Author Topic: what's the thread pitch of AAZ block turbo oil return banjo?  (Read 3760 times)
October 29, 2009, 09:01:07 am
87octane
« on: October 29, 2009, 09:01:07 am »
Ain't got one. Need a pipe plug pronto. What's the mm/pitch for that fitting into the side of the block where the turbo would normally drain back?
Reply #1October 29, 2009, 02:27:47 pm
GEE-BEE
  • 1604
Re: what's the thread pitch of AAZ block turbo oil return banjo?
« Reply #1 on: October 29, 2009, 02:27:47 pm »
IT'S THE FINE THREAD TYPE METRIC, IF YOU CAN WAIT i CAN GET A SIZE TOMORROW
Corse 1.25 thread  Pitch
Fine 1.50 Thread Pitch
Iam going to do a 90 degree adapter ( metric to -8 flare )for a aircraft type hose
teflon with s/s fittings with a ae466 aeroquip intergal fire sleeve
I purcahed the Banjo adapter to _8 hose on ebay...
Gee-Bee
« Last Edit: October 29, 2009, 02:36:19 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2October 29, 2009, 02:50:28 pm
87octane
« Reply #2 on: October 29, 2009, 02:50:28 pm »
Tomorrow will be great. The local metric bolt supply house will be open Friday so I can button up the new block this weekend. I'm expecting you to say 14 or 15mm fine as a rough eyeball estimate. I can't find anything that big in my various bolt buckets.
Reply #3October 29, 2009, 07:36:51 pm
« Reply #3 on: October 29, 2009, 07:36:51 pm »
1.25 is finer than 1.50.
Reply #4October 30, 2009, 08:39:32 am
GEE-BEE
  • 1604
« Reply #4 on: October 30, 2009, 08:39:32 am »
my bad...  :-[
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
Reply #5October 30, 2009, 03:32:14 pm
stewardc
« Reply #5 on: October 30, 2009, 03:32:14 pm »
I got my fittings at a local hydraulic shop.
Reply #6October 31, 2009, 04:27:49 pm
GEE-BEE
  • 1604
« Reply #6 on: October 31, 2009, 04:27:49 pm »
IT'S A 18MM
THOMPKININD.COM
7408-18 PLUG  9.76 IN STOCK
Giles Pump OHC
MK1 JETTA DASH
Reply #7November 02, 2009, 07:22:33 pm
87octane
« Reply #7 on: November 02, 2009, 07:22:33 pm »
Huge thanks, GEE BEE.
Yikes, it's a $15 bolt with tax and shipping, if you can find a disti that'll sell only one.
Better than an empty hole in the side of the block spewing oil, seeing as I spent the day and a 1/2 case of engine degreaser scrubbing the chassis and driveline in preparation for stabbing the new 1.9 in.
Looks like the previous owners could not stop the various previous engine incarnations from spewing forth from every seam, every gasket.
These 1.9's sure do look regal (and really tall) fully dressed on an engine stand, makes me wonder how you vw guys can fit all that stuff under the hood without flopping it over at a 45 like the vanagon guys do.
I'm really hoping my front and rear 3rd member trade with Idaho delivers before I have to bury the front diff under franken one nine, cuz that b$tch is heavy...
Reply #8November 02, 2009, 09:16:04 pm
GEE-BEE
  • 1604
« Reply #8 on: November 02, 2009, 09:16:04 pm »
Yep time is money...
I used to have a aircraft hose shop at Long beach Airport, I did low psi 50 to 6000 opsi S/S braided teflon hoses
Some of the new stuff is Kevlar braided with Ti Fitting's
C17
B777 / B780 dreamliner
Are the two newer aircraft with those hose assy's
I now do custom silicone seal's and extrusion's
Giles Pump OHC
MK1 JETTA DASH
