Author Topic: VANAGON/T3 SILICONE COOLANT HOSES *GROUP BUY* SIGN UP  (Read 39904 times)
Reply #15December 07, 2009, 09:50:15 am
GEE-BEE
  • 1604
Re: VANAGON/T3 SILICONE COOLANT HOSES *GROUP BUY* SIGN UP
« Reply #15 on: December 07, 2009, 09:50:15 am »
THERE IS NOW !
Just wait and see....
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #16December 07, 2009, 01:03:18 pm
SYNCROgeek
  • 1
« Reply #16 on: December 07, 2009, 01:03:18 pm »
I will definitely buy 1 set.  I prefer the euro 1.6TD (JX) hoses.
-Andrew                               /  Syncro Westfalia - subaru 2.5
Syncro Doka - 1Z TDI project  \  Syncro B3 VR6 wagon
Corrado G60                          /  Syncro B3 2L16vG60 twinscrew
Reply #17December 07, 2009, 02:17:21 pm
Elliot54
  • 1
« Reply #17 on: December 07, 2009, 02:17:21 pm »
Count me in for 2 sets Elliot54
2- 82' westi-diesels
Reply #18December 08, 2009, 09:33:23 am
GEE-BEE
  • 1604
« Reply #18 on: December 08, 2009, 09:33:23 am »
I have Chris at Van-Cafe sending in some obsolete hose's for duplication also
I hope this help's everyone..
Cheers
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #19December 08, 2009, 09:34:47 am
blackdogvan
  • 574
« Reply #19 on: December 08, 2009, 09:34:47 am »
Is there any consensus on the differences between the hose sets for the euro JX & whatever else exists?
1991 Vanagon 1.9 mTDI
Reply #20December 09, 2009, 04:25:46 am
kd4yor
  • 37
« Reply #20 on: December 09, 2009, 04:25:46 am »
what's the significance of TUV certification for a state side van? seems like a way to cut down on the price some.
Reply #21December 09, 2009, 05:27:07 am
tdihuntdawg
  • 27
« Reply #21 on: December 09, 2009, 05:27:07 am »
I will take 1 set for euro 1.6
Reply #22December 09, 2009, 08:16:13 am
GEE-BEE
  • 1604
« Reply #22 on: December 09, 2009, 08:16:13 am »
It's a Euro spec like : SAE or DOT
US Spec : SAE J20R3
The tooling is what makes assy's pricey
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
Reply #23December 09, 2009, 04:07:50 pm
vedipus
  • 9
« Reply #23 on: December 09, 2009, 04:07:50 pm »
I would be interested in a set. I have a converted van and '82 or '83 hoses would probably both work with some mods on my part.
can't get out from under this pile of old VW diesel stuff - anybody need 1.6TD parts?
'04 R32
'85 Vanagon w/inline-4 conversion
'74 Fox
'89 Jetta GLI Wolfsburg
Looking for a nice '85-'86 Golf, Dasher, or Quantum diesel
Reply #24December 10, 2009, 06:08:39 pm
williamtaygan
  • 33
    • Arctic Vegwerks
« Reply #24 on: December 10, 2009, 06:08:39 pm »
What year are the obsolete hoses?  '82 or '83?
Here's a shot of the '82 and another with size differences labeled on the TIICO hoses - all VERY rough measurements.
Maybe use the '82 octopus hoses for routing, since it seems to take the injection lines into account - and also the lower return hose, since it bends around the fuel filter - but step the ends so gas to diesel conversions with the larger coolant pipe and expansion tanks could pop them right in? ('83 has the larger tank but the smaller pipes)
Perhaps combine the later w.pump to exp tank hoses so the larger part routes around the engine mount like an '82, but it looks like the heater line on the JX/TIICO might be going around the later-style expansion tank.  (Can anyone confirm how the later style heater hose fits on a stock '82 engine?)
I'm also wondering if there's a reason why the '82-'83 style hoses aren't being used for diesel conversions, other than being NLA - any design issues?
Anyone got a STOCK 1983 HOSE pic they could share?  Differences with the '82?
Cheers
GB
Stock '82 hoses:
TIICO gasser hoses (which look nearly *identical* to the JX Euro turbo diesel hoses - except for the one bend in the straight hose)  Measurements are from the '82 stock hoses, but in the same places:
1981 1.6 NA Pickup
1982 1.6 NA Westfalia
1990 1.6 NA Jetta (not running)
1991 1.6 eco Jetta
1994 1.6 TD Jetta
Reply #25December 10, 2009, 07:25:04 pm
GEE-BEE
  • 1604
« Reply #25 on: December 10, 2009, 07:25:04 pm »
THE FIRST TWO GOING TO TOOLING ARE :
025-21-062E LIST , STOCK 82.69
025-121-062 F LIST, STOCK EPDM TYPE 139.90
There will two pictures to compare, stock versus Silicone
Black
Iam probly doing 25 each on these, that way there is no tooling cost ( mandrell )
I belive there are apart of the Tiico kit
Gee-Bee
« Last Edit: December 11, 2009, 02:43:18 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #26December 10, 2009, 07:42:56 pm
westyventures
  • 45
« Reply #26 on: December 10, 2009, 07:42:56 pm »
025-21-062E
025-121-062 F
Black
Gee-Bee
I'm confused: why are you starting with these? I thought we were talking diesel hoses here.
Karl Mullendore
www.westyventures.com
Reply #27December 10, 2009, 07:45:46 pm
GEE-BEE
  • 1604
« Reply #27 on: December 10, 2009, 07:45:46 pm »
I know , but these where the first sent in , Iam waiting for a complete Diesel set to arrive, it's nice to see the original and oem price and compare quality for a first article on the silicone type.
I look forward to various model's..
AAZ/ TDI etc.
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
Reply #28December 14, 2009, 01:57:19 am
Syncroincity
  • 727
« Reply #28 on: December 14, 2009, 01:57:19 am »
Euro DV set shipped out Friday, you should get it Mon or Tues. I included my front hoses also, which are '86 WBXer style, they don't have the uprights that early DV hoses do...
FWIW, comparing the pic above of the TIICO set to my set showed them to be practically identical, the only difference being a slight offset twist to the ends of the small single z-shaped hose.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #29December 14, 2009, 07:49:17 pm
GEE-BEE
  • 1604
« Reply #29 on: December 14, 2009, 07:49:17 pm »
Front's and Tiico received and shipped to tooler..
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
