Author Topic: IDI to TDI  (Read 75532 times)
Reply #150March 19, 2008, 04:04:36 pm
IDI to TDI
« Reply #150 on: March 19, 2008, 04:04:36 pm »
Quote from: "rallydiesel"
Cool. So did you have to time the IP differently than the IDI?
Will this be an easy job for Giles (I think you said you were sending your pump to Giles?) to set-up? I am just wondering if this engine would just be treated like any 1Z. etc m-TDI or if he needs to have the engine for tuning? Does Giles even do m-TDI pumps?
I was going to send it to Giles, but was running low on money and really needed to get the car running, so I just worked on it myself. Giles will do M-TDI pumps, and he doesn't need the engine, just needs to know about what you plan to do with it. I will probably save up for a spare pump and send it to him when I get the money. As far as timing, I just set it until it didn't sound too noisy, but I'm sure it isn't optimal. It does start easily however. It's hard to get a gauge on it, but I know it's way more than .040".
That's why I got a transducer to use a timing light, so I can more easily time it, if I can ever find out how many degrees it should be set at.
Reply #151March 19, 2008, 08:27:18 pm
IDI to TDI
« Reply #151 on: March 19, 2008, 08:27:18 pm »
I've read in a couple places that  12 degrees BTDC is the magic number.  Hopefully someone with a timing light will chime in.
While rebuilding my AAZ I punched a timing mark on the flywheel at 12 BTDC in breathless anticipation !
Reply #152March 20, 2008, 04:07:07 pm
IDI to TDI
« Reply #152 on: March 20, 2008, 04:07:07 pm »
I sort of got my timing light to work. By accident, I found a really weird way to hook it up where it would flash, although it was flashing too much and the mark would jump around a bit. However I was able to fairly confidently say it was at 4 BTDC. I advanced it to 11 BTDC, although I haven't driven it yet. It still sounded ok, not too clattery, so hopefully that will do. The transducer puts out only about .5v according to my meter, although I guess if there is a fast spike, I may not be reading it. The odd way I ended up hooking it up was the lights + terminak on the battery +, the lights - terminal on the un-energized terminal of my fan relay, I guess grounding it through the fan, and the transducer wire to one of the pickup terminals on the light. It wouldn't flash at all if I grounded the light to a regular ground, or if I grounded the other pickup terminal on my light.
Reply #153March 20, 2008, 05:52:16 pm
IDI to TDI
« Reply #153 on: March 20, 2008, 05:52:16 pm »
Cool !
BTW, the timing light *may* move around for real... if your pump is worn... kinda like a worn distributor on a gasser.  Lots of wear... lots of movement.
My Tiny Tach transducer showed up so the experimentation with a home-made timing light adapter begins.  The transducer will put out a very very short spike... if I can I'll post pictures for the geeks out there like me.
Reply #154March 20, 2008, 06:54:08 pm
rallydiesel
  • 1880
IDI to TDI
« Reply #154 on: March 20, 2008, 06:54:08 pm »
How does a timing light work on a diesel? Is it reading the voltage spike from the alternator?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #155March 20, 2008, 06:59:32 pm
IDI to TDI
« Reply #155 on: March 20, 2008, 06:59:32 pm »
Couple of different methods:
- a piezo transducer is clamped to the #1 or #4  injector line... it detects the small expansion in the line when the injector is fired and drives the timing light.
- #1 or #4 glowplug gets removed and replaced with a translucent cover and a photo detector.  The photo detector sees the flame front and drives the timing light.
Reply #156March 20, 2008, 07:11:26 pm
IDI to TDI
« Reply #156 on: March 20, 2008, 07:11:26 pm »
Quote from: "Vincent Waldon"
Cool !
Yeah, I don't have a scope, so seeing the actual waveform might help me make a better adapter.
Reply #157March 22, 2008, 07:59:22 am
IDI to TDI
« Reply #157 on: March 22, 2008, 07:59:22 am »
I was a little worried yesterday. I noticed my temp was a lot warmer than it had generally been, although I still don't think my fan came on. Then I remembered I advanced the timing, probably causing more heat in the engine as opposed to the exhaust. I was thinking it was way too early for a blown head gasket.  :lol:
Reply #158March 22, 2008, 09:26:28 pm
IDI to TDI
« Reply #158 on: March 22, 2008, 09:26:28 pm »
I decided 11 degrees is too advanced with the ALFB (timing advance solenoid) energized. It was pretty loud, and my mileage went down some. With the wire off the terminal, it quieted back down, temp went down some, and it appears to be getting better mileage, though I'm just going by how much the gauge has moved. I will probably leave the timing alone now until I get it on a dyno some day.
Reply #159March 23, 2008, 10:32:55 pm
IDI to TDI
« Reply #159 on: March 23, 2008, 10:32:55 pm »
Quote from: "jimfoo"
Cool !
Posted a few pictures in the General forum under a new topic.
Reply #160April 10, 2008, 09:38:07 pm
rallydiesel
  • 1880
IDI to TDI
« Reply #160 on: April 10, 2008, 09:38:07 pm »
Hey Jimfoo, are ALH pistons the same as 1Z? Any idea if a TDI crankshaft would work in the AAZ? And finally, are the rods from an ALH the same dimensions as from an AAZ? What is the difference between the AHU and 1Z anyways?
Reply #161April 17, 2008, 06:07:04 pm
mrhutch
  • 1
IDI to TDI
« Reply #161 on: April 17, 2008, 06:07:04 pm »
AAZ will take a TDI crank
T25 Frankenstein IDI engine 1.9
Reply #162April 17, 2008, 06:59:29 pm
rallydiesel
  • 1880
IDI to TDI
« Reply #162 on: April 17, 2008, 06:59:29 pm »
So if I were to use the AAZ rods, what TDI pistons can I use? I have read that there are a couple different wrist pin diameters. Anyone know what diameter pin the AAZ cranks have? Jimfoo, did you use 1Z or AHU pistons?
Reply #163April 17, 2008, 07:14:45 pm
IDI to TDI
« Reply #163 on: April 17, 2008, 07:14:45 pm »
I believe 1Z and AHU and ALH are all the same dimension wise. I just used some of Prothe's. ALH pistons are supposed to be stronger though. I believe mine were 26mm, the same as the AAZ.
Reply #164April 18, 2008, 04:50:50 am
IDI to TDI
« Reply #164 on: April 18, 2008, 04:50:50 am »
Quote from: "prothe"
ALH and 1Z/AHU pistons are the same except for the location of the top compression ring.  This was rumored to be done for emissions reasons.
I finally have 1.6 TDI pistons.  I would love to market them now, but there is a lot of research to be done before I can start selling any kind of TDI conversion package. But the good news is that they are 76.48mm wide and the same height above the piston pin as the 1.6 diesel piston.
sorry for the thread jack, but the conversion requires sleeving of the block, so it is a bit more involved than just putting everything back together right?  is there a quick and dirty way of sleeving a block? maybe some engines won't need to be sleeved?
