Author Topic: Anyone selling a head gasket (2 notch) and 12mm stud set ?  (Read 3272 times)
August 15, 2008, 07:53:54 pm
arb
« on: August 15, 2008, 07:53:54 pm »
Anyone in SE Michigan with an extra  head gasket (2 notch) and 12mm stud set  for a 1.6L (1982.5) they want to sell me ? I don't see where Parts Place Inc carries the stud set...
Reply #1August 15, 2008, 08:39:02 pm
blkboostedtruck
  • 1535
« Reply #1 on: August 15, 2008, 08:39:02 pm »
set of 10bolts 12mm head bolt part#sn15551 parts place $28.95
2notch part#sn1186 parts place $28.95
that info from Blkboostedtruck priceless :wink:
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2August 15, 2008, 08:48:01 pm
arb
thanks
« Reply #2 on: August 15, 2008, 08:48:01 pm »
Yeah, I see they sell the head bolts and gasket, I was looking for the Stud set - the Ford/ Cogsworth.... a little earier to assemble. I've never rebuilt with studs - always used the copper Permatex gasket spray to get the gasket to stay put while I set the head with normal bolts...
Reply #3August 15, 2008, 08:57:51 pm
blkboostedtruck
  • 1535
« Reply #3 on: August 15, 2008, 08:57:51 pm »
OH thats easy! grind heads off 2 old bolts and then grind a slot for a screwdriver use those to line up the head and hold gasket in place then just use a screwdriver to remove them and magnet after a couple new bolts have been put in after the head has been set on!
you understand what i mean? with that process?
Duane
'66 variant 1500S
Reply #4August 15, 2008, 09:01:48 pm
arb
« Reply #4 on: August 15, 2008, 09:01:48 pm »
Yep, I might end up doing it that way :-)  I understood the studs to not stretch like the stock bolts so you can use them over and over...
Reply #5August 15, 2008, 09:20:57 pm
« Reply #5 on: August 15, 2008, 09:20:57 pm »
Get studs from Summit Racing.
Reply #6August 15, 2008, 09:35:42 pm
arb
« Reply #6 on: August 15, 2008, 09:35:42 pm »
I really need to be bolting this engine in my caravan sooner than that.... If I can't get studs locally in a few days, I'll use stock this time around.
Say Jimfoo, like watching your wheelin photos. Did you but a locker in your diff's yet ? I've got a first gen Rubicon and that magic button means I've never been recovered but I've recoved many...
Reply #7August 15, 2008, 10:02:11 pm
subsonic
  • 1836
« Reply #7 on: August 15, 2008, 10:02:11 pm »
Try headbolts.com
I have a new metal aaz 3 notch you could use if your setup is hydro.
Reply #8August 15, 2008, 11:45:42 pm
  • 2932
« Reply #8 on: August 15, 2008, 11:45:42 pm »
Yeah, headbolts.com,.. as long as you have the part number.
Reply #9August 16, 2008, 06:04:38 am
arb
part # ?
« Reply #9 on: August 16, 2008, 06:04:38 am »
Does anyone have the part # for headbolts.com = the 12mm Stud set and 2 notch head gasket ?
Reply #10August 16, 2008, 01:30:53 pm
arb
« Reply #10 on: August 16, 2008, 01:30:53 pm »
I forgot all about S & G in our area...  they had both. $63 out the door.
http://www.sgparts.com/
Reply #11August 16, 2008, 04:20:10 pm
« Reply #11 on: August 16, 2008, 04:20:10 pm »
Quote from: "arb"
Locker in the rear.
