Author Topic: The Rebirth of Smokey Eddy - The 1.9 Saga  (Read 54263 times)
Reply #60July 14, 2010, 02:51:33 pm
catlin_cava
  • 1954
Re: The Rebirth of Smokey Eddy - The 1.9 Saga
« Reply #60 on: July 14, 2010, 02:51:33 pm »
Looks sweet man, I can't wait to see it running
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #61July 16, 2010, 06:15:41 pm
Thezorn
  • 381
« Reply #61 on: July 16, 2010, 06:15:41 pm »
If you don't have a good D.I.Y for the boost pressure controll or Manula Boost Controller let me know. I just made my own for about 15 bucks and it work amazing, opens up right at 15 psi and it could easily open at any boost level. I can take some pictures and show you how I did it if you want.
Will.
Compounded 93 AAZ
Reply #62July 16, 2010, 09:18:23 pm
arsenicpants
« Reply #62 on: July 16, 2010, 09:18:23 pm »
Will.
I'd like to see that, please :)
Reply #63July 16, 2010, 09:55:14 pm
RadoTD
  • 513
    Stage WTF
« Reply #63 on: July 16, 2010, 09:55:14 pm »
Will.
+1
I the wastegate on my K14 is so finicky, I've given up for now
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #64July 17, 2010, 12:24:54 am
zagarus
  • 619
« Reply #64 on: July 17, 2010, 12:24:54 am »
looks like it's coming together quite nicely!  8)
Reply #65July 17, 2010, 12:57:03 am
Thezorn
  • 381
« Reply #65 on: July 17, 2010, 12:57:03 am »
Ill take pictures tomorrow and post them up here for you guys.
Compounded 93 AAZ
Reply #66July 17, 2010, 01:20:42 am
  • 3468
    • McScrubbins Body Wash
« Reply #66 on: July 17, 2010, 01:20:42 am »
Will.
this is very kind of you! However, i do not want to waste boost that's already being produced and allow the turbo to over spool with lots of fueling. I NEED to run a working adjustable waste gate.
Unless... what you're talking about IS related to a waste gate and doesn't just blow off boost pressure like a blow off valve...
Reply #67July 17, 2010, 10:06:11 am
« Reply #67 on: July 17, 2010, 10:06:11 am »
Are you done yet? :P
Reply #68July 17, 2010, 10:08:32 am
« Reply #68 on: July 17, 2010, 10:08:32 am »
Eddy, a boost controller just holds the WG closed until a certain set pressure, then it "pops" open, it doesnt open 30% at 8psi, 60% by 12 psi, on and on.. it is completely closed until the set pressure, then it pops open. makes for quicker spool up too..
Reply #69July 17, 2010, 10:59:49 am
  • 3468
« Reply #69 on: July 17, 2010, 10:59:49 am »
oh ok so that is what thezorn is talking about then?
and almost tyler. i cant get my turbo apart so im going to say screw it.
Reply #70July 17, 2010, 11:10:12 am
« Reply #70 on: July 17, 2010, 11:10:12 am »
Good you'll like the NA a lot more anyways :P
Reply #71July 17, 2010, 11:11:06 am
  • 3468
« Reply #71 on: July 17, 2010, 11:11:06 am »
Oh im still going to use it. I'm not a fool. I just can't change the hot side bearing is all. it wasn't leaking anyways.
Reply #72July 17, 2010, 11:12:46 am
« Reply #72 on: July 17, 2010, 11:12:46 am »
HEY! what are you saying?
I knew what you meant, I was just messin with ya
Reply #73July 17, 2010, 11:13:43 am
  • 3468
« Reply #73 on: July 17, 2010, 11:13:43 am »
Oh okay :P
im not saying anything ;)
Reply #74July 17, 2010, 11:19:48 am
  • 3468
« Reply #74 on: July 17, 2010, 11:19:48 am »
With the plate in there the push rod actually pushes on something! Hurray!
« Last Edit: July 17, 2010, 11:22:54 am by Smokey Eddy »
