Author Topic: Dakota digital diesel tach converter box....brand new!!!!  (Read 5143 times)
November 30, 2008, 02:48:27 pm
jimbote
  • 168
« on: November 30, 2008, 02:48:27 pm »
[/b]SOLD .....Thanks Ben!!!
Reply #1December 01, 2008, 11:02:17 pm
79rabbit4dr
« Reply #1 on: December 01, 2008, 11:02:17 pm »
I've been looking into getting one of these. I read your workaround with the nuts on the pulley, I don't have access to a welder so I'm probably going to go this route. How difficult is it to get one of these working?
any interest in trading for some spare parts I have posted?
http://www.vwdiesel.net/forum/index.php?topic=17210.0
« Last Edit: May 28, 2009, 08:57:02 am by 79rabbit4dr »
Reply #2December 02, 2008, 07:36:50 am
BigVWman
  • 332
« Reply #2 on: December 02, 2008, 07:36:50 am »
Would this work well to convert the TDI ECU signal to run an older tach? Is it still available?
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #3December 02, 2008, 03:26:40 pm
jimbote
  • 168
« Reply #3 on: December 02, 2008, 03:26:40 pm »
Quote from: "79rabbit4dr"
http://vwdiesel.net/phpBB/viewtopic.php?t=17210
I don't think it will be too difficult to get it working however the instructions are horrible imho....if you purchase I can help ya' with understanding the obvious "greek" installation manual ....right now i'd like cash to justify buying a different boost and egt gauge....
Reply #4December 02, 2008, 03:31:43 pm
jimbote
  • 168
« Reply #4 on: December 02, 2008, 03:31:43 pm »
Quote from: "BigVWman"
Still available....but I don't think it will be able to convert a TDI's ecu signal for an older tach....what kind of alternator are you using?...it can convert a inductive signal down to 36 teeth.....which means you can point an inductive pickup at your cam or IP sprocket(44t) or your flywheel teeth via inductive pickup and use that signal to power your tach with this converter or you can tap into you alternator and use the W signal....
Reply #5December 03, 2008, 11:35:23 am
BigVWman
  • 332
« Reply #5 on: December 03, 2008, 11:35:23 am »
The alt i'm using is the 120amp but i was trying to just modify the signal from ecu which i believe is 0-5volts to operate an older(mk1) tach. I can calibrate using the vagcom but am unsure if the dakota works this way.
Tim
Reply #6December 04, 2008, 05:38:56 pm
jimbote
  • 168
« Reply #6 on: December 04, 2008, 05:38:56 pm »
I would go to Dakota's website and on the DSL-1 page they have a link to the installation manual in PDF.....
Reply #7December 05, 2008, 04:03:35 pm
jimbote
  • 168
« Reply #7 on: December 05, 2008, 04:03:35 pm »
$60 shipped north america!!!
