Author Topic: Flipping Exhaust manifold? Let's see your new oil lines...  (Read 5387 times)
January 07, 2008, 05:15:10 am
Baselyne
« on: January 07, 2008, 05:15:10 am »
If a person was planning on flipping their exhaust manifold to run a gasser intake mani then Im told a person would have to make custom oil lines...
Does anyone care to share what they have fab'd up in the way of using that gasser intake mani?
Reply #1January 07, 2008, 02:56:13 pm
« Reply #1 on: January 07, 2008, 02:56:13 pm »
if ur going to do that why not get a better mani and a better turbo
Reply #2February 09, 2008, 11:29:24 am
hillfolk'r
  • 1532
« Reply #2 on: February 09, 2008, 11:29:24 am »
i use a early 4-2 manifold flipped over w/an adapter block to mate to a t3 flange
i was able to rebend the oil feed line,but made up a custom -10 an line for the drain
i cut off the stock drain tube before the rubber,and welded on a -10 fitting to screw the line onto
put a -10 bulkhead in the pan in stock td location
works great
Throttle cables ftw
