Author Topic: TDI alternator problem  (Read 5591 times)
January 07, 2008, 01:40:14 pm
oldskool rich
  • 446
« on: January 07, 2008, 01:40:14 pm »
basicly i hav an aaz and just added a tdi 140amp alternator aparently off a new A4 and now my rev counter wont work, was previously using the W terminal but dont know where to get the signal from now, i thort it was the 2 wires cumming out the plug at the top front side (2 blue wires) but these dont seem to work, am i barking up the wrong tree, or cud there be a problem with my alternator or rev counter?
maybe ive wired it wrong, wen i had the W terminal only one wire needed to go to the taco, do i need to make a circuit of sum kind to get a signal with this one?
f6squared I.D.S.T
Reply #1January 07, 2008, 01:53:24 pm
RabbitGTDguy
  • 1274
« Reply #1 on: January 07, 2008, 01:53:24 pm »
Some gasser alternators don't have the W terminal actually wired up. Though, I've yet to run across one that actually says "W" and isn't setup to pickup the signal. Are you sure your unit actually has the W terminal on it?
Joe
1972 VW Westfalia
Reply #2January 07, 2008, 02:48:55 pm
oldskool rich
  • 446
« Reply #2 on: January 07, 2008, 02:48:55 pm »
sorry no the new alternater doesnt have a W terminal, just a plug cuming out of the top and i cant get a signal from it, i wanted to know how i can run my rev counter from it
f6squared I.D.S.T
Reply #3January 07, 2008, 02:51:17 pm
oldskool rich
  • 446
« Reply #3 on: January 07, 2008, 02:51:17 pm »
gassers get there revs from the coil dont they, i obviously cant do that
there must be a way, surly cars with AFN engines must hav rev counters?
f6squared I.D.S.T
Reply #4January 07, 2008, 03:11:19 pm
« Reply #4 on: January 07, 2008, 03:11:19 pm »
You can make a w terminal. You just need to solder a wire onto one of the junctions where the windings hook to the diodes so that you get unrectified AC. Either run a very well insulated wire out for your w terminal, or steal a terminal out of another alt and install it in yours. If you look here http://www.66rover.com/rover%20rebuild/index.html and click on 052907, you can see how I did it on my Delco.
Reply #5January 07, 2008, 04:02:13 pm
snakemaster
  • 405
« Reply #5 on: January 07, 2008, 04:02:13 pm »
rich there seems to be somthing wrong with the wheels on your truck , dose your wheels  not hit things when you drive along ? i would not stick your head out of the window cos a big rock mit get flun from your wheel and hit you on the head , that wouldent be to good  :lol: the cops must love you 8)
Reply #6January 07, 2008, 04:53:27 pm
RabbitGTDguy
  • 1274
« Reply #6 on: January 07, 2008, 04:53:27 pm »
Quote from: "jimfoo"
No...you can't get the signal like a gasser does...and new gassers don't even use the coil for the most part.
Here is your answer though! Perfect JIMFOO!!!
Joe
1972 VW Westfalia
Reply #7January 07, 2008, 05:16:32 pm
oldskool rich
  • 446
« Reply #7 on: January 07, 2008, 05:16:32 pm »
thanx jimfoo, that link is helpfull, was hoping i wasnt gona hav to take anything else apart but never mind :roll: cheers for the help
i know my wheels stick out, they are mini fitment, 20mm front and 30mm rear spacers too, i havent been hit in the head yet, but does flick up loads of water in the rain, fuzz get confused wen i tell em comercial vehicle mots are different to cars, not been convicted yet :lol:
f6squared I.D.S.T
Reply #8January 07, 2008, 08:36:47 pm
« Reply #8 on: January 07, 2008, 08:36:47 pm »
the 140 amp alternator fits the AAZ? so it would fit the 1Z right? i'm thinking of getting a big and juicy alternator for my TDI (that already has the one way clutched pulley) so i don't have too many charging issues if i'm running an air/water intercooler setup, coolant glow-plug pre-heating system, water injection, big stereo  :twisted:  etc...
my guess is that the 140 amp alt would put quite a bit of a load on the engine... i heard of some kid putting a 300 amp alternator on a 1.6N/A... thing couldn't even hold idle... it just barely started then died  :lol:
http://cgi.ebay.com/ebaymotors/VW-MK-4-TDI-ALTERNATOR-JETTA-GOLF-BEETLE_W0QQcmdZViewItemQQ_trksidZp1638Q2em118QQcategoryZ33573QQihZ003QQitemZ130079398748QQrdZ1QQsspagenameZWD1V
would that work?  price seems a bit steep but looks in good condition (not that it means that it works flawlessly)
thanks
i've also found this:
http://cgi.ebay.com/ebaymotors/New-Alternator-VW-TDI-Golf-4-Jetta-4-Beetle-Volkswagon_W0QQcmdZViewItemQQ_trksidZp1638Q2em118QQcategoryZ33573QQihZ013QQitemZ230205809559QQrdZ1QQsspagenameZWD1V
looks like its from www.dieselvw.com though... i bet its the 90 amp version and doesn't look like it has the clutched pulley, but i may be wrong...  he's got intake/exhaust valves now too! damn wish i ordered some!
Reply #9January 08, 2008, 03:13:33 am
RabbitGTDguy
  • 1274
« Reply #9 on: January 08, 2008, 03:13:33 am »
140amps would be nice to have. Your first one there def. does have the clutch pulley (I actually have a brand new one sitting here (the clutch pulley that is) waiting for a nice alternator to install it on). The second does not. I remember someone on the board here saying that there is a guy on ebay that does "rewire" alternators...be it your VW 70, 90, 120amp for 140amps if you want it. I think 120amp would be plenty. Currently I'm running a 90amp with my A/W setup and some other bits (fuel pumps, will have relayed lights, etc.) I'm not planning anything major stereo wise. 140amp is a possibility though and would be nice with the clutched setup. I still haven't looked into getting an alternator from him...but may need to in the future. Def. with the b3 mTDI project on the horizon! Need to find another 1z/AHU accessory bracket for that matter though!
Joe
1972 VW Westfalia
Reply #10February 09, 2008, 11:12:01 pm
hillfolk'r
  • 1532
« Reply #10 on: February 09, 2008, 11:12:01 pm »
those wheels are hot ,im droolin
hey you can get a "w" terminal by splitting the case,and soldering a wire to any one of the 3 leads coming off the stator going to the diode pack
just connect to it BEFORE the diode pack,this is ac electricity and the tach runs off of the frequency
the middle one is the w lead
they wont be labled,but the 3 stator leads are u,v,and w if i remember the din wiring standards correctly
i have an old 55 amp alternator in my car that i modded this way,so i can use my vdo diesel tach
ive done it many times,as ive had alternators fail/etc...ive had the same tach for over 10 years now and its been in many cars
Throttle cables ftw
