Author Topic: Successful N/A governor modders?  (Read 5282 times)
December 08, 2007, 07:30:01 pm
Brian Rages
  • 3
« on: December 08, 2007, 07:30:01 pm »
Hi,
I'm doing a re-seal on my injection pump and thought it would be a good time to do a little hot-rodding.
I've read a lot on the "governor mod", but it seems like the method outlined in the FAQ is not the correct method for the N/A.
For the N/A, I want to shim the main spring?  Is this right?
Has anyone done this mod with good results?  Thanks!
In other news, I just ordered a GERMAN timing belt and tensioner...
Reply #1December 09, 2007, 03:35:55 am
snakemaster
  • 405
« Reply #1 on: December 09, 2007, 03:35:55 am »
main spring for the n/a worked good on my 1.9 n/a  it was very close to 90hp  + a few other tweeks  8)
Reply #2December 10, 2007, 10:52:50 am
935racer
« Reply #2 on: December 10, 2007, 10:52:50 am »
Yeah shim the main, I mod alot of the NA pumps because they are so damn slow :lol:
I shim them about .055".
Reply #3November 19, 2009, 12:27:27 pm
professor
  • 14
Re: Successful N/A governor modders?
« Reply #3 on: November 19, 2009, 12:27:27 pm »
the following process is the correct procedure for gov mod in NA pumps?
http://forums.vwvortex.com/zerothread?id=3107325
Reply #4November 19, 2009, 02:34:03 pm
« Reply #4 on: November 19, 2009, 02:34:03 pm »
giles has commented on this forum about the na pump before maybe i can find it
Reply #5November 19, 2009, 04:33:08 pm
Reply #6November 19, 2009, 05:19:38 pm
« Reply #6 on: November 19, 2009, 05:19:38 pm »
Jimfoo told me NOT to shim/remove the intermediate spring. He put a solid piece in there and it hurt drivability. I shimmed the Main spring about 1/4" or .250.... Maybe closer to .3"  Anyway, I had perfect results and wouldn't do it any other way. You try and let us know.
Reply #7November 19, 2009, 06:02:00 pm
« Reply #7 on: November 19, 2009, 06:02:00 pm »
There's absolutely no reason to shim the intermediate spring - it's total movement is like 2mm, you can easily overcome it with the throttle.  What it does is make the engine a whole heck of a lot more driveable.  People mistakenly think they're gaining something by shimming it since it seems like it can reduce fueling, but it's such a small amount just pressing the pedal down further takes care of that and then some.
The big long main spring is all you need to mess with.
Reply #8November 20, 2009, 08:24:47 am
« Reply #8 on: November 20, 2009, 08:24:47 am »
i used 2 1/8 inch thick stainless nuts. fit perfect over the shaft. worked like a dream. and like him ^, i too wouldnt do it any other way, not with how good it works doing this.
Reply #9November 20, 2009, 01:44:21 pm
Reply #10November 21, 2009, 03:20:57 pm
professor
  • 14
« Reply #10 on: November 21, 2009, 03:20:57 pm »
this is what i have found for you... because i am so awesome
thks ;D ;) you're so awesome :P :P
I don't know what's mean "hurt drivability". Could u help me? thks
Reply #11November 21, 2009, 04:40:44 pm
« Reply #11 on: November 21, 2009, 04:40:44 pm »
I believe that it is turning the pump into a on/off switch. Or at least there will be a varying dead spot in your pedal. It has been awhile but I think that is what Jimfoo said to me. I just know putting probably .300" of shim in the main spring made it go like a scalded goose with no problems otherwise.
Reply #12November 21, 2009, 05:28:00 pm
« Reply #12 on: November 21, 2009, 05:28:00 pm »
I just remembered!
The spot in the middle was bad because he couldn't keep a steady speed. That was the biggest concern with the intermediate spring shim.
Reply #13November 22, 2009, 04:58:17 am
professor
  • 14
« Reply #13 on: November 22, 2009, 04:58:17 am »
I just remembered!
thks man ;)
Reply #14November 24, 2009, 09:24:03 am
professor
  • 14
« Reply #14 on: November 24, 2009, 09:24:03 am »
thanks
I will shim the main spring. 1 more question: for 1/4mile in NA diesel cathegory the better is shim the intermediate spring and the main or only the main?
