Author Topic: parts swaping na and td cranks  (Read 3205 times)
April 27, 2008, 01:02:14 pm
turbosuzi
« on: April 27, 2008, 01:02:14 pm »
My 1.6td lost oil and seized. I tore it down and the bores are in great shape and I ran a hone over them. I am wondering if any one knows if I can use the crank from an 81 na that I have, might there be any problems with seals, bearings, oiling, or pullys?
Reply #1April 27, 2008, 01:24:29 pm
Quantum TD
  • 1195
« Reply #1 on: April 27, 2008, 01:24:29 pm »
I don't know offhand. But you could check VAGCAT.com and compare the part numbers.
Reply #2April 27, 2008, 07:15:37 pm
« Reply #2 on: April 27, 2008, 07:15:37 pm »
a turbo crank is different, its hardened at one end or the other or some other crap, but they are interchangable.
Reply #3April 27, 2008, 09:11:21 pm
turbosuzi
« Reply #3 on: April 27, 2008, 09:11:21 pm »
I am goin to use it as a na, so i should be fine?
I live in a rural area but I dont have access to a Bently and I dont know what size bearings to buy, how do I know if they need to be replaced or if I can reuse them?
Reply #4April 28, 2008, 06:23:27 pm
bugnut
  • 89
« Reply #4 on: April 28, 2008, 06:23:27 pm »
If the engine seized you are not going to reuse the old bearings.  You need the book and check the bores with a micrometer and compare those numbers to the books numbers.  Then with all that info you can determine if you need a line bore or just new bearings.
1980 Rabbit  1.9/1.6 franko engine.  compound built in the works
Reply #5April 28, 2008, 07:24:36 pm
« Reply #5 on: April 28, 2008, 07:24:36 pm »
i think it'd be fine whether you turboed it again or not
Reply #6April 29, 2008, 12:11:42 am
turbosuzi
« Reply #6 on: April 29, 2008, 12:11:42 am »
I did not mean that I was going to use the bearings of of the seized crank. I was wondering if there was a way too know if the bearings that are on the  donor crank on the donor motor were in need of replacement?
Reply #7April 29, 2008, 12:13:05 am
turbosuzi
« Reply #7 on: April 29, 2008, 12:13:05 am »
Quote from: "turbosuzi"
I am going to try to get into town and get a bently this week
Sorry I meant to edit not quote myself..
Reply #8April 29, 2008, 06:42:41 am
« Reply #8 on: April 29, 2008, 06:42:41 am »
I would worry about tearing it down before you worry about what to get for it. If you lost oil, you could have damaged the journals, then you'd have to get it turned and would need a different size.
Reply #9April 29, 2008, 12:30:32 pm
turbosuzi
« Reply #9 on: April 29, 2008, 12:30:32 pm »
I already tore it down and the seizur was on the crank to connecting rod all of the journals are in great shape. I am going to take a crank out of a na motor that I have and install it into my td with new rings, seals and bearings.
Reply #10April 29, 2008, 01:22:39 pm
« Reply #10 on: April 29, 2008, 01:22:39 pm »
All you have to do is look at the bearing from the NA engine. If they are stock  then you should be able to just get new stock sized bearings.
Same with the rod bearings.
Reply #11April 29, 2008, 07:20:56 pm
turbosuzi
« Reply #11 on: April 29, 2008, 07:20:56 pm »
awesome that was helpful. Ill get the new bearings of the same size.
Sorry if I was not clear about my  question.
Reply #12April 29, 2008, 07:48:21 pm
mk2diesel
  • 60
« Reply #12 on: April 29, 2008, 07:48:21 pm »
just buy some PLASTIGUAGE and follow the directions  ...
