Author Topic: Clutch for a 200+ HP 1.6?  (Read 5891 times)
Reply #15August 26, 2008, 03:55:38 pm
boosted_diesel_84
  • 216
« Reply #15 on: August 26, 2008, 03:55:38 pm »
or...spend some money like i did and get a real clutch... Spec Clutches, they can get you a clutch to hold up to whatever power level you want. mine is a stage 2, just installed on my new motor. which will be in soon. their stage 3 clutch is rated at 460 Ft. Lbs of torque, so i think it can handle a lil 1.6 haha
heres a link
http://www.034motorsport.com/index.php?cPath=113_2525_2603_2605
-Jack-
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #16August 28, 2008, 01:19:38 pm
monomer
  • 414
« Reply #16 on: August 28, 2008, 01:19:38 pm »
Quote from: "boosted_diesel_84"
heres a link
-Jack-
stage 3 ordered
www.michiganvw.org
