TDI Engine -General Info
05 tdi jetta
Topic: 05 tdi jetta (Read 4150 times)
July 29, 2008, 05:11:33 pm
Jesse34567
Newbie
05 tdi jetta
July 29, 2008, 05:11:33 pm »
i am just wondering what perfomance mods u guys would recommend for 05 jetta tdi
July 29, 2008, 08:54:49 pm
VW_Commuter
05 tdi jetta
July 29, 2008, 08:54:49 pm »
How much are you looking to spend? Since it's an '05 that means it has Pumpe Duese injection and that means that no power mods are cheap. Injectors are $400/each for a total of $1600 to change your injectors.
The power mod that I've been toying with is a
KermaTDI Q-Loader and performance tune
for $735. Guys that have that mod are reporting an increase of 30 to 40 Hp and around 40 ft-lbs increase in torque. There are other tuners out there such as RocketChip and others.
(on edit) I forgot to also mention that the KermaTDI Q-Loader allows you to go back to your stock tune in a matter of minutes which is great if your car is still under warranty.
If you want a site with good information on TDI's it's
TDIClub
. There you'll find more information about maintenance, tuning & performance, and other things that you won't believe it.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
July 29, 2008, 10:40:54 pm
Powered by Spearco
05 tdi jetta
July 29, 2008, 10:40:54 pm »
I just got my '04 Jetta flashed with Rocketchip and wow :shock: , it really hauls but now. Well worth the money. It was a PD100 HP and now is about a 130 HP :roll:.
Josh
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
July 30, 2008, 06:32:55 am
myke_w
05 tdi jetta
July 30, 2008, 06:32:55 am »
you'll want to remember to save up for a clutch kit when you start adding mods. When you start slipping, replace it with a sachs solid flywheel kit and never look back.
July 30, 2008, 07:52:03 am
Jesse34567
Newbie
05 tdi jetta
July 30, 2008, 07:52:03 am »
what else can u do? cause i am thinking about some easy horsepower with rocket chip
July 30, 2008, 08:17:23 am
myke_w
05 tdi jetta
July 30, 2008, 08:17:23 am »
I own a bone stock PD and this is what I plan to do in this order.
Injectors aren't worth a whole lot of ponies as far as I can tell, it should be one of the last things you do.
EGT / Boost Guage
Chip Tuning
VR6 Clutch, pressure plate, solid flywheel
Front mount intercooler and improved piping
PD150 intake
Free flowing downpipe and possibly de-cat
Bigger turbo
Limited Slip Diff and other traction mods
05 tdi jetta
