Author Topic: 05 tdi jetta  (Read 4139 times)
July 29, 2008, 05:11:33 pm
Jesse34567
  • 2
05 tdi jetta
« on: July 29, 2008, 05:11:33 pm »
i am just wondering what perfomance mods u guys would recommend for 05 jetta tdi
Reply #1July 29, 2008, 08:54:49 pm
VW_Commuter
  • 355
05 tdi jetta
« Reply #1 on: July 29, 2008, 08:54:49 pm »
How much are you looking to spend?  Since it's an '05 that means it has Pumpe Duese injection and that means that no power mods are cheap.  Injectors are $400/each for a total of $1600 to change your injectors.
The power mod that I've been toying with is a KermaTDI Q-Loader and performance tune for $735.  Guys that have that mod are reporting an increase of 30 to 40 Hp and around 40 ft-lbs increase in torque.  There are other tuners out there such as RocketChip and others.
(on edit)  I forgot to also mention that the KermaTDI Q-Loader allows you to go back to your stock tune in a matter of minutes which is great if your car is still under warranty.
If you want   a site with good information on TDI's it's TDIClub.  There you'll find more information about maintenance, tuning & performance, and other things that you won't believe it.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #2July 29, 2008, 10:40:54 pm
Powered by Spearco
  • 1203
05 tdi jetta
« Reply #2 on: July 29, 2008, 10:40:54 pm »
I just got my '04 Jetta flashed  with Rocketchip and wow :shock: , it really hauls but now. Well worth the money. It was a PD100 HP and now is about a 130 HP :roll:.
Josh
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #3July 30, 2008, 06:32:55 am
myke_w
  • 1099
05 tdi jetta
« Reply #3 on: July 30, 2008, 06:32:55 am »
you'll want to remember to save up for a clutch kit when you start adding mods. When you start slipping, replace it with a sachs solid flywheel kit and never look back.
Reply #4July 30, 2008, 07:52:03 am
Jesse34567
  • 2
05 tdi jetta
« Reply #4 on: July 30, 2008, 07:52:03 am »
what else can u do? cause i am thinking about some easy horsepower with rocket chip
Reply #5July 30, 2008, 08:17:23 am
myke_w
  • 1099
05 tdi jetta
« Reply #5 on: July 30, 2008, 08:17:23 am »
I own a bone stock PD and this is what I plan to do in this order.
Injectors aren't worth a whole lot of ponies as far as I can tell, it should be one of the last things you do.
EGT / Boost Guage
Chip Tuning
VR6 Clutch, pressure plate, solid flywheel
Front mount intercooler and improved piping
PD150 intake
Free flowing downpipe and possibly de-cat
Bigger turbo
Limited Slip Diff and other traction mods
