Author Topic: SOLD- Bosch Diesel Injection Pump on Ebay  (Read 4770 times)
January 27, 2008, 08:17:48 pm
mtnbob
  • 738
« on: January 27, 2008, 08:17:48 pm »
I put my injection pump out of my 86 Golf 1.6 N/A with 110,000 miles on ebay. I bought a Giles high-performance pump for my car and kept this one to reseal, but I never got around to it.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=130193829199&ssPageName=STRK:MESE:IT&ih=003
96 Subaru Outback Wagon
Reply #1January 28, 2008, 09:20:44 am
yeagerjf
  • 12
« Reply #1 on: January 28, 2008, 09:20:44 am »
Can anyone tell me if this will fit my 89 Jetta.  1.6L NA?
Thanks
Reply #2January 28, 2008, 09:41:18 am
« Reply #2 on: January 28, 2008, 09:41:18 am »
Yes it will. It'll even work on TD cars and mk1 diesels
Reply #3January 28, 2008, 10:30:35 am
mtnbob
  • 738
« Reply #3 on: January 28, 2008, 10:30:35 am »
ty tyler i wasn't sure if it worked in turbos or 1.5L engines
Reply #4January 28, 2008, 10:35:52 am
« Reply #4 on: January 28, 2008, 10:35:52 am »
I wouldn't recommend it for 1.5 engines, it would be less then optimal. If you run it on a TD engine you are basically creating an ECO diesel except the pump plungers are 1 mm larger (I think) so you'd have a bit more power
Reply #5January 28, 2008, 10:47:03 am
mtnbob
  • 738
« Reply #5 on: January 28, 2008, 10:47:03 am »
so you recommend me leaving the ad how it is? it doesn't sound like an optimal turbo pump either
Reply #6January 28, 2008, 11:34:16 am
« Reply #6 on: January 28, 2008, 11:34:16 am »
Well the 1.6 was available in the Mk1 chassis, also the Mk2 chassis goes up to 92, which you have excluded in your ad.
I might say that it will work on all VW 1,6 NA engines and will also work on the TD engine however power may be reduced. I say may be reduced because a good NA pump versus a crappy TD pump will most likely yield more power then the TD pump
Reply #7January 30, 2008, 06:25:14 am
mtnbob
  • 738
« Reply #7 on: January 30, 2008, 06:25:14 am »
I fixed the ad to include 1992 cars, and put in a note about it working on turbo models, though at a reduced HP 8)
