tdc marks on flyweel
Topic: tdc marks on flyweel (Read 11002 times)
March 23, 2008, 04:03:36 am
carrizog60
March 23, 2008, 04:03:36 am »
was seeing the french forum and see that the timing marks on the flyweel that they take for reference is this:
am i doing wrong?
i never timed my pump by this but by other mark that it has... :shock:
see on bentley:
Portugal
March 23, 2008, 04:23:54 am
Baselyne
doubt it
March 23, 2008, 04:23:54 am »
I dont think that's the right mark but i could be wrong!
March 23, 2008, 04:25:46 am
carrizog60
March 23, 2008, 04:25:46 am »
because if its the wrong mark should be chaged the post as beeing a sticky...
Portugal
March 23, 2008, 10:27:28 am
March 23, 2008, 10:27:28 am »
Unfortunately there are several different marks, and then people scribe their own / use gasser flywheels etc etc.
Your first picture looks a bit wonky to me in that I've never ever seen a factory timing mark right next to a flywheel bolt.
The second picture is definitely the factory mark, properly aligned. Both my current diesel flywheels have the diamond shape *and* a line, but the same diamond shape for sure.
My opinion would be: if you can find a mark like the second picture then go for it..... the first one looks aftermarket-ish to me.
March 23, 2008, 11:08:21 am
carrizog60
March 23, 2008, 11:08:21 am »
well,the first pic is what is in the french area in a diy for timing the pump...
maybe i will alert them :arrow:
Portugal
March 23, 2008, 11:19:44 am
burnt_servo
March 23, 2008, 11:19:44 am »
if a person un bolted the fly wheel from the flex plate , and moved it one bolt over , would that not change the timing marks?
i can't remeber if the fly wheel and flex plate are indexed to each other .
1990 jetta , tweaked pump , tweaked turbo , ported head 2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
March 23, 2008, 03:34:04 pm
rallydiesel
March 23, 2008, 03:34:04 pm »
They are indexed to each other. There are pins that only allow the flywheel to bolt to the pressure plate one way. With that being said, using a different pressure plate could allow the flywheel to bolt on differently. I installed a new p-plate and the I had to scribe a new timing mark.
1991 Jetta TD - sold
2001 Golf TDI - Son's
March 24, 2008, 05:31:25 am
myke_w
March 24, 2008, 05:31:25 am »
That first picture is (i'm pretty sure) the dynamic timing mark for a gasser motor. It appears that someone has used a gasser flywheel on a diesel
To the right of that mark (about 1/2 inch) I believe you will find a little round peen mark, that's the static timing mark..
March 24, 2008, 09:39:26 am
subsonic
March 24, 2008, 09:39:26 am »
So is there a way to mark the flywheel for TDC before it is mounted to the engine?
1985 VW Golf 5-spd, 4-door, 1.6NA Bought from orig. owner in Savannah with 42,000 miles.
1980 VW Rabbit LS 5-spd, 4-door 1.6NA almost 450,000miles RIP
March 24, 2008, 10:02:17 am
rallydiesel
March 24, 2008, 10:02:17 am »
The best way would be to have the cylinder head off and the transmission on. Use a dial gauge and find TDC and then punch TDC on the flywheel.
March 24, 2008, 10:40:40 am
myke_w
March 24, 2008, 10:40:40 am »
I've snapped some pics with my phone showing in this order"
0 dot in white on:
gas flywheel
newer diesel flywheel (3 bolt)
older diesel flywheel (2 bolt)
all 0 dots in same place
and all 3 have the alignment pegs in the same place
http://oak.cats.ohiou.edu/~mw105397/VW/pics/020_Flywheels/
Reply #11
March 24, 2008, 09:46:33 pm
Tintin
Reply #11 on:
March 24, 2008, 09:46:33 pm »
The first pic is from AAZ, at each time that I have make a timing on this engine, I white painted the mark.
Reply #12
March 26, 2008, 11:18:37 am
slorimer
Reply #12 on:
March 26, 2008, 11:18:37 am »
so in picture Photo0021
is the TDC mark the punch mark to the right of the white dot?
94 1.9TD
Reply #13
March 26, 2008, 12:25:47 pm
Baselyne
just wondering....
Reply #13 on:
March 26, 2008, 12:25:47 pm »
so when putting the gasser flywheel onto a diesel how do I know where to mark the tdc mark?
Reply #14
March 26, 2008, 02:40:34 pm
Reply #14 on:
March 26, 2008, 02:40:34 pm »
I'm pretty sure that I used this mark to time my last engine.... It runs fine.
I'll have to take the head off my spare engine and verify the marks. Come to think of it I don't think I've ever seen that diamond looking thing
