Author Topic: Franken motor!  (Read 150865 times)
Reply #270April 20, 2008, 05:51:50 am
subsonic
  • 1836
Franken motor!
« Reply #270 on: April 20, 2008, 05:51:50 am »
Quote from: "dubbinchris"
Quote from: "935racer"
Video:
http://millerperformancecars.com/car-videos/passenger-performance-jetta.html
Why linkey no work anymore?
Try this one.
http://www.passengerdiesel.com/
Reply #271May 13, 2008, 05:27:19 am
MJF
  • 581
Franken motor!
« Reply #271 on: May 13, 2008, 05:27:19 am »
Any progress?
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #272May 13, 2008, 07:54:32 am
DVST8R
  • 535
Franken motor!
« Reply #272 on: May 13, 2008, 07:54:32 am »
I was at dave's shop on the first weekend in may for the dyno day, and it was still parked exactly where he put it when it died. Too this point he has been to busy to even pop the hood, and I would suspect with race season in full swing, that unless I take it upon myself to do when I'm back down there at the end of May, nothing will happen with it until September / October area.
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #273July 22, 2008, 03:34:38 pm
DVST8R
  • 535
Franken motor!
« Reply #273 on: July 22, 2008, 03:34:38 pm »
Well I had a chance to go back down to Dave's shop a couple week's back to help a friend with another project.
Dave finally had a chance to pull off the head and see what caused the damage...
Well after that much suspense it appears that the injector was worn and leaking, to the point were it eventually was sticking open, causing enough heat to melt out the pre cup and have it fall into the piston, and then that smashing the motor.
So after all of that it was just a regular maintenance item that killed the motor, and nothing to do with the nearly 200whp that it was pushing.
Dave has since bought a benz wagen, and I believe that the jetta has gone to the JY. Yes he did pull off anything of value. He has no plans to ever rebuild that motor, the next vw project that he has is his caddy, and I don't even think he knows what he is going to run for a motor in that.
Reply #274July 22, 2008, 05:59:42 pm
foxracer1
  • 991
Franken motor!
« Reply #274 on: July 22, 2008, 05:59:42 pm »
Is there a pic? Can't see it if there is. I'd like to see it.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #275March 16, 2009, 06:11:49 pm
Franken motor!
« Reply #275 on: March 16, 2009, 06:11:49 pm »
does anyone still have these videos?
Video:
Click and save as.
The ones I just put on that made less power were 1.9 injectors with mercedes 300d nozzles, the ones that made 195 (smoothed graph) were stock 1.6td.
The 1.9 injectors do seem to give more fuel, I took it for a drive and my revs were hanging, but but it doesn't pull as hard as the 1.6 nozzles.
What are we going to do to get more fuel Giles? I need way more fuel from 5500 and up.
Reply #276March 16, 2009, 07:17:25 pm
cyrus #1
  • 360
Franken motor!
« Reply #276 on: March 16, 2009, 07:17:25 pm »
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #277February 16, 2013, 03:16:23 pm
Re: Franken motor!
« Reply #277 on: February 16, 2013, 03:16:23 pm »
I know Dave has posted this in another thread, but I thought I would try to keep this one all together. This is his Dyno chart from his dyno pull today. It has zero correction factor, and zero smoothing. Dave also clicked on the wrong thing before he pushed print so it doesn't have rpm, but now that He is moving to this shop and will have a dyno full time, I'm sure we will see not only some more HP, but a smoother graph, with RPM. Also he was having trouble maintaining boost on the dyno, it would peak at 28psi, and quickly fall back to 22psi. Anyway enough blabing here it is. Edit: It is a brand new Mustang Dyno
Hoping for a 200+ in the very near future.  :wink:
Just bumping the thread for those interested.
You guys really need to learn to search.
Reply #278February 18, 2013, 05:57:48 am
Re: Franken motor!
« Reply #278 on: February 18, 2013, 05:57:48 am »
Looking back I wonder if with the gt2056 and awic if Malone had already reached close to the same hp.   2056 is capable of it on paper
