Author Topic: Best way to drop my 1994 Jetta GL?  (Read 4326 times)
May 20, 2008, 11:42:44 pm
Votex.IDI
  • 2
« on: May 20, 2008, 11:42:44 pm »
What is the best way to lower my car with stock suspension?
Reply #1May 21, 2008, 05:46:39 am
fastvicar
  • 154
« Reply #1 on: May 21, 2008, 05:46:39 am »
About the only way you can lower the car with stock suspension is to cut off coils from the springs.  Keep in mind that it increases the effective spring rate when you do this.  And it is not recommended by most people.
You could also sag the springs by heating them with a torch.  The chances of you getting the car balanced & handling properly with this method are far less than you melting brake lines or setting it on fire.
1981 Rabbit 1.6L TURBO!!  "The Whistle Pig"
Reply #2May 21, 2008, 12:00:08 pm
« Reply #2 on: May 21, 2008, 12:00:08 pm »
Quote from: "fastvicar"
should probably be heating up the coils outside of the car... but leaving them on while you do it would help you get the right height a bit easier...
you need to get even heat distribution over the steel though (possibly even heating it red hot?)
Reply #3May 21, 2008, 12:19:32 pm
rallydiesel
  • 1880
« Reply #3 on: May 21, 2008, 12:19:32 pm »
Best way to lower your car with stock springs is to fill your trunk with dead hookers.
 :roll:
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #4May 21, 2008, 09:40:42 pm
Votex.IDI
  • 2
« Reply #4 on: May 21, 2008, 09:40:42 pm »
hahaha! All very awsome suggestions,
Is there a good method for getting the height as similar as possible when heating out side of the car?
recommended coilovers? and drop to my car? (i.e height, how low should I go?)
Reply #5May 21, 2008, 10:04:33 pm
Op-Ivy
  • 513
« Reply #5 on: May 21, 2008, 10:04:33 pm »
I wouldn't touch stock suspension at all. Just asking for trouble IMO.
If you are tight on cash just get some lowering springs and run them with stock shocks/struts.
Just get a cheap cupkit. Worth it in the end.
Reply #6May 22, 2008, 07:12:18 am
« Reply #6 on: May 22, 2008, 07:12:18 am »
Quote from: "Op-Ivy"
X2
Lowering springs are just not that much money..
Reply #7May 26, 2008, 01:45:13 pm
LoneWolf
« Reply #7 on: May 26, 2008, 01:45:13 pm »
IMO springs with stock shocks are horrible to drive with, you may as well just save your cash and buy either springs and shocks, or a cheap set of coilies
