S-PAutomotive.com
Author Topic: 1.6L TD in a Dodge Caravan  (Read 144870 times)
Reply #495May 07, 2010, 04:59:03 pm
  • 7837
Re: 1.6L TD in a Dodge Caravan
« Reply #495 on: May 07, 2010, 04:59:03 pm »
I have 2 "pretty good" 1.6 clutches left over from my N/A and Turbo engines. The one in my N/A I was going to run until I realized I maybe making too much power. Pressure plates and discs look fine. I could ship both to you and let you decide :D  PM.
Reply #496May 10, 2010, 12:04:13 am
arb
« Reply #496 on: May 10, 2010, 12:04:13 am »
Wow, Smoking Eddie said it took 3 weeks before Prothe sent him his head...  :'(  Looks like I'll be burning gas like a drunken sailor for a while now. Then, it sounds like the new injectors might have issues out of the box. :-(  Hummmm. At least I have 2 sets of new OEM injector heat shields so I can reuse my old injectors if the "new" ones are not good. Time will tell. So, should I pull the head, then just the trans (going to do the clutch now too) ?? Or, just pull it all at once ? :-D
I've got some time now. Enough I could hot tank the block (Yeah, I'm sold school on that) and swap rings & bearings while I'm waiting for the head and stuff. If I pull the package, I'll be more likely to do the lower end while I'm waiting.
Reply #497May 10, 2010, 12:20:56 am
  • Administrator
  • 2831
« Reply #497 on: May 10, 2010, 12:20:56 am »
I really don't think the Merc nozzles are a good idea, IMHO...
I'm 90% sure I saw Giles saying they'd be bad mojo with the VW swirl chamber.  From what I understand the Mercedes chamber is a very different size and shape than the VW ones.  Makes sense - an idling IDI Merc sounds a lot different than a VW.  Also I think there's been people who've blown out their prechambers with Merc nozzles.
Reply #498May 10, 2010, 01:46:16 am
Runt
  • 83
« Reply #498 on: May 10, 2010, 01:46:16 am »
I think it was Dave (935racer) who ran both stock and merc nozzles on the dyno, and lost ~5hp, IIRC with the merc nozzles.  I see the some of the europeans mention biodiesel nozzles as being better, but I'm not sure which number those are, or what makes tham better.  I believe Giles swears by the stock nozzles, although I do recall seing mention of a GTD nozzle as well.
One DD 92 Jetta, One 91 Collision write-off, and One 92 rust free shell, beautiful, stripped, waiting for diesel-ization.
Reply #499May 10, 2010, 11:47:12 pm
  • 2787
« Reply #499 on: May 10, 2010, 11:47:12 pm »
Yup, from what I've read stock nozzles can flow plenty and it's the right spray pattern.
Reply #500May 11, 2010, 09:25:32 am
arb
« Reply #500 on: May 11, 2010, 09:25:32 am »
I'm glad you guys spoke up. I just asked Pete to change my new injectors to stock 1.6L TD injectors.
Reply #501May 11, 2010, 09:58:03 am
arb
« Reply #501 on: May 11, 2010, 09:58:03 am »
Arb, you're just the person to build your own injector tester from a bottle jack and replace your own injectors.
FWIW, I get the earlier TD nozzles from autohausaz.com and rebuild them to the *low* end of the pressure spec for best fuel economy.
I use the DNOSD293 nozzles which were spec'd on some vw IDI TD engines and yet are quite inexpensive:
http://sd.autohausaz.com/autohausaz/detailw.jsp?sid=3vjolwfmvksbhdytprkjh155&partner=autohausaz&product=0434250103
After buying the four nozzles you still have to toss in an oil filter just to meet the $50 free shipping.   ;)
Thanks Andrew !  There was nothing wrong with my current injectors that I know of. I only ordered new as I thought, new head, new injectors would not harm anything.
I'll have to search for how to make the tester w/ the bottle jack. Maybe the 12 ton that runs my U-joint press will work for that too.
Reply #502May 11, 2010, 12:37:07 pm
arb
« Reply #502 on: May 11, 2010, 12:37:07 pm »
Bummer, I'm back looking for a head again. Pete (Prothe) just sent me a message he is refunding my $$$ as he is out of stock on the head.
Reply #503May 12, 2010, 01:13:52 am
vwjunkie53
  • 98
    • The Volvo diesel forum
« Reply #503 on: May 12, 2010, 01:13:52 am »
I'm running a set of DNOSD273 "GTD" nozzles in my D24T in my volvo, they came from prothe and I have ahd good luck with them so far.  I also talked to Giles, and he said the stock TD and GTD nozzles both perform well, but the GTD nozzle seemed to make more power in a application with the fuel turned up or with a built pump.  As for economy, I gained a couple mpg after rebuilding my injectors, but i set them a little above the TD specs.  Mine are all around 2400 psi.  I have never heard of building them at the lower end of the spectrum for better economy, but then again I was looking for performance gain.  The extra MPGs were just bonus for me...
Jason
1984 Volvo 760 GLE,  "built" D24T w/ARP studs, MLS head gasket, ported/polished head, 3 angle valve job, NA cam, 56mm T3/T4, NA manifold, FMIC w/ 3" alum piping, 3" turbo back, detailed in CAT yellow. T-5 manual swapped w/ Clutchnet 6-puck.  Best of 16.07@86mph with orig. worn out engine.
Reply #504May 13, 2010, 08:53:06 am
arb
« Reply #504 on: May 13, 2010, 08:53:06 am »
I just got Prothe to refund the 4 merc injectors too. when the credits hit, I might drive up to partsplaceinc and get a new Brazilian made loaded new 1.6L hydro head for $600.
Reply #505June 01, 2010, 02:17:59 pm
arb
« Reply #505 on: June 01, 2010, 02:17:59 pm »
When to buy the "new" hydro head from Partsplaceinc and they wanted to charge me another $150 for a "Core deposit" - I questioned whether the head was really new if they needed a core back. He said sure it was new.. I asked what would happen if I brought them a mechanical head back as the core - he said they likely would give me half the $150 :-(  Did not sound very trustworthy to me... so I took a gamble with Prothe - Ordered new hydro head, lifters, valves on a Friday, he shipped on Monday, and 6 days after I ordered the parts were here. His valves are actually made in Taiwan. The head looks to be of good quality. I need to buy a new cam shaft as that's one thing he did not have. Photos to follow.
Reply #506June 05, 2010, 01:59:28 pm
spdrace11
  • 38
« Reply #506 on: June 05, 2010, 01:59:28 pm »
 :) nice work
91 VW Jetta diesel coupe 1.6 NA 5spd, 91 Jetta 1.6 NA, 81 Caddy 1.6NA
Reply #507June 16, 2010, 09:22:44 pm
  • 7837
« Reply #507 on: June 16, 2010, 09:22:44 pm »
Any updates on how it went?
Reply #508June 17, 2010, 11:57:21 am
arb
« Reply #508 on: June 17, 2010, 11:57:21 am »
Many delays in both getting parts and school ending for my son. So, I got the hydro head, hydro lifters, valves, HG, head bolts, clutch disc, throw bearing, and a single injector -   somehow I only ordered 1 injector and  forgot to order the valve stem seals, so another order when out and has been received.. Here's the photos of the parts from Prothe:
The head casing and machining look good.
The runners at the valve seat could be a bit better
But the casting roughness is localized at the valve end
The cam bearings look really good.
Machining looks good too:
The hydro lifters were packaged well and felt good.
The injectors were not made in China, but rather Taiwan. Hopefully they will not leak like some of you have found. You can also see the valve stem seal.:
I'm realistically looking at a couple of weeks before I have the engine out and the old head off - I am planning on reusing the springs, spring seats, and clips from the old head...
Reply #509June 17, 2010, 01:47:12 pm
Wayland
  • 364
« Reply #509 on: June 17, 2010, 01:47:12 pm »
My Prothe NA injectors have been fine so far. No leaks or other problems. Thanks for posting your report on the head. I've been thinking of ordering one.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Fixmyvw.com
