Author Topic: Clutch for a 200+ HP 1.6?  (Read 5780 times)
August 23, 2008, 10:30:10 am
monomer
  • 414
« on: August 23, 2008, 10:30:10 am »
What should I do for a clutch? The stock clutch is beefy, but we're talkin a lot of torque here.
www.michiganvw.org
Reply #1August 23, 2008, 11:40:38 am
gigaz2
  • 626
« Reply #1 on: August 23, 2008, 11:40:38 am »
g60 flywheel and vr6 clutch, can't remember if you have to swap gearbox as well, but the stock one might not take it.
Reply #2August 23, 2008, 11:53:02 am
« Reply #2 on: August 23, 2008, 11:53:02 am »
u would need an 02a or 02j to run that clutch
Reply #3August 23, 2008, 11:56:35 am
53 willys
« Reply #3 on: August 23, 2008, 11:56:35 am »
PM "zukgod1"..he has a link to a company that makes beefed up custom clutches...... 8)
Reply #4August 23, 2008, 01:48:04 pm
stewardc
« Reply #4 on: August 23, 2008, 01:48:04 pm »
I used an ACT assembly on mine, but it's an AAZ and uses a bigger flywheel.
Reply #5August 23, 2008, 09:34:38 pm
Powered by Spearco
  • 1203
« Reply #5 on: August 23, 2008, 09:34:38 pm »
If your running a 020 trans. stock. Try a 200mm solid hub Bug clutch disk and a 210mm 16v presure plate and a 210mm flywheel. No need to buy a 02A or 02J trans, unless you've got the money? My .02 cents.
Josh
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #6August 23, 2008, 10:36:54 pm
monomer
  • 414
« Reply #6 on: August 23, 2008, 10:36:54 pm »
Quote from: "Powered by Spearco"
Josh
any P/N handy?
will this hold?
www.michiganvw.org
Reply #7August 23, 2008, 10:49:11 pm
Powered by Spearco
  • 1203
« Reply #7 on: August 23, 2008, 10:49:11 pm »
I'll get a PN tomarrow for the disk. As far as holding, I know a few racers with Rabbits and a rally racer that are useing it and no complaints as of yet.
'13 Golf R:. Tuned
'98 Puch G320
Reply #8August 23, 2008, 11:15:52 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #8 on: August 23, 2008, 11:15:52 pm »
In a gasser application, the 020 trans is ok up to 200hp (borderline). The torque numbers are usually close to the hp numbers on an NA gasser. If you are talking about TD running 200hp, you need to upgrade the trans to an 02a or 02j. 02m would be the best!
02a/etc. would be the best. use an ACT kit for a VR6 (stage2, sprung center, built pp).
this is the tested formula for gassers running 250-300hp. Remember, gassers run close torque ratings to hp. Diesel is another story.
Reply #9August 23, 2008, 11:27:43 pm
monomer
  • 414
« Reply #9 on: August 23, 2008, 11:27:43 pm »
Quote from: "vanagonturbo"
which cars would this come out of?
www.michiganvw.org
Reply #10August 24, 2008, 10:31:38 am
numbnuts
  • 99
« Reply #10 on: August 24, 2008, 10:31:38 am »
I thought an idi running 200hp would not be making much more torque than 200 ft/lbs :?  I thought it was thje tdi's and then the pd tdis that made alot more torque. If not show me some graphs please :wink:  :lol:
Reply #11August 24, 2008, 10:37:20 am
BlackTieTD
  • 1512
« Reply #11 on: August 24, 2008, 10:37:20 am »
02a passat or corrado is usually easist. around 90-92 passats are getting dirt cheap. people will give them away....
here is power torque graph of 1.6TD (52kW mkI TDs). its in metric though and at first it looks like the power is higher....
Reply #12August 24, 2008, 05:38:13 pm
Powered by Spearco
  • 1203
« Reply #12 on: August 24, 2008, 05:38:13 pm »
Ok, heres the Sachs PN for the 200mm disk.
AMTX5219M
VW PN for bug is,
311 141 031
Used with a 210mm clutch PP and Flywheel.
Try it, you might like it? :)
'13 Golf R:. Tuned
'98 Puch G320
Reply #13August 25, 2008, 01:19:45 pm
monomer
  • 414
« Reply #13 on: August 25, 2008, 01:19:45 pm »
AMTX5219M
VW PN for bug is,
311 141 031
is it holding up for you? how much did it run you?
www.michiganvw.org
Reply #14August 25, 2008, 05:32:18 pm
Powered by Spearco
  • 1203
« Reply #14 on: August 25, 2008, 05:32:18 pm »
I think my cost is around $30.00.
I do not have one in my vehicle as of yet but I know of someone who is running one in a race Rabbit (auto cross) and he says its the best combo yet.
Not 200+hp but close to 180hp.
'13 Golf R:. Tuned
'98 Puch G320
