Author Topic: 2000 B5 VW Passat rear brake pad change  (Read 4091 times)
September 12, 2008, 09:12:08 am
zozie
  • 122
    • Rotoconcept Robotics
« on: September 12, 2008, 09:12:08 am »
Can someone tell me if I need special tools to do rear pads on the car? I have to do it tomorrow.I've done fronts a few times but I'm not sure about the rear because of the hand brake.
Any input is appreciated
Thanx
Reply #1September 12, 2008, 09:31:39 am
« Reply #1 on: September 12, 2008, 09:31:39 am »
its been a while but I think you need to twist the piston while you push it in..
Anyone else remember?
My older Passat rears are that way at least.
I just used a regular disk compressor and a pair of channel lock pliers to twist the piston as I pushed it in.
Have to be careful though it's easy to mess up the boot of mar the piston.
Reply #2September 12, 2008, 09:57:59 am
akrallysport
« Reply #2 on: September 12, 2008, 09:57:59 am »
Pretty much the only tool needed is something to retract the piston. Has to push and rotate simultaneously.
Reply #3September 12, 2008, 12:45:09 pm
« Reply #3 on: September 12, 2008, 12:45:09 pm »
Well if he doesn't have the rear disk specific tool he will need to twist the piston somehow..
It wont twist on it's own.
