25 am »
What head did you use for that?
Suzuki Samurai 1.6
Reply #19July 19, 2010, 12:19:24 pm
MJF
  • 581
« Reply #19 on: July 19, 2010, 12:19:24 pm »
Itīs 1,9 head.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #20July 19, 2010, 02:15:13 pm
UnderPSI
  • 109
« Reply #20 on: July 19, 2010, 02:15:13 pm »
A 1.9 head must have wider valve spacing than a 1.6.
Suzuki Samurai 1.6
Reply #21July 27, 2010, 03:36:53 pm
UnderPSI
  • 109
« Reply #21 on: July 27, 2010, 03:36:53 pm »
Almost done, don't think you can go any bigger in a 1.6 head.
Suzuki Samurai 1.6
Reply #22July 27, 2010, 04:54:40 pm
  • 3468
« Reply #22 on: July 27, 2010, 04:54:40 pm »
MJF's godly cylinder head...
I wish i could see UnderPSI's photos but i can't at work! :(
