Author Topic: How much boost are you running without IC?  (Read 6938 times)
Reply #15May 12, 2010, 04:20:21 pm
Re: How much boost are you running without IC?
« Reply #15 on: May 12, 2010, 04:20:21 pm »
you can up the boost and be ok, it could possibly make it run cooler egts.  but i wouldn't recommend cranking up the fuel and the boost a lot,  i was running 25-30 psi and plenty of fuel with no intercooler i did have a larger exhaust and cone filter but other wise there weren't any other mods.  i ended up with a cracked head,  you don't want to end up where i ended up haha.  i was young and dumb what ever.  honestly with out you increasing fueling, you probably won't be able to go over 15 psi.  there just won't be enough heat and gasses to do it.  so i'd say ur safe to up boost  just keep ur egts in check
Reply #16May 12, 2010, 11:39:48 pm
« Reply #16 on: May 12, 2010, 11:39:48 pm »
ive personally never seen an engine die from no timing belt cover.
ive killed an engine from having the air filter pop off.
someone else on the board has murdered their compression from losing an air filter too..
There have DEFINITELY been dead engines around here due to no timing belt cover.  There have DEFINITELY been engines who've died due to no air filter too!!  Both are equally bad news...  One gets you gradually over time, the other reaches out one day with a totally unexpected godsmack.  Either way, eventually you're doing a rebuild way sooner than you would have otherwise.
Reply #17May 13, 2010, 04:45:04 am
« Reply #17 on: May 13, 2010, 04:45:04 am »
Don't worry, he has a timing cover (finally) :-*
Reply #18May 13, 2010, 05:24:45 pm
deathhare
  • 74
« Reply #18 on: May 13, 2010, 05:24:45 pm »
Yeah thanks to this guy I have one. :)
I didnt say it was on the car though.  :P I'm trying to get it nitro plated at the moment to put it on.
And Ive always had an air filter. Its there in the pic you can just barely see it.
Reply #19May 13, 2010, 05:50:37 pm
2mAn
« Reply #19 on: May 13, 2010, 05:50:37 pm »
on my old TD coupe i was running 20psi. ill be taking it a lil easier on this coupe until i get an intercooler. old motor had a 2.5" PP downpipe and straight pipe exhaust. this new one is all TT stuff 2.25" im excited. so glad to be back here  ;D
Reply #20May 13, 2010, 06:00:26 pm
catlin_cava
  • 1954
« Reply #20 on: May 13, 2010, 06:00:26 pm »
I was running 20+ PSI on my Last AAZ with no intercooler.
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #21May 14, 2010, 08:39:16 am
GEE-BEE
  • 1604
« Reply #21 on: May 14, 2010, 08:39:16 am »
17 PSI here....
it's just a hauler....
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #22May 14, 2010, 02:48:18 pm
kaneb
  • 164
    • www.dasdubbers.org
« Reply #22 on: May 14, 2010, 02:48:18 pm »
I usually don't go past 15 psi but it will spike to 21 psi if i get on it.
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #23May 16, 2010, 12:17:10 pm
deathhare
  • 74
« Reply #23 on: May 16, 2010, 12:17:10 pm »
Did a 600 miles round trip this past weekend with no issues. A LOT of mountains and long climbs on boost without any issues.  ;D
Reply #24May 16, 2010, 05:50:53 pm
« Reply #24 on: May 16, 2010, 05:50:53 pm »
Pics or it didn't happen. :)
Reply #25May 17, 2010, 03:01:17 pm
MouseGTD
  • 110
« Reply #25 on: May 17, 2010, 03:01:17 pm »
i was running 30psi+ for a good while till i got my boost controller now its around 25psi.
i've been running mine without a filter since i put the engine in over a year ago and had no problems what so ever. kept meaning to put one on but never got round to it and very much doubt i ever will. I also ran my old td scirocco for a year without one, both cars had plenty of abuse and were driven in all weathers and on lots of different sufaces from tarmac to gravel.
i've ran a few car's without cam belt covers and know many other's who have done the same and i have never heard of any engines being killed by it. whats supposed to be the danger?
« Last Edit: May 17, 2010, 03:23:22 pm by MouseGTD »
Reply #26May 17, 2010, 05:10:01 pm
« Reply #26 on: May 17, 2010, 05:10:01 pm »
With the timing belt, if ANYTHING and I mean ANYTHING from a tiny little pebble, a twig, parts of a bird that just went through you grill, that zip tie you left sitting on top of the radiator, some random bolt, WHATEVER gets between the belt and a pulley (which the toothed belt will drag in there quite nicely) you've got a very good chance of throwing the belt.  Once that happens you're rebuilding your head at a minimum since you just smashed your pistons into your valves.  If you're lucky it's just the head, if you're unlucky you could be in for a whole bottom end.  Personally I don't have an extra couple grand sitting around "just in case".
With respect to the air filter, well... Someone once told me if you don't have anything nice to say, don't say anything at all.   :-X :-X
Reply #27May 17, 2010, 10:25:23 pm
  • 3468
    • McScrubbins Body Wash
« Reply #27 on: May 17, 2010, 10:25:23 pm »
I tried 25psi once without an IC and my car actually got slower.
Reply #28May 18, 2010, 03:32:14 pm
MouseGTD
  • 110
« Reply #28 on: May 18, 2010, 03:32:14 pm »
does removing the cam belt cover suddenly turn your car into a magnet for low flying birds? lol
as i say i've never heard of an engine being damaged by a lack of a cover, some of the car's running without them are running twin carbs with trumpets and no filters too
some one best tell this bloke that his engine will explode if he drives it like that ::)
running no filters or cam cover is a common practice, i could fill this thread with photo's of car's running without one or both but the threads gone far enough off topic as is.
« Last Edit: May 18, 2010, 03:34:20 pm by MouseGTD »
Reply #29May 18, 2010, 08:41:48 pm
« Reply #29 on: May 18, 2010, 08:41:48 pm »
Remember, not every engine has a flat cylinder head and pistons with no room for valves.  Many many many gassers are non-interference engines, or are so slightly interference that they can suck it up with their hydraulic lifters in a lot of situations.  There are lots and lots and lots of these on this board:
I mean LOTS.
As to the bird, that was a joke... just ask this guy: http://www.vwdiesel.net/forum/index.php?topic=17883.0
