Author Topic: tranny questions, about the 020  (Read 7771 times)
March 17, 2010, 07:43:38 pm
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« on: March 17, 2010, 07:43:38 pm »
I know next to nothing on these trannies.  I have basically focused the entirety of my knowledge and brainpower on the engine.  I know that my engine will rev fast and higher than stock setups, so the question is how to take advantage of the torque and power that will be available.  I have a very rudimentry understanding o gear ratios and have sought out an 020 tranny with close gears I found here:
http://www.thesamba.com/vw/classifieds/detail.php?id=523552
I also know that to go anywhere far I want to have a highway cruising gear that is fairly long and as of yet have no Idea on anything.  FYI, I will be putting all of this under the trunklid of an 01' MR2 Spyder, in an MR setup with the engine and tranny facing the same direction, this will certainly take some doing, and I will need the tranny and engine+mounts to make the correct measurements.  Any help on this particular front will be helpful as well.... like say....... arb, or anyone else who has put a diesel in anything but a vw.
thanks,
Kevin
Reply #1March 17, 2010, 07:45:58 pm
truckinwagen
  • 1895
Re: tranny questions, about the 020
« Reply #1 on: March 17, 2010, 07:45:58 pm »
check out brokevw.com
you will learn all about the 020
-Owen
83 Opel Kadett Diesel
Reply #2March 17, 2010, 08:19:37 pm
rallydiesel
  • 1880
« Reply #2 on: March 17, 2010, 08:19:37 pm »
truckenwagen speaks the truth. I don't think anyone knows more about the 020 than broke.
Here's another good site about 020 gear ratios:
http://www.qualityvwparts.com/
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #3March 17, 2010, 09:01:45 pm
« Reply #3 on: March 17, 2010, 09:01:45 pm »
This will show you all the different gear ratios out there and let you play with tire sizes and stuff.
http://www.scirocco.org/gears/
Reply #4March 17, 2010, 09:34:52 pm
NintendoKD
  • 931
    • myspace page
« Reply #4 on: March 17, 2010, 09:34:52 pm »
I love this forum..... did I mention that you guys are great ;D
thanks,
Kevin
Reply #5March 18, 2010, 08:09:32 am
GEE-BEE
  • 1604
« Reply #5 on: March 18, 2010, 08:09:32 am »
Yeah, and some members give other members freebie's !
I support you , since you support us !
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #6March 18, 2010, 09:29:57 am
JerryGTD
  • 89
« Reply #6 on: March 18, 2010, 09:29:57 am »
Another good site with gear ratios on it.
http://www.a2resource.com/eandt/ratios.html
1991 Jetta GL ECOdiesel
Reply #7March 18, 2010, 11:35:41 am
« Reply #7 on: March 18, 2010, 11:35:41 am »
I don't think the 020 will handle all the power your engine is gonna put to it.
IIRC Dave's build a few years ago (190ish HP) went thru two 020's in about a week. :'(
Reply #8March 18, 2010, 07:22:23 pm
NintendoKD
  • 931
    • myspace page
« Reply #8 on: March 18, 2010, 07:22:23 pm »
In Japanese, I would say "Komata na"  This is quite the conundrum, I want a tranny that can handle the power and give me some quickness, the wide profile and low suspension geometry of the spyder will give me excellent traction, as well as the spectacular tires that I have put on it.  The good news is that my car will be that much fasdter with out the added weight of a tranny. ::)  Which tranny can I use, I project power to be in the 300 HP range, and that is a modest estimate, as well as having close to 400 ftlbs not 450.  Is there anything out there for me?  I would love to use a lim slip diff, but all of that power will exlode one of those in a heartbeat.  Should I just go out for a getrag "for those not saavy, this is the transmission for the 2jz toyota supra transmission, stock it is good to about 1000 hp, no joke" LOL
Reply #9March 19, 2010, 09:05:25 pm
NintendoKD
  • 931
    • myspace page
« Reply #9 on: March 19, 2010, 09:05:25 pm »
so is there a tranny that will handle the power that I will throw at it?  Without exploding?  These numbers are no Joke, I really plan on doing this, and making this a reality.  Without a transmission My car will have like waaaay more horsepower, you know, like mega weight reduction, that's like what, 100 pounds of weight LOL! ;D
Reply #10March 19, 2010, 11:54:32 pm
« Reply #10 on: March 19, 2010, 11:54:32 pm »
I doubt these tranny's are much over 50lbs.
Reply #11March 20, 2010, 12:04:38 am
NintendoKD
  • 931
    • myspace page
« Reply #11 on: March 20, 2010, 12:04:38 am »
LOL! right then 50 pounds, well, in wight reduction I say the pounds come first, the tonnes come later.
Reply #12March 20, 2010, 12:07:53 am
truckinwagen
  • 1895
« Reply #12 on: March 20, 2010, 12:07:53 am »
the big weak spot in the 020 is the ring gear rivets.
if you replace the rivets with the special ring gear bolts they can hold plenty of power, and I would recommend an LSD if you want any kind of traction at all with all that power.
I like the Wavetrac diff, it not only is the cheapest LSD for our cars, but works better too, you can get them from Bildon Motorsport.
-Owen
Reply #13March 20, 2010, 01:20:30 am
NintendoKD
  • 931
    • myspace page
« Reply #13 on: March 20, 2010, 01:20:30 am »
I know absolutely nothing about transmissions, any info?  I need pictures folks  I want to learn, but don't know where to go to school on vw trannies :-[  I need to learn to I have learned everything els eabout these cars/engines but know next to nothing on gearing and how the transmission works.  Once I wrap my brain around something and have a firm grasp there is no letting go.  I will look at Howstuffworks but I need particulars on this mission, in otherwards the 020, or is there a more suitable alternative.  Also thanks on the advice on the diff, an LSD would be just superb,as opposed to a torque biased for lots of power and traction.  I have wider bigger tires on the spyder, I have the 03'+ style rims which have larger wider in the front to give it a good profile and better traction.  I'll post up some pics sometime.
thanks,
Kevin
Reply #14March 20, 2010, 07:15:16 am
JerryGTD
  • 89
« Reply #14 on: March 20, 2010, 07:15:16 am »
