Author Topic: OIL DRAIN PLUG ( QUICK )  (Read 4798 times)
November 15, 2009, 09:55:38 am
GEE-BEE
  • 1604
« on: November 15, 2009, 09:55:38 am »
QUICKOILDRAINVALVE.COM
Available with and without nipple for a hose connect
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1November 15, 2009, 10:42:15 pm
OM617
Re: OIL DRAIN PLUG ( QUICK )
« Reply #1 on: November 15, 2009, 10:42:15 pm »
Is it that difficult to remove 1 bolt every couple of months?
Reply #2November 15, 2009, 10:46:45 pm
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: November 15, 2009, 10:46:45 pm »
Hahahahahahhahah I'm with OM617...
It's really not that difficult.
Reply #3November 15, 2009, 10:50:12 pm
truckinwagen
  • 1895
« Reply #3 on: November 15, 2009, 10:50:12 pm »
many of the oil pans on the equipment I work on have ball valves with a nipple for a hose.
but those have their oil changed once a month(ore more) and use upwards of fifteen gallons of oil each.
I have thought about putting a valve for oil changes on my motor, but it would probably just get knocked off.
83 Opel Kadett Diesel
Reply #4November 16, 2009, 12:21:20 am
Op-Ivy
  • 513
« Reply #4 on: November 16, 2009, 12:21:20 am »
If you are prone to stripping bolts it might be a good idea. :P
Reply #5November 16, 2009, 07:28:08 am
« Reply #5 on: November 16, 2009, 07:28:08 am »
i would rip the damn thing off and cook my engine. im with 617 and everyone else here, just take the bolt out, its not that hard.
Reply #6November 16, 2009, 08:36:53 am
GEE-BEE
  • 1604
« Reply #6 on: November 16, 2009, 08:36:53 am »
Gee's
I installed one on my sump on my Porsche ( dry sump )12 quarts of oil
I thought I would just show others a good product...
I think I will keep my fingers of posting any idea's from know on...
Later
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
Reply #7November 16, 2009, 09:59:47 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #7 on: November 16, 2009, 09:59:47 am »
I think this one would make more sense in a VW:  http://www.nospillsystems.com/prod02.htm   As mentioned previously they are primarily used where you have to drain large quantities of oil.   For VW's the primary advantage would be not having hot oil run over your hands as you remove the bolt.
Calvin
91 VW Golf 1.6NA 5spd
Reply #8November 16, 2009, 11:14:22 am
« Reply #8 on: November 16, 2009, 11:14:22 am »
If I could keep myself from offroading it would work fine, but alas, everytime I add something new to the underside I find myself driving down a rutted trail........
Reply #9November 17, 2009, 07:40:11 am
stewardc
« Reply #9 on: November 17, 2009, 07:40:11 am »
Thanks for this my man. One will be added to the Caddy when I install the new oil pan. ;D
Reply #10November 17, 2009, 08:30:05 am
GEE-BEE
  • 1604
« Reply #10 on: November 17, 2009, 08:30:05 am »
Yeah !
Somebody likes it !  ;)
So what is the drain (plug ) size ?
Fumoto engineering is the Mfg
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
Reply #11November 17, 2009, 09:30:57 am
stewardc
« Reply #11 on: November 17, 2009, 09:30:57 am »
Don't know right now. Will measure before I order.
Reply #12November 17, 2009, 09:45:05 am
macka
  • 957
« Reply #12 on: November 17, 2009, 09:45:05 am »
2 sizes listed. 14x1.5mm and an adaptor if you don't need one. I'm getting one, I ordered a skid plate, because I do drive on a lot of bushroads, I figure if I don't have to drop the plate to do an oil change. Time saved is money saved.
Quote from: Vincent Walden
Reply #13November 17, 2009, 11:21:06 am
GEE-BEE
  • 1604
« Reply #13 on: November 17, 2009, 11:21:06 am »
Thanx for the size, you can get it with and without a hose nipple...
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
Reply #14November 17, 2009, 12:43:30 pm
  • 3468
« Reply #14 on: November 17, 2009, 12:43:30 pm »
Gee's
Later
Gee-Bee
I didn't mean to offend you either, I just think it's a funny idea for what, 4-5 litres of oil?
Some people go overboard on their VW's and there is nothing wrong with that if you're having fun.
