serpentine setup, no power steering, possible?
Topic: serpentine setup, no power steering, possible? (Read 4325 times)
January 28, 2008, 11:19:44 am
flapjack
January 28, 2008, 11:19:44 am »
I've got the serpentine belt setup from a 1.9 td on my 1.6td
It has a vbelt for the water pump & power steering
If the power steering pump is removed, how do you tighted the vbelt?
Did any mk3 come from the factory without p.s.?
thanks
signature
January 28, 2008, 11:25:46 am
January 28, 2008, 11:25:46 am »
i suppose you would need to find a car without P/S. or just install a junk p/s pump?
January 28, 2008, 11:25:58 am
January 28, 2008, 11:25:58 am »
http://vwdiesel.net/phpBB/viewtopic.php?t=9599
you need this style of water pump pulley
January 28, 2008, 11:56:04 am
flapjack
January 28, 2008, 11:56:04 am »
i think a junk ps pump would seize without the ps oil going thru it.
Quote from: "burn_your_money"
the one that has the serp driving the water pump? I've looked for that. I can't find that anywhere.
thanks, if i can't find it, i may just put the ps back in.
signature
January 28, 2008, 02:25:31 pm
January 28, 2008, 02:25:31 pm »
Take a PS pump, fill it with fluid and just make a loop. Not very efficient but it'll work.
I'll see about getting you a PN for that pulley
January 29, 2008, 06:16:37 am
flapjack
January 29, 2008, 06:16:37 am »
Burn
yes please , if you can. the part number would be great. There is a great vw junkyard in Pennsylvania with Canada 1.9 diesels, they got me the serp setup, but he can't find that water pump pulley for me.
Is there a belt specific to a car with no PS but WITH AC ?
Did those cars have AC? Your picture in the faq shows the water pump powered by the serp, but the AC is missing.
signature
January 29, 2008, 07:13:57 am
January 29, 2008, 07:13:57 am »
That is a factory non ac model. I don't know much about AAZs but I would imagine it needs a different belt. I'm not sure but the AC ones might drive the WP with the v-belt, I'll check though as I have 3 of these engines kicking around
January 29, 2008, 08:52:02 am
January 29, 2008, 08:52:02 am »
I think you guys need one of these:
http://forums.vwvortex.com/zerothread?id=3494610
Or: (pic shows a 16v but I've heard it works with any VW 4-banger)
'86 Golf N/A Diesel -->Wife's car
January 29, 2008, 09:43:45 am
flapjack
January 29, 2008, 09:43:45 am »
Thanks Verminaard !
that's very cool, but I have to keep the AC.
(north new jersey summers, humid 100 deg & 45 minute commute)
That kit uses a 1.9TD crank pulley and obd-1 vr6 water pump pulley
if that water pump pulley doesn't interfere with the ac pulley, thats what I'll use.
He sells a 1.9TD crank pulley for $75 which seems like a really good price.
I thought they were over $200 ??
signature
February 08, 2008, 06:50:43 am
flapjack
February 08, 2008, 06:50:43 am »
The vr6 water pump pulley fits.
It looks a little off center, the belt riding a bit closer to the outside edge, but looks like it'll work.
signature
February 20, 2008, 01:15:38 pm
Busdriver
User+
February 20, 2008, 01:15:38 pm »
Use a junk power steering pump as an idler pulley to tighten the belt.
Take a power steering pump, open it up, REMOVE the vanes, reassemble.
Fill with power steering fluid (don't forget to plug the holes) reinstall.
Pretty much the same answer as run a junk power steering pump in a loop, but without the loop.
John Koloski
98 Jetta TDI
90 Vanagon 1.9TD AAZ
occasional biodiesel brewer
Reply #11
February 25, 2008, 04:32:42 pm
BigVWman
Reply #11 on:
February 25, 2008, 04:32:42 pm »
Flapjack did you ever get the serp system to work with a/c and driving waterpump? I just put bracket and parts on my 1.9 and looks like the serp belt won't even touch water pump pulley when a/c is installed. I was hoping to retain a/c but drive h20 pump off serp if possible any suggestions?
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby, 87 gti, 01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #12
February 25, 2008, 08:52:37 pm
flapjack
Reply #12 on:
February 25, 2008, 08:52:37 pm »
I don't see a way to keep AC and run the water pump with the serp
I think I may put the @#$-ing power steering back on and run the v belt for the water and power steering as the good Lord intended.
At the moment I've got a serpentine belt running the water pump but going backwards over the AC. It'll do until I actually finish getting the rest of the car together and actually starting it. For some reason I can't finish this job
signature
Reply #13
February 26, 2008, 06:05:03 am
subsonic
Reply #13 on:
February 26, 2008, 06:05:03 am »
Little helper :lol:
1985 VW Golf 5-spd, 4-door, 1.6NA Bought from orig. owner in Savannah with 42,000 miles.
1980 VW Rabbit LS 5-spd, 4-door 1.6NA almost 450,000miles RIP
