Author Topic: replacement for K24 with ball bearing!  (Read 4741 times)
November 21, 2008, 12:26:20 am
blueattack
  • 13
« on: November 21, 2008, 12:26:20 am »
I'm looking for a turbo witch will replace my K24, but it needs to be a ballbearing! (vnt would be to much work)
I would like it to be almost as much as plug and play.
Does anyone knows a turbo which has these capabilities ?
Reply #1November 21, 2008, 03:08:26 am
dillenger1
  • 777
« Reply #1 on: November 21, 2008, 03:08:26 am »
there are none.Youll need to make an adapter plate or get an 8v log manifold.There are some IHI turbos really small and ball bearing.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #2November 21, 2008, 06:32:50 am
arb
« Reply #2 on: November 21, 2008, 06:32:50 am »
Quote from: "dillenger1"
Look at my 1.6L in a caravan for the amount of work to make a flange to adopt a turbo to a manifold it was not intended for. I'm happy with the results but not the amount of time it took.
Reply #3November 26, 2008, 10:45:33 am
Duzty
  • 34
« Reply #3 on: November 26, 2008, 10:45:33 am »
I'm running a Garrett GT2860RS 0,86 ballbearing on my 1,9TD. at 35psi.
But i fuel it very hard, and it has a bit spool time!
255hp/450nm.
VW Golf mk2 1.9TD - FMIC, GT2860RS - 11mm Pump.
1/4 Mile - 13,24 :twisted:
Reply #4November 26, 2008, 12:17:42 pm
zaprzal
  • 160
    • turbodiesel.pl
« Reply #4 on: November 26, 2008, 12:17:42 pm »
Quote from: "Duzty"
255hp/450nm.
when (rpm) does it wake up and when do you have full boost?
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #5November 26, 2008, 02:52:08 pm
Duzty
  • 34
« Reply #5 on: November 26, 2008, 02:52:08 pm »
Quote from: "zaprzal"
Quote from: "Duzty"
255hp/450nm.
You can see it on this video. A clip from the dyno!
DYNOMETER![/url]
Reply #6November 26, 2008, 04:18:36 pm
  • 3468
    • McScrubbins Body Wash
« Reply #6 on: November 26, 2008, 04:18:36 pm »
 :shock:
wow
Reply #7November 26, 2008, 08:12:33 pm
cyrus #1
  • 360
« Reply #7 on: November 26, 2008, 08:12:33 pm »
That thing is a beast!  :shock:
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #8November 28, 2008, 01:59:15 am
Dr. Diesel
  • 1341
« Reply #8 on: November 28, 2008, 01:59:15 am »
Quote from: "Duzty"
255hp/450nm.
The venerable disco potato... What rpm do you achieve full boost at?
Reply #9November 28, 2008, 08:42:16 am
Duzty
  • 34
« Reply #9 on: November 28, 2008, 08:42:16 am »
around 3200 rpm's.
But we fuel it around 170ml.
Reply #10November 28, 2008, 11:56:02 am
Dr. Diesel
  • 1341
« Reply #10 on: November 28, 2008, 11:56:02 am »
nice peak number.
