Author Topic: Part-Out '79 Rabbit 4dr gas - S.E. Idaho - best offer takes  (Read 10033 times)
November 11, 2008, 04:03:10 pm
79rabbit4dr
« on: November 11, 2008, 04:03:10 pm »
tons of parts pictures at the link below.
http://picasaweb.google.com/myeternalmedia/79GasserPartsForSale#
ALL ORIGINAL PARTS as far as I know... I mean to say that these are all USED, original parts so the condition of them is NOT NEW!
This car used to be my neighbors, i've used some parts off of it for my 81 diesel rabbit 4dr. The rest needs to GO!!! Make me an offer, you pay shipping or come pick it up. The shell is also for sale. Minor surface rust, can easily be sanded off. No rust holes, not even close. West coast car.
I'd like to get a couple hundred out of this whole thing, as parts or all together I don't care.
list of items I have pulled so far;
- seat slider release pins = $5
- top half of timing belt cover (haven't taken bottom half off yet.) = $5
- rear area mat clamp things = $5
- valve cover = $15
- drivers side interior control mirror = $15
- side markers, front and back = $15/set
- gas pedal stopper = $5
- fuse rail = $20
- wood trim cluster = $30
- speedo converter module = $5
- tape deck = $20
- alternator = $20
- heater core line-in valve = $5
- metal tube - came from behind intake = $5
- water pump, housing & pulley = $10
- cam w/ gear gear might be sold, cam = $30
- fitted cardboard insert came out from under dash on pass side = $5
- glove box - lipstick red = $25
- ash tray - lipstick red = $15
- knee board - lipstick red = $30
- whats left of the motor, i'm told it ran well - being torn down & out = $name your part we'll work out a fair price
- shell, stays/goes together = $100
- small tail lights, bulb holders, & inner covers - SOLD
- distributor - SOLD
- front triangle windows - SOLD
- driver door window scraper - SOLD
- wiring harness - SOLD
- rear hatch hole plugs - SOLD
- rear area speaker housing - needs new carpet, tabs in tact - SOLD
LET ME KNOW IF THERE IS SOMETHING SPECIFIC YOU NEED, I MAY HAVE IT JUST DIDN'T LIST IT.
PLEASE PM for best response.
Reply #1November 11, 2008, 04:36:51 pm
RabbitGTDguy
  • 1274
« Reply #1 on: November 11, 2008, 04:36:51 pm »
wow...a solid and pretty clean shell....anywhere near the east coast! Amazing...
I need rockers for my 79, but I can't ask to have this cut up. Someone has to pick this up.
Joe
1972 VW Westfalia
Reply #2November 13, 2008, 06:08:58 am
myke_w
  • 1099
« Reply #2 on: November 13, 2008, 06:08:58 am »
I may have asked about this before but - do you have a steering column that isn't all jacked up? Mine has that wicked rattle they get when the lower bearing wipes out..
 :cry:
Reply #3November 13, 2008, 10:52:35 am
79rabbit4dr
« Reply #3 on: November 13, 2008, 10:52:35 am »
never driven the car so i'm not sure, sounded fine pushing it around.
Reply #4November 13, 2008, 02:23:41 pm
RabbitGTDguy
  • 1274
« Reply #4 on: November 13, 2008, 02:23:41 pm »
Myke,
You may want to just try checking that lower bearing as the problem is that they come loose from there mounting area in the column. Pushing it up, back in take the wiggle out of things as well as well. Its a common problem on the mk1. Many a fix has been done with a single zip tie that works flawlessly or if you want to go to town, push it back up in and add a hose clamp to keep it there.
Had the problem in my 81...never had a prob after.
There is a rebuild kit out there too...think it was 20.00 or so for it.
Joe
1972 VW Westfalia
Reply #5November 14, 2008, 06:06:34 pm
79rabbit4dr
« Reply #5 on: November 14, 2008, 06:06:34 pm »
posted up some pictures of rusty areas after cleaning them.
same album listed above;
Reply #6November 21, 2008, 11:31:06 pm
79rabbit4dr
« Reply #6 on: November 21, 2008, 11:31:06 pm »
all the glass is coming out of this baby, front triangles are gone but hatch, all 4 squares, and rear triangles are still available as well as the chrome trim that goes around the windows.
Reply #7November 28, 2008, 09:53:27 pm
79rabbit4dr
« Reply #7 on: November 28, 2008, 09:53:27 pm »
driver door window scraper = sold
tail light, bulb holders, and inner tail covers = sold
Reply #8December 01, 2008, 11:06:51 pm
79rabbit4dr
« Reply #8 on: December 01, 2008, 11:06:51 pm »
would also like to trade for tach, shifter boot, visors, or square headlight grill.
Reply #9December 02, 2008, 03:33:32 am
Turbinepowered
  • 1206
« Reply #9 on: December 02, 2008, 03:33:32 am »
That's a 1.6 solid lifter gas engine, right?
I'd be interested in the head, cam gear, and intermediate shaft w/ gear...
Reply #10December 03, 2008, 09:07:47 am
79rabbit4dr
« Reply #10 on: December 03, 2008, 09:07:47 am »
Quote from: "Turbinepowered"
uploaded pix of all that stuff you asked about. hope that helps.
Reply #11December 03, 2008, 04:03:42 pm
Dr. Diesel
  • 1341
« Reply #11 on: December 03, 2008, 04:03:42 pm »
That camshaft would be an upgrade for 81+ solid lifter gas engines. Almost the same as a G grind.
Reply #12December 03, 2008, 07:16:10 pm
79rabbit4dr
« Reply #12 on: December 03, 2008, 07:16:10 pm »
Quote from: "Dr. Diesel"
Good to know. Out of curiosity, how do you tell?
ALSO,
more pix uploaded.
Reply #13December 10, 2008, 08:56:41 pm
79rabbit4dr
« Reply #13 on: December 10, 2008, 08:56:41 pm »
posted more pix for you. http://picasaweb.google.com/myeternalmedia/79GasserPartsForSale#
Reply #14December 15, 2008, 02:44:59 pm
79rabbit4dr
« Reply #14 on: December 15, 2008, 02:44:59 pm »
exhaust is unavailable.
