Author Topic: Installing the flywheel. Have a question....  (Read 4034 times)
April 28, 2010, 11:17:20 am
MoparEd
  • 37
« on: April 28, 2010, 11:17:20 am »
Hi,
Im getting ready to install the flywheel on my 1.9 AAZ with a 02A transmission. Im stumped. Is there suppose to be a shim between the flywheel and crank, or on the outside under the flywheel bolt heads?  Looking at the flywheel, i see an imprint of what seems to be a shim, but its on the inside between the flywheel and crank face. I also dont remember taking it off when I tore the engine down....
Thanks
« Last Edit: April 28, 2010, 11:19:00 am by MoparEd »
Reply #1April 28, 2010, 02:06:38 pm
Re: Installing the flywheel. Have a question....
« Reply #1 on: April 28, 2010, 02:06:38 pm »
ive never seen a shim between a crank and flywheel, except on a toyota 22r engine equipped with an auto trans. usually they go between the bolts and FW.
Reply #2April 28, 2010, 03:49:04 pm
Doakster
  • 291
« Reply #2 on: April 28, 2010, 03:49:04 pm »
It's not really a shim....but kinds of looks like a metal gasket...it comes in any clutch kit and you can probably order it separately.
It's shaped in the same pattern as the bolt holes on the flywheel flange, so only goes on one way. I've never understood exactly what it's used for.
But it's always been there on all the VW clutches I've done.
1991 VW Jetta 1.6TD (Formally an ECO), Giles LDA Pump and Injectors, Techtonics 2.25" Down Pipe and Exhaust system, Rebuilt Trans with 3.94 final drive and a Peloquin Limited Slip Diff, Front H&R Sport Springs, MK4 VR6/1.8T front brakes, Single Round Headlight Conversion.
Reply #3April 28, 2010, 03:52:30 pm
« Reply #3 on: April 28, 2010, 03:52:30 pm »
it goes between the bolts and the pressure plate then.
Reply #4April 28, 2010, 03:53:36 pm
« Reply #4 on: April 28, 2010, 03:53:36 pm »
Vince's dumb post about non-02A trannys deleted, since the OP has stated he's installing an 02A.  :-X
« Last Edit: April 28, 2010, 06:19:51 pm by Vincent Waldon »
Reply #5April 28, 2010, 06:13:23 pm
« Reply #5 on: April 28, 2010, 06:13:23 pm »
Ed has a 02A though so it is in fact the flywheel that bolts to the crank.
Reply #6April 29, 2010, 02:30:00 am
ScottSummerhayes
  • 15
« Reply #6 on: April 29, 2010, 02:30:00 am »
Doesn't it stop the bolts from vibrating loose? and also spreads the load over the bolts to help keep it even when tightening...
Reply #7April 29, 2010, 06:42:23 am
Mark(The Miser)UK
  • 1557
« Reply #7 on: April 29, 2010, 06:42:23 am »
'KATE' refers to the shim as being  a compensating disk for automatics.
Mark-The-Miser-UK
Reply #8May 03, 2010, 11:10:38 pm
MoparEd
  • 37
« Reply #8 on: May 03, 2010, 11:10:38 pm »
Thanks for the replys :)
I ended up putting it back together without it lol
Reply #9May 04, 2010, 09:58:28 am
« Reply #9 on: May 04, 2010, 09:58:28 am »
I asked Giles about it as he also has a 02A and he doesn't remember his car having one.
Reply #10May 04, 2010, 11:46:24 am
« Reply #10 on: May 04, 2010, 11:46:24 am »
None on an 02J either, so perhaps it got discontinued when they went with the more conventional flywheel -> pressure plate arrangement.
